Question about Kohler Electrical Supplies
2oo2 kohler is not getting gas - Kohler Electrical Supplies
  • 2,046 Answers
Does this machine have a fuel filter if so make sure it's clean. Does it have a fuel bowl? Take it off and clean it out real good . also clean the fuel jet. These are why the engines do not start or run properly if one of these are dirty. Dirt keeps the fuel out of the carb.
Posted on Apr 16, 2017
K300 gas engine. What is output shaft dia and is it keyed?
3/4 Keyed Shaft ' eBay
www.ebay.com/bhp/3-4-keyed-shaft
eBay3/4" Dia. Steel Shaft / Rod 18" Long. ( Keyed 3/16 "both ends ). $34.21 .... 3/4" to 1" inch w/Step Key Gas Engine pulley Crank Shaft Sleeve adapter Predator.
Vertical shaft Kohler Engines - Engine4Less.com
engine4less.com/ALL-Vertical-shaft-Kohler-Engines/
This engine has same mounting and shaft as all KOHLER Single cylinder ... 1"diameter x 3-5/32" length keyed VERTICAL (UP and DOWN ' ) crankshaft. Please ...
Nov 06, 2015 | Kohler Electrical Supplies
Kohler engine troubleshooting
Do you hear the fuel pump running? Is there gas coming out of the pump? Could be a bad wire connection to the fuel pump or bad ground connection.
Aug 03, 2014 | Husqvarna Ariens 46 In Deck 20 HP Kohler...
Kohler exercise causes engine spikes and gasping for fuel.
On exercise it isn't under load, you may have too much gas pressure, have the gas pressure and fuel/air ratio checked on the mixer
Dec 16, 2012 | Kohler Generator 20kw 20res W/ 200 Amp...
Kohler Generator won't start
If you have a drip leg near generator open that up for a sec and then try it again.
Nov 16, 2012 | Kohler Electrical Supplies
Kohler 14hp wont start not getting any fuel
Fuel solenoid, filter blocked, pump, carb leak check those
Oct 22, 2012 | Kohler pa-ch440-3031 gas engine, 4 cycle,...
Kohler gas geset no fuel to carb
The pickup tube in the craft's fuel tank has likely worked loose and dropped into the tank. The generator lost its "straw" that it needs to siphon fuel through.
Jun 02, 2010 | Kohler Electrical Supplies
I have a kohler cammand 18.if put a little gas in it runs for a minute then stop.some how i not getting the gas it should be feeding.
check the fuel pump it is usually on the side of engine take hose off going to carb turn over see if gas pumps out if not pump is bad
Aug 05, 2009 | Kohler CH25 PA-CH730-0040 Command Gasoline...
Electrical Supplies Logo
29 people viewed this question
Top Kohler Electrical Supplies Experts
rjivaro
John Trevino
Wayne McNeil
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
