Question about OKI Office Equipment & Supplies
How to fix an Oki 132 error - OKI Office Equipment & Supplies
What should I do when the Display says Service call 132:Error
After turning ON the
power or when cover
is closed, the sensor
detects that the unit is
missing.
1) Is an Error message displayed?
2) Is the LED head properly
mounted?
3) Does the Error take place
again?
Confirm that the lever is in
position.
Replace the toner feed unit.
Replace the ID units.
May 27, 2014 | OKI C5100n Laser Printer
I HAVE C5500 OKI PRINTER AND THE ERROR SAYS REPLACE IMAGE DRUM 561:M DRUM LIFE I PUT IN NEW MAGELN AND STILL HAS THAT MESSAGE
oki printer c5950 fix new cartridge & drum coming error replace image drum 561:m drum life
Jan 15, 2013 | OKI C5500n Printer
Icq error 132
how can I fix the ICQ error 132?
Oct 24, 2011 | ICQ Computers & Internet
Okidata B4600 error message #132 on two printers. What does this error mean. The printers will not go to off line.
Error 132:
LED Head Missing, Color:Magenta
When magenta LED head connection cannot be detected
Solution:
You should first try to restart the printer.
If that doesn't resolve the problem, the ribbon cable is probably disconnected from the print head.
The led print heads are four assemblies that hang down from the lid of the machine when you open it. Make sure they are properly connected.
Sep 14, 2011 | OKI B4600 Printer
The display is showing Service Call 132:Fatal
I solved this problem easily (Once I found it!)..open lid, locate where the top section bright metal lugs contact with copper leaf contacts at the front of the base unit and clean them with some fine emery paper or gently with small flat screwdriver... mine had a bit of toner dust and a tiny carbon deposit which was preventing the circuit being made. This showed the fatal error 132 and you may notice on start up that the normal rotation noises within the machine were silent too. Worked for me. Problem arose after Xmas break when machine had been stood for a few weeks. Good Luck! Bryan at Pinewood Studio Manchester.
Nov 17, 2009 | OKI C9600n Led Printer
How do i solve fatal error 980
i got that error on the first day i got my oki c5950 it was a result of a paper jam in the fuser unit, i removed the jamed paper but the error was still there, i contacted oki support and got a detailed explanation on how to fix this error with a patch file, so if u or anyone out there r still having that problem send me a mail on ecks80@hotmail.com and i will forward u the info.
good luck
Sep 14, 2009 | OKI C5500n Laser Printer
Fatal error 980 OKI C5500 printer
I had a paper jam and removed the jammed papers. The paper jam cleared and then the Fatal Error 980 appeared. OKI C5500 printer
Mar 15, 2009 | OKI C5100n Laser Printer
Service Call 020 Fatal Error
Error 020 is a ROM dimm error, could be as simple as reseating/replacing Rom Dimm or a expensive main PCB, you need to get hold of a oki dealer, contact oki to find closest OKI repair agent.
www.oki.com
Jan 08, 2008 | OKI C9300 Led Printer
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
mukhtar21 shaikh
mukhtar21 shaikh
SiNnA
SiNnA
Level 1 Expert
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
