Question about HP Garden
O2 kohler 16 hp dosent seem to be getting gas
  • HP Master
  • 2,321 Answers
Does this machine have a fuel filter if so make sure it's clean. Does it have a fuel bowl? Take it off and clean it out real good . also clean the fuel jet. These are why the engines do not start or run properly if one of these are dirty. Dirt keeps the fuel out of the carb.
Posted on Apr 16, 2017
Kohler 15 hp motor turns over but will not run.what is wrong?
take the spark plug out and turn the engine over to blow out any excess gas in the chamber. put in a new spark plug and try again. if this don't work you may have a valve or timing problem. there are many videos that show how to check valve clearance and flywheel key on you tube. if you have gas and spark and compression it should start.
Mar 31, 2018 | HP Garden
K300 gas engine. What is output shaft dia and is it keyed?
3/4 Keyed Shaft ' eBay
www.ebay.com/bhp/3-4-keyed-shaft
eBay3/4" Dia. Steel Shaft / Rod 18" Long. ( Keyed 3/16 "both ends ). $34.21 .... 3/4" to 1" inch w/Step Key Gas Engine pulley Crank Shaft Sleeve adapter Predator.
Vertical shaft Kohler Engines - Engine4Less.com
engine4less.com/ALL-Vertical-shaft-Kohler-Engines/
This engine has same mounting and shaft as all KOHLER Single cylinder ... 1"diameter x 3-5/32" length keyed VERTICAL (UP and DOWN ' ) crankshaft. Please ...
Nov 06, 2015 | Kohler Electrical Supplies
Kohler engine troubleshooting
Do you hear the fuel pump running? Is there gas coming out of the pump? Could be a bad wire connection to the fuel pump or bad ground connection.
Aug 03, 2014 | Husqvarna Ariens 46 In Deck 20 HP Kohler...
I have 16 hp Kohler engine with a compression release not working,help.
i have a Kohler 16 Magnum opposed cylinder engine and it wont crank over with the spark plugs in it,battery and starter are both good,its an aluminum engine and i have seen several of the Kohler engines break the automatic compression release on the cam gear and they seem to lock up while trying to start,pull the plugs and the crank fine,Kokler is the most expensive engine i have seen and their parts are outrageously priced,old Kokler was a good engine,newer ones in my opinion are junk,i work at a small engine shop,i have seen new Kohler engines with a broken ACRs,i work at a second job,we got a new supervisor that worked for Kohler before her came to our plant,he said he worked customer service at Kohler and he heard complaints constantly from people using their engines and the returns were out the roof on their engines,what im saying is i wont ever but another Kohler unless itsm an old one,Thanks Tommy
Jun 06, 2012 | Kohler Electrical Supplies
Kohler 149 cc engine won't start seems to be getting no fuel
This may not fix your problem but it does deal with that engine. I just tried to replace the spark plug in that engine and it took me 5 hours. The Kohler plug in the engine that came from the factory cannot be found in traditional stores and it is a strange size, 11/16 or 12 mm. The Kohler plug is #1413211. I could not find a match in a book. Divine intervention lead me to a place where they were fixing the Kohler 149cc engine that had the same plug in it that mines did. I discovered that a Champion 8815 does fit the engine but it takes a 18mm socket. It did fix the problem and the mower works. Hopefully this will save someone my hassles.
Apr 28, 2012 | Garden
20 hp kohler leaking gas out front right side of motor
Check all your fuel hoses make sure they are not broken or any holes are in the lines themselves. Also clean out the Carb and all the ports leading to the engine with some carb cleaner. If you still have raw fuel leaking then you are going to have to replace the top gasket on the motor where your cylinders are located.
May 05, 2010 | Kohler CH25 PA-CH730-0040 Command Gasoline...
Garden Logo
27 people viewed this question
Top HP Garden Experts
solver2010
andrewdwhite
ray gallant
Are you a HP Garden Expert? Answer questions, earn points and help others
