Question about Troy Garden
Change drive belt on troy bilt bronco model 13wv78ks011
landsend
  • 1066 Answers
SOURCE: Troy Bilt Self Propelled Lawnmower drive belt
belts usually come off for a few reasons.
They become loose...stretch or the tensioner moves,  Make sure that none of the tightening bolds are slipping.  You can dab them with a bit of paint.
when the pulleys are not in alignment or crooked or bent.  Eyeball the path from one pulley to another, also make sure the tensioner is in alignment and there are no other obstructions.
good, high quality belts are required, and they must be real drive belts...not regular v belts.  If there is a way to watch the belt in operation you can usually see what's going wrong.
On my lawnmower I had to grind some metal away where the belt went from the motor to the transmission.  Good luck
Posted on Apr 18, 2009
SOURCE: belts slippin on troy bilt horse
Have you adjusted the locking cam for forward. This cam is held in place with one bolt. The further you move it down the tighter it will make the belt
Posted on May 05, 2009
  • 3 Answers
SOURCE: how do I change the belts on a troy bilt tiller
remove plastic belt cover
remove the guard,belt/pulley
work in the right side first:
remove the rigth-side wheel
remove the screws of the bumper
remove 2 screws on bracket/transmission assembly
pull the bracket
install the new belt
reinstall the right side screws and wheel
do the same in the left side
Ps: remove the belt guide, and reverse return spring
http://www.partstree.com/parts/?lc=troy_bilt&mn=21A-634K766+7HP+FRT+Roto-Tiller+(2005)&dn=0079200009
Posted on May 13, 2009
moretons
  • 155 Answers
SOURCE: troy bilt lawn mower bronco belt broke HELP!
hi try this site its called pats small engines
Posted on Jul 26, 2009
  • 6468 Answers
SOURCE: I HAVE A 2010 TROY BILT LAWN TRACTOR. WE HAVE TO CHANGE THE BLADE AND TRANS BELT. ONCE WE CHANGED IT, WE PUT IT IN GEAR AND GO ABOUT 10 FT. THEN IT STOPS AND WON'T MOVE. IT IS A 17.5, 42 IN. CUT,
sounds like you missed a pulley or belt guide and the belt fell off
Posted on Jul 13, 2012
Need diagram to replace tension spring for drive belt
Go to the manufacturersame website, enter in the the model number and look under diagrams for the pic of your tractor. My troy Bilt has 2 belts, one for the cutting deck and the other is the drive belt. I would replace both as the cutting deck needs to be removed and it's fairly simple and will save you time. It sounds let the drive belt is the reason for the tractor not moving. Hope this helps.
My tractor is a 2007 troy Bilt super bronco with a new fresh installed motor.
Nov 03, 2015 | Garden
Where can I get all three belt diagrams for a troy built bronco riding lawn tractor model# 13AV67KG
Troy Bilt Deck belt Replacement - YouTube
? 11:46
www.youtube.com/watch?v=w3SrErGTyoY
Apr 1, 2014 - Uploaded by Murray Mayhem
I got a good one troy bilt bronco having problems finding the right deck belt for it. I use the model number under the seat but they are too long ..
Jul 09, 2015 | Troy Garden
I have a Troy Bilt Bronco, Kohler 18 engine
its the coil it has the same one as a 12.5 has
Sep 18, 2009 | Garden
Had to change the small drive belt that drives the transmission on a Troy-Bilt 42'' 17.5 HP Pony mower. Now it only has one speed forward, slow!! Didn't touch anything-got the OEM belt replacement. Any...
You need to adjust the gas pedal. Info should be in the owners manual. I have it in my Troy Bilt Bronco manual. It say to adjust it in my book after replacing the trans drive belt. Maybe that will help.
Aug 17, 2009 | Garden
How to install belt on Troy bilt tiller:
With engine OFF If you put belt on engine pully and driven pulley then work the clutch handle you should be able to see how belt goes so it tightens when clutch is worked.
Jun 24, 2009 | Mtd Troy-Bilt Bronco OHV Tiller
Changing Drive belt On Troy Built Tiller
You have to remove the engine (4 bolts, no big problem), then remove the bolt in the center of the pulleys, then remove the pulleys. Slip the belt(s) (2 if you have the Super Bronco model) onto the pulleys, re-attach the pulleys with the bolt, re-mount the engine, and you're home free.
May 20, 2009 | Mtd Troy-Bilt Bronco OHV Tiller
Garden Logo
103 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
