Question about Cell Phones
Samsung U600 usb port wont recognize samsung U600 useing window vista ,so what to do to get vista to recognize this device John
I CONNECTED MY SAMSUNG U600 TO THE PC USING A USB CABLE AND IT SAYS "ONE OF THE USB DEVICES ATTACHED TO THIS COMPUTER HAS MALFUNCTIONED, AND WINDOWS DOES NOT RECOGNIZE IT." WHAT SHOULD I DO?
Try connecting directly to the computer its self not through a hub/keyboard/monitor. If that does not work try downloading the software from Samsung first.
May 04, 2011 | Samsung SGH-U600 Cellular Phone
Windows 7 not recognizing USB device, replaced cable and still same problem
Have you tried connecting other USB device to check if your computers USB device is still working? Have you tried using the other USB ports that you have on your computer? If you're using a USB hub disconnect it and directly connect your printer to your computer's USB port.
If you already tried those questions above try using microsoft fix, you can download it on this website: http://windows.microsoft.com/en-US/windows-vista/Tips-for-solving-problems-with-USB-devices , it shows that the fix is for windows vista but it does work on windows 7.
Note: If other USB devices are working on your computer, it's better sending your printer to a local tech to check if the problem is with your printer, or you can also try connecting your printer to another computer and check if it will work, if it works then the problem is with the computer and it also means that it's going to be a long process of troubleshooting and might end up on restoring your computer to factory settings.
Apr 23, 2011 | Samsung ML 1710 Laser Printer
Windows Vista will not recognize dell axim X3
I have had that problem with other USB devices i suggest trying a different USB port as the USB port you have used to connect the X3 to is most likely malfunctioning.
Aug 10, 2009 | Dell Axim X3 Pocket PC
Vista not recognizing PowerShot S30
1. connect U r camera to Back side Mother Board USB Port not for extension or front side port.
2. Check in bios USB controllers are enabled or disabled. if disabled enable it.
3. in windows device manger check for usb controllers
Jul 01, 2009 | Canon PowerShot S30 Digital Camera
Connecting samsung U600 to my mac computer
mine wouldnt work because the samsung mobile pc software wasnt compatible with windows vista, so if you have vista, it wont work either, will only work on windows xp x
May 07, 2009 | Samsung SGH-U600 Cellular Phone
Usb driver for samsung U600
i don't know if there is a site where you can download some software. but this problem happened whith my samsung u600, all i done to fix it was to unplug my mobile phone from my laptop and then plug it in again.
Jan 09, 2009 | Samsung SGH-U600 Cellular Phone
Usb
your usb device is use less now.
replace it if u have warrenty of it.
Mar 24, 2008 | Computers & Internet
Samsung u600 usb connection wizard
PC Studio for Vista can be found on the Samsung Website. Series is "U series" and model, of course, is U600. As for installation, as Samsung suggests, make sure that the phone is NOT connected to the USB port at ANY POINT prior to the completion of the installation. Install the software as normal. Then, after it has finished installing, open up PC Studio and plug in your phone. At this point, the software SHOULD recognize that the phone has been connected after setting it up to use USB connection in the “Connection Manager” (Click “File”, “Connection”).
If it is still not recognizing the device after plugging It in, or if it displays a message along the lines of “USB Device Not Recognized” KEEP THE PHONE PLUGGED IN TO THE USB, Go into the Control Panel in the Start Menu and open up the Device Manager. At the very bottom of the list of hardware etc, there will be a selection for “Universal Serial Bus controllers”, expand this menu and look for an item called something like “Unknown USB device”. Double click on the device and go to the “Driver” tab (I think you have to press a button on the first screen that appears in order to get to the menu driver tab. Although I can’t remember what was written on it, there was only one there). When in the Driver tab, click on “Update Driver”. Now on the wizard that appears, click on “Browse my computer for driver software” then, ignoring the rest of the page, click on “Let me pick from a list of device drivers on my computer”. Uncheck the selection box “Show compatible hardware” and scroll down the list of Manufacturers until you get to “Samsung”. Now, if you’ve installed PC Studio, you should see four separate selections for “Samsung”. Click on the fourth manufacturer selection and you should see “SAMSUNG Mobile USB Device” as a Model selection, select it and click “Next” (If, 1, you don’t see “SAMSUNG Mobile USB Device” at all, then just browse the other three Samsung based manufacturers or, if 2, you have more than one entry of “SAMSUNG Mobile USB Device” then select the top one”. Also, if Windows comes up with any warnings about installing device drivers, just ignore them). Windows will now update the driver (It actually updates three drivers). If you open up PC Studio the phone should now be recognized as connected (Assuming your prior setting up of the Connection Manager to use USB).
Good Luck.
Oct 24, 2007 | Computers & Internet
Cell Phones Logo
60 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
