Question about The Music
Sop all the clocks, in the third stanza, and how the rhythm and rhythme achieve a particular effect in line 12?
SOURCE: Low volume on front pickup of Epiphone Les Paul
i have an old sg, and this happened to me too. the repair guy told me that inside the p/u, the windings were broken, resulting in a lower output. go on e-bay, and look up a neck pos. humbucker. there everywhere. or do yourself a favor, and do what i did. i have an epi. flying v, and epi. les paul. on e-bay, i bought gibson 57 classics. i put these in both my guitars, and i now have great sounding guitars. you will not belive the difference. good luck, scott
Posted on Apr 08, 2009
  • 10406 Answers
SOURCE: I have a problem with my LCD,the keyboard id
See the answer to: http://www.fixya.com/PostAnswer.aspx?thid=3726424&prdid=360392
since your question is exactly the same as asked in that question.
Posted on Dec 27, 2009
  • 5603 Answers
SOURCE: I have a Roland D110 sound module. The rhythm
I would check to see if the unit has either a Lithium or NiCad backup battery in it which MIGHT be exhausted and need replacing.
Posted on Apr 01, 2010
  • 1138 Answers
SOURCE: Need operating manual for BOSS Dr. Rhythm Section DR-5
Here is one link:http://cms.rolandus.com/assets/media/pdf/dr5_turbo.pdf Here is more:http://www.rubiconsystems.com/paul/dr5faq.htm
Posted on Jul 26, 2010
sparky1500
  • 1066 Answers
SOURCE: I have a Fender G-DEC Guitar amp and it has an
you can use the line in/mic stereo input, but you will have to turn the input level way down to around 1 or 2.
i assume that the record outputd a re rca outs. you can get a rca stereo to 1/8 inch stereo adapter, like the ones they use to connect protable cd palyers to recievers, and then get a 1/8 inch stereo to 1/4 inch stereo adapter form radio shack to complete the connection.
Posted on Nov 30, 2010
Boss DR-3 Dr. rhythm LED screen lights up by does not show any information. what can I do to fix problem?
take it appart. there is a conductive rubber between lcd pannel and the pcb use widow washer fluid without amonia to clean it
Jul 20, 2016 | Roland Boss Dr. Rhythm DR-3 Drum Machine
The ACMP function doesnt work when I play, even tho it says it is on in the display window
Check you have selected 'sync start'. The ACMP selection activates the automatic chords but not the rhythm, so each note produces a droning chord. Sync start activates the automatic chords and rhythm you have selected when you play anywhere near the bottom end of the keyboard. Alternatively you can manually press play to start the drums by themselves and then the chords will begin the moment to play with your left hand.
Mar 12, 2015 | Yamaha PSR-E413 Portable Keyboard
How do i adjust the drum rhythm volume so it is louder than the tone settings
You ay have to edit a rhythm and save it as a "user defined rhythm". During editing the volume of each part can be defined with vol. level ranging from 0-127.
Please read the manual.
Metronome volume can be easily changed by just holding the metronome button.
Mar 22, 2014 | Casio Privia Px330 Px-330 88 Key Digital...
Hi i have problems with my speakers on my pa 800 ,when i just play tones its clear but when i play the rhytms doesn't play right is not clear
Read your user manual about keyboard split. OFTEN the rhythms use the keys below F sharp for the chording of rhythm. When in this mode, you should restrict your melody to notes above F sharp that is to the left of middle C. If you play melody below this it will confuse the rhythm chording. You can likely change the split point of the keyboard, however, the F sharp split is the standard and I would suggest staying with it.
Dec 14, 2011 | Korg Pa800 Synthesizer
I need to know from which sites can I download rhythms & tones which is compatable fpor my casio keyboard ctk 810IN
You can play back standard MIDI files from the SD card slot, or load them into memory via USB. However, it is not possible to add new tones or rhythms.
Sep 26, 2011 | Casio Ctk 496 Electronic Keyboard with 61...
Hello, My Pa800 is few years old now has always worked perfectly. I recently combined few sets of rhythms together and loaded it there seemed to be no problem, few days later i was getting glitches in all...
The splicing of rhythms to play seamlessly would be tricky. Also you need to consider if you might be exceeding the number of generators available. If you are splicing external samples, that take great care and a lot of editing. Part of the problem is syncronizing the clocks of individual samples. It is hard to avoid glitches and changing mode of clock and quantizing will expose these glitches.
Sep 07, 2011 | Korg Pa800 Synthesizer
I have casio CTK 5000. i want to download additional tones and rhythms on it . kindly suggest the site as well as the file formats it will recognize for this model. also kindly describe the total procedure...
It is possible to load new rhythms and tones in the CTK-5000. But you need the stuff. That is what it really lacks. Casio needs the Rhythms and tones in its own formats.
May 15, 2011 | Casio CTK5000 (61Key Portable Keyboard)
Jun 28, 2010 | Boss Music
My Alesis Sr-16 will suddenly start playing without being being commanded and it will also stop playing during a performance.Is this common and can it be fixed?
These will USUALLY stop playing if in a song mode that runs so many cycles and terminates.
The random starts CAN be caused if you have a MIDI input cable connected and ANY device sends a rhythm start command or starts sending rhythm clocks to the unit. You can usually disable receiving commands via MIDI and SHOULD do this unless you are actually using MIDI.
Other things would be electrical transients that could trigger the device. MAKE SURE ALL of your equipment that this is connected to is power from the SAME electrical outlet to avoid ground loops which can also damage your equipment as well as cause intermittent operation.
Nov 09, 2009 | Alesis Sr 16 Stereo Drum Machine
Music Logo
Top The Music Experts
John mullen
Larry Stiles
Larry Stiles
D. E. Hev
Are you a The Music Expert? Answer questions, earn points and help others
