Question about Lexmark Office Equipment & Supplies
Left side of platen does not latch down IBM LEXMARK
  • 3594 Answers
SOURCE: Black line going down the left side of the copy
Copiers are full of mirrors and lensea any of withch could be dirty.
DickyO
Posted on Aug 17, 2009
  • 3594 Answers
SOURCE: left platen latch is broken.
If it's pinned knock the pin out, if it's welded grind the welds off there not to deep. If the latcl is cracked but not broken off you can fold up some paper and wedge it into the latch. there is a replacement gear with a set screw for 15.00.
DickyO
216-241-0027
Posted on Jun 20, 2011
intower18
  • 957 Answers
SOURCE: On IBM 6400 CTO platen
I have a link that can help you with your concern, I got you the operator's guide I thought this could help you.
Please click HERE so that you will get to the exact site.
Click HERE as well because this is the manual of your device for your future reference.
Hope those links would help you.
Thanks
Posted on Aug 02, 2011
intower18
  • 957 Answers
SOURCE: On IBM 6400 CTO platen motor over travel. On
Thanks
  • 125 Answers
SOURCE: IBM Lexmark typewriter carriage return won't return to left position
Hi:
Open the top cover and locate the shiny rod that the carrier moves back and forth across. Use some WD-40 on a rag to clean it well the apply a light coating of it to the entire shaft.
Posted on Jul 25, 2012
Left side of platen does not stay down on IBM Wheelwriter
The platen latch is broken, you can wire it down with some wire. or get a new platen.
That is if you push it down and pops back up.
Apr 16, 2017 | IBM Office Equipment & Supplies
Wheelwriter platen latch removal
Very vague question. the left side you have to drive the pin out.
right side just a clip.
If the platen wont stay down you can carefully wire it down so it doesnt interfere with the carrier is moved to the left.
Or buy a used platen.
Sep 12, 2015 | Lexmark Wheelwriter 6 Series II Typewriter
Bottom half of letter not printing clearly
First try pressing down firmly on both ends of the platen (black roller) if it snaps into place you're fixed if it doesn't stay the black plastic latch is cracked you'll need a platen or just a larch if it is just the R, side.
DickyO
Jan 09, 2015 | IBM Wheelwriter 1500 by Lexmark Electronic...
The platen won't stay in place so only the top half of the characters are showing
If the right platen latch is broken it can easily be replaced to lock down the platen. If the left one is damaged then you have to replace the entire platen as that is much more difficult to repair.
Apr 04, 2014 | IBM Personal Wheelwriter 2
Remove platen on IBM Wheelwriter 1000 by Lexmark
There are 2 black plastic latches one at each end of the platen squeeze them together and lift out platen.
DizkyO
Jan 13, 2014 | Lexmark Wheelwriter 3 Typewriter
How do you remove the platen from a Nakajima WPT-150 typewriter?
On the L. side there is a latch you press down, lift the left end and walk the R. end out.
DickyO
Nov 20, 2012 | IBM Wheelwriter 30 Typewriter
Maquina de escribir ibm WHEELWRITER 15 SERIES II "ESCRIBE SOLO LA MITAD DE LAS LETRAS, LA PARTE SUPERIOR"
Push down firmly on both ends of the platen it should snap into place. If the latch is broken the platen will need replaced.
DickyO
Sep 05, 2011 | Lexmark Wheelwriter 15 Series II...
I have an ibm personal wheelwriter. When typing on the right hand side of a page, the bottom part of the letter is not being typed. When typing on the left hand side, everything is OK.
The platen is not fully seated in the side frame. Press down firmly on the platen it should pop into place. Occasionally the black latches crack and the platen needs to be replaced.
DickyO
Sep 16, 2010 | IBM Office Equipment & Supplies
IBM Wheelwriter 6 prints only top portion of characters
The platen is probably not all the way in. Be sure the black latches are lined up with the side frames and press firmly down on the platen.
hope this helps
DickyO
Feb 25, 2008 | Lexmark Wheelwriter 3 Typewriter
IBM Wheelwriter 10 Series II
I assume you had the platen out and now it is not seated all the way in. Be sure the black latches are aligned with the side frames then push the platen FIRMLY down.
Oct 27, 2007 | Lexmark Wheelwriter 10 Series II...
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
