Question about IBM Office Equipment & Supplies
Left side of platen does not stay down on IBM Wheelwriter
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 130 Answers
The platen latch is broken, you can wire it down with some wire. or get a new platen.
That is if you push it down and pops back up.
Posted on Dec 03, 2017
  • 3594 Answers
SOURCE: IBM Wheelwriter 30 won't let us clear the left margin
If the carrier (print head) goes to the left when you turn the T/W on then try this.
Return to the L. margin, press mar rel key, backspace to the location that you want the margin, press L. mar key the wheel should spin and reset the margin.
DickyO
Posted on Oct 18, 2008
  • 3594 Answers
SOURCE: IBM Personal Wheelwriter 2 - machine comes on and is stuck
If the 1 &2 lights are flashing check the keyboard conectors and see my tip under WW1000.
DickyO
Posted on Dec 14, 2008
  • 3594 Answers
SOURCE: Need to remove the Platen to remove paper.
On each end of the platen there is a black plastic retainer squeeze them together and lift the platen out.
DickyO
Posted on Jun 30, 2009
  • 3594 Answers
SOURCE: Black line going down the left side of the copy
Copiers are full of mirrors and lensea any of withch could be dirty.
DickyO
Posted on Aug 17, 2009
  • 49 Answers
SOURCE: print head moves left and stays horrible noise
The problem is either something is interfering with the carrier movement OR the carrier homing sensor is broken/defective. First, turn off the power and manually move the carrier to the right side frame, check for foreign objects in the machine (pens, pushpins, paper clips etc.). Put some oil (10 weight) on a cloth and clean the chrome shaft that the carrier travels on.(by the rubber cogged belt). This is a common problem. If the sensor itself is the problem, take to a repair shop.(not common)
Posted on Nov 25, 2009
Wheelwriter platen latch removal
Very vague question. the left side you have to drive the pin out.
right side just a clip.
If the platen wont stay down you can carefully wire it down so it doesnt interfere with the carrier is moved to the left.
Or buy a used platen.
Sep 12, 2015 | Lexmark Wheelwriter 6 Series II Typewriter
Bottom half of letter not printing clearly
First try pressing down firmly on both ends of the platen (black roller) if it snaps into place you're fixed if it doesn't stay the black plastic latch is cracked you'll need a platen or just a larch if it is just the R, side.
DickyO
Jan 09, 2015 | IBM Wheelwriter 1500 by Lexmark Electronic...
The platen won't stay in place so only the top half of the characters are showing
If the right platen latch is broken it can easily be replaced to lock down the platen. If the left one is damaged then you have to replace the entire platen as that is much more difficult to repair.
Apr 04, 2014 | IBM Personal Wheelwriter 2
I have an ibm personal wheelwriter. When typing on the right hand side of a page, the bottom part of the letter is not being typed. When typing on the left hand side, everything is OK.
The platen is not fully seated in the side frame. Press down firmly on the platen it should pop into place. Occasionally the black latches crack and the platen needs to be replaced.
DickyO
Sep 16, 2010 | IBM Office Equipment & Supplies
I Have an IBM selectric system/2000 Wheelwriter 3
The platen probably worked itself out press firmly down on both ends of the platen it slould click into place. If it won't stay you will need a platen.
DickyO
Oct 23, 2009 | IBM Office Equipment & Supplies
ONLY TYPES TOP PART OF THE LETTER IBM WHEELWRITER 30 SERIES II
The most common problem is the platen (black roller) gets out of position. Be sure the black latches are aligned wuth the side frames then push down firmly on the ends of the platen it should snap into place.
DickyO
Aug 27, 2008 | IBM Wheelwriter 30 Typewriter
IBM Wheelwriter 30 series II - prints only half a letter
If it types only the top half yhe platen is probably not all the way in. Make sure the 2 black latches are lined up with the side frames then press down firmly on both sides of the platen.
DickyO
Apr 14, 2008 | IBM Wheelwriter 30 Typewriter
IBM Wheelwriter 6 prints only top portion of characters
The platen is probably not all the way in. Be sure the black latches are lined up with the side frames and press firmly down on the platen.
hope this helps
DickyO
Feb 25, 2008 | Lexmark Wheelwriter 3 Typewriter
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
jasbo
jasbo
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
