Question about Refrigerators
Frigidaire/refrigerator Freezer not cooling Can hear compressor click here n but only runs 3/4 seconds
  • 38 Answers
Hello
That's most likely the compressor overload
The start components are bad or the compressor is locked up take an amp draw then check the tag on the compressor it will give you the LRA rating
if you get lucky if it has a condenser fan motor check it
Thanks
Posted on Apr 17, 2017
refritech08
  • 149 Answers
SOURCE: Compressor Stopping
compressor is running overloaded possible problems bad relay/overload /capacitor dirty or clogged condensers if the unit uses a condenser fan suspect a bad fan. and defective thermostats are notorious for short cycling. id check the coils first and if dirty clean up maybe that can be the major problem.
Posted on Apr 23, 2008
  • 116 Answers
SOURCE: Sears Kenmore 53652300, doesn't cool
This usually indicates that the compressor is working too hard and drawing too much current. The click that you hear is a safety shut-off. Possible causes of this are numerous and usually require having a professional come in to fix the issue, it can range anywhere from a faulty compressor to a bad start relay.
There is in most cases a temporary fix, it is called a hard start relay/capacitor. It is usually available from an appliance parts retailer for around $15 to $20. Installation instructions are included, just be sure to unplug your refrigerator first and make sure that someone following you can repair from where you left off. This relay assembly can normally get you up and running but it should not be used as a permanent fix. This will not correct for a refrigerant leak in the system.
Check your refrigerator owners manual before making any repairs or modifications to your refrigerator, there may be an extended warranty on the sealed system and compressor.
Posted on Aug 01, 2008
rpbuice
  • 161 Answers
SOURCE: kenmore refrigerator compressor clicking
Relay on the compressor bad.
Try unpluging for 30 - 45 min until the compressor has cooled down then plug it back in. If it doesn't start replace the relay. Most service techs carry a universal relay and wiil put the relay on, if it starts, your good to go, if not, then the compressor is bad.
Posted on Dec 17, 2008
  • 1214 Answers
SOURCE: frigidaire refrigerator model FRT21LRGW5-compressor sound is loud
Sounds like the start relay or start capacitor has failed.
Unplug the unit until you can get a replacement or the compressor will be ruined (if it's not already.).
PTC start relay is P/N 218721108 $36.49
Capacitor is P/N 218909901 $7.99
P/N and pricing from Sears Parts.
Posted on Feb 01, 2009
farfield
  • 462 Answers
SOURCE: Problems with Frigidaire Refrigerator not cooling
In turning it off you may have only closed the air damper. Set it to 1/2 way.
If ice or frost in the air damper area on refrigerator side you may not be defrosting the freezer coil.
Inspect from bottom looking up with a mirror and flashlight. You should have no Ice buildup frost that is even and white is normal. Feel Check the back wall mid way down to 1/4 way to bottom. Push on the wall slightly. Crunching like frost or snow behind wall is not normal. I suspect non defrosting here.
Next eliminate the inside fan motor. It has to run to push air all over the freezer and refrigerator. If this fan doesn't run the results will be only the area with the refrigeration evaporator coil will cool and it may get too cold and resemble a non defrosting situation where the air is not able to circulate because of frost build up.
Next eliminate the Ice maker and light as a source of heat. Unscrew and unplug them
Next eliminate the door gaskets from not sealing. A piece of paper set tween the door and frame and pulled across it and you feel resistance all the way and the gaskets are smooth and not warped they are OK
Next inspect the condenser fan and coil by the compressor underneath. A dirty coil here will cause diminished heat removal and possible for a partial cooling of some of the freezer.
Only after inspecting all these items and determining they are OK should you proceed with refrigerant checking. Also a person with out the ability to measure the actual amount of refrigerant being put in should be shown the door. Even with topping off (adding some) refrigerant I use a scale to determine that I do not put in too much. So if you have a friend that does this and no way to tell how much is too much.... well with all due respect your getting what you pay for.
If this helps you understand your problem and need more information please post back, I will follow up. If it helped you determine your trouble please rate me as high as you can. Thank You for using fixya and good luck.
Posted on Mar 22, 2009
I have a Frigidaire freezer chest. model number: mfc13m4fw3. It will click on for ten seconds and click off. I don't understand whats wrong. It wont stay on. Thank you
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jun 29, 2011 | Frigidaire Freezers
GE TFF24RC- Has lost its cool, will not re-cool, hear compressor kick on, but after 2-3 seconds it kicks off, and repeats about every 3-4 minutes. I am thinking it is shot, but there is always some slim...
heatman101
May 07, 2011 | Refrigerators
My compressor runs for 3 seconds - then shuts down for 3 minutes - then runs for 3 seconds
heatman101
Mar 21, 2011 | Thetford Norcold® Model DE0061
The compressor is working for 15 second and stop.
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Mar 13, 2011 | Frigidaire FRS3R5EMB Side by Side...
FRIDGE AND FREEZER DO NOT COOL. FAN AND COMPRESSOR ARE RUNNING AND AIR IS FLOWING THREW THE VENTS BUT A WIERD NOISE APPEARS EVERY 2-3 MINUTES LIKE THE COMPRESSOR WANTS TO START BUT IS RUNNING STILL. ...
1. is light on in side when you open the door. If not check breakers or fuses.
2. Can you hear the compressor running. If not do you hear any clicking sounds.
3. If you hear clicking sounds, try putting a fan on compressor and unplug refrigerator.
4. Wait one hour.
5. plug back in. If compressor starts let it run and see if it cools, if it doesnt, call service man.
6. If it goes back to clicking, call a service man.
also are the coils clean?
Feb 26, 2011 | Maytag MBB1956GES Bottom Freezer...
MSD2454GRW. Clicking noise for about 10 seconds then shuts off. Freezer is thawing. Fridge "appears" to be cooling fine...not sure. Help...don't have the $$ to hire someone.
4. Wait one hour.
try this and let me know if it helps.
Feb 22, 2011 | Maytag MSD2454G Side by Side Refrigerator
My Frigidaire FRS22ZRG freezer is working fine, but the refrigerator has been abnormally hot all night long.
4. Wait one hour.
try this and see if anything happens and let me know.
Feb 22, 2011 | Refrigerators
Compressor turns on and back off in 2 seconds.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
heatman101
Nov 27, 2010 | Frigidaire FRS-26DR7D Side by Side...
Loud click,compressor starts, immediately stops. Then a click ,fridge light dims for a couple of seconds. compressor starts and continues to run. Fridge cooling ok.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Aug 30, 2010 | Frigidaire FRT17G4B Top Freezer...
Frigidaire does not work (freezer and cool area)
what can u hear. u should hear fan in freezer. fan in back. is compressor running. is ice in freezer on back wall. are both sides not cooling. post more info to go by
Jul 02, 2008 | Frigidaire FRS26RLECS Side by Side...
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
