Question about Garden
Tractor battery doesnt stay charged when tractor isnt running
  • 100 Answers
Sounds like the battery is at the end of it's life...
You could use a trickle charger that stay permanently on the battery whenever you aren't using the machine.. useful things to have...
Posted on Apr 17, 2017
I have a 1976 ford tractor battery want stay charged when tractor is not running it is a ford 2000
Take a look at this, click on the link. Hope it works. I found this url.
I was going to tell you to check your charging system and make sure battery is good. Check all wiring circuits. My experience with tractors is limited.
Apr 16, 2017 | Ford Cars & Trucks
I have a sst16 and the battery will not stay charged any suggestions as to what the problem could be. I can not find the fuses is there a diagram
battery will not stay charged Deloris, Have battery tested could be bad (lucky to get 2 seasons out of one). You have to see if charging when running with a digital volt meter. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to test small engine charging system battery alternator
Repairing the Charging System on John Deere 175 Lawn Tractor
Electrical System Troubleshooting for Lawn Tractors Mowers
Apr 03, 2016 | John Deere Garden
Mower isnt firing at all. wont turn over doesnt click NOTHING>
set brake and lock sit on seat and try again. charge the battery or try jumper box/cables .
Apr 12, 2015 | Garden
Battery will not stay charged.
Will the battery stay charged with one terminal disconnected?
if yes the you have a wiring problem. If no get a new battery.
What is the battery voltage when mover is running?
12.6v = not charging while running
13.7v = good charging
Oct 23, 2013 | Garden
John Deere 4100 compact tractor will not keep a charge. Has a magnet alternator,new battery ,and new voltage regulator. If you external charge battery, will start & run till useup charge. Then tractor...
If you hold a wrench against the back of most alternators when it's running the wrench should be attracted to the alternator which would indicate that its charging. If it isnt' charging then the regulator inside the alternator is burnt (typically) if it is charging then check the wires to & from the alternator.
Nov 24, 2017 | Cell Phones
Battery isnt getting charged by the mower. and it runs dead. I jump it, and start it and the PTO will engage for a bit, but as the battery runs dead, PTO isnt getting appropriate voltage. What charges...
40b7c2b.jpgTry to always list the model number. Something like 917289472 would be the model number. Here is a wiring diagram for that model. Note the test voltages with unit running. Check the wiring from the regulator to the ignition switch and from the switch to the battery. It is possible for the ignition switch to be bad and keep it from charging. Test at these terminals with voltage tester. You should have more than 12 V at the regulator( diagram says 9-16 volts). If you need the manual you can go to and download diagram. Enter YOUR model number. Good luck!
Oct 19, 2010 | Craftsman GT 5000 26 HP54" Garden Tractor...
Mower doesnt charge battery. does stay running after charge from charger what goes bad to have this happen
Check and clean all of your connections at your solenoid back to "shiney and bright". That sounds like the problem.
Best regards, --W/D--
Aug 21, 2009 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
My 2n tractor only puts out 3-4 charging. The
The 12 v conversion is the way to go. 6 v is a pain. It's getting harder and harder to get parts, and running off of battery power leaves a lot to be desired, especially if you've ever had to haul a dead battery back to the barn. I had a Farmall model "B", 1947, 6 volts. 12 volts was like a whole different tractor. Just my humble opinion!
Aug 18, 2009 | Ford 2n, 9n, 8n Tractor Left Taillight...
,when pull the knob to engage blades it doesnt work or they don't
When the tractor has not been run for a hour or so use a meter and check the battery voltage. Then start the machine and check the battery voltage. The voltage should be higher when running. Normally 12.5 to 14vdc. Any higher then your voltage regulator in not working and your cooking your battery. Lower and the charging system is not working. If it has a dedicated alternator then it or it's voltage regulator is bad. Usually the voltage regulator is built in to the alternator and can't be changed by itself. Check your parts manual if one is listed by itself.
Mar 31, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
