Question about Garden
When tractor is not running battery doesnt stay charged
5 Suggested Answers
  • 218 Answers
SOURCE: battery wont stay charged
Hi..my name is Keith..you can take the battery to like an AutoZone or AdvanceAuto..and they will test the battery for free..it sounds like it has a bad cell in it..also i would look at the battery cable connections to see if they are corroded and make sure the ground wire has a clean connection to the frame..if this didnt help..please write me back
Posted on Jul 01, 2009
woobie dog
  • 1273 Answers
SOURCE: My 2n tractor only puts out 3-4 charging. The
The 12 v conversion is the way to go. 6 v is a pain. It's getting harder and harder to get parts, and running off of battery power leaves a lot to be desired, especially if you've ever had to haul a dead battery back to the barn. I had a Farmall model "B", 1947, 6 volts. 12 volts was like a whole different tractor. Just my humble opinion!
Best regards, --W/D--
Posted on Aug 18, 2009
woobie dog
  • 1273 Answers
SOURCE: mower doesnt charge battery
Check and clean all of your connections at your solenoid back to "shiney and bright". That sounds like the problem.
Posted on Aug 21, 2009
  • 15 Answers
SOURCE: i bought this tractor new last year but it will
Did you leave any old fuel in it during the winter?
Posted on Apr 19, 2010
I have a 1976 ford tractor battery want stay charged when tractor is not running it is a ford 2000
https://youtu.be/35xEyu7dsL8
Take a look at this, click on the link. Hope it works. I found this url.
I was going to tell you to check your charging system and make sure battery is good. Check all wiring circuits. My experience with tractors is limited.
Apr 16, 2017 | Ford Cars & Trucks
Tractor battery doesnt stay charged when tractor isnt running
Sounds like the battery is at the end of it's life...
You could use a trickle charger that stay permanently on the battery whenever you aren't using the machine.. useful things to have...
Apr 16, 2017 | Garden
I have a sst16 and the battery will not stay charged any suggestions as to what the problem could be. I can not find the fuses is there a diagram
battery will not stay charged Deloris, Have battery tested could be bad (lucky to get 2 seasons out of one). You have to see if charging when running with a digital volt meter. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to test small engine charging system battery alternator
Repairing the Charging System on John Deere 175 Lawn Tractor
Electrical System Troubleshooting for Lawn Tractors Mowers
Apr 03, 2016 | John Deere Garden
Why does battery light stay on?
Can be a number of things from dirty connections at battery terminals, bad battery, low RPM when operating, bad alternator or rectifier. Try charging battery first and try it for a cut of two if possible. If you can test the battery voltage when running it should be 13-14 volts. Hope this helps. Brad
Aug 17, 2014 | Toro Garden
Battery will not stay charged.
Will the battery stay charged with one terminal disconnected?
if yes the you have a wiring problem. If no get a new battery.
What is the battery voltage when mover is running?
12.6v = not charging while running
13.7v = good charging
Oct 23, 2013 | Garden
Battery not charging
Looks like the battery is wasted. I'd have it replace it. A new battery should keep charged for longer period of time.
Jun 19, 2012 | John Deere Garden
Mower doesnt charge battery. does stay running after charge from charger what goes bad to have this happen
Aug 21, 2009 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
Aug 18, 2009 | Ford 2n, 9n, 8n Tractor Left Taillight...
,when pull the knob to engage blades it doesnt work or they don't
When the tractor has not been run for a hour or so use a meter and check the battery voltage. Then start the machine and check the battery voltage. The voltage should be higher when running. Normally 12.5 to 14vdc. Any higher then your voltage regulator in not working and your cooking your battery. Lower and the charging system is not working. If it has a dedicated alternator then it or it's voltage regulator is bad. Usually the voltage regulator is built in to the alternator and can't be changed by itself. Check your parts manual if one is listed by itself.
Mar 31, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Craftsman mower 917 273201
Check the seat switch for the running problem. Disconnect the switch and jump the harness with a piece of wire, and see if the tractor stays running. If so, then the switch is bad. As for the charging problem. Test the voltage regulator. Start the tractor and put a volt meter across the battery. Red to red and black to black. Run the RPM to full throttle. You should have a reading of 14 to 14.5 volts. If not, the regulator is bad. Hope this helps.
Sep 21, 2008 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
