Question about Tablets & eReaders
How can i move pictures from mysa,song tablet to stoage card
How to down load films to a 32 GB card Hudle2.Thanks
OK, to accomplish this you need 2 hings:
1. A micro sd card. (Which I gather you already have one)
2. File manager installed in your tablet.
Now, if the tablet support micro sd card, you are all set. Download the file manager, it could be Astro, ES File Explorer, etc...
Once installed, open the file manager. The tablet storage, which is known as internal storage, it is display as sdcard/storage (or sometimes as internal storage). Once you tap the internal storage, everything that is installed in your tablet will be display; (Android, DCIM, etc...) Now you need to look where are the pictures or films saved at. It is usually DCIM/Camera. Once you have found the pictures that you want to move or copy, long tap the films, depending on the file manager app, you must tap copy or move (NOTE: Since every file manager is different, some takes a little bit of extra steps, others requires for you to open a menu). Once you had chose to copy or to move it, look for the external sd card location, which will also be located at sd card/storage/ (32gb external storage) and choose this location to paste your films or pictures.
Another way is by using a computer. Make sure that you have all the drivers needed for the computer to recognize your tablet, you also need the usb charge cable. Once the computer recognize it when the tablet is plug in to the computer, open it by double clicking, there should be 2 storage display under the tablet folder: Internal storage and 32gb. external storage. Open the internal storage, look for where the films are saved (just like I explained with the file manager), choose the films that are to be move or copy, and jus drag and drop or press ctrl and C to copy, go to the external storage, open it and press ctrl and V to paste.
Jul 10, 2016 | Tablets & eReaders
Can't download games error window says not enough storage. Bought 16 mg memory card not working
Probably you get the error because, by default, all downloads go to the internal storage, not the memory card. Make some room on your device by moving pictures, videos, songs to the memory card. You can also move some applications to the memory card using the Application Manager feature of any Android device.
Mar 19, 2015 | Nextbook Premium 8 Se Android
How to fix error downloading insufficient space on device but I have a 8gb microsd card with lots of room and nothing will download please help this is my second next book tablet I just want to fix th
Amber,
I think your problem may be due to it downloading into the internal memory of the tablet. There may be a way of moving the apps into the external micro sd card rather than deleting them.
From http://www.tomsguide.com/forum/id-2055729/set-downloaded-games-google-play-directly-external-card-samsung-galaxy-tab.html
" Go into settings, then to storage, then to used space, then to applications. In applications manager go to sd card there will be a list of your applicationsicon1.png, touch/click on each one individually and within each one that can be moved, is a box "move to sd card" touch that box and wala it is moved! To move pictures I reset the cameras auto storage to the sd card then moved all my other pictures to the camera file which then stored them on the sd card. I then deleted the pictures from the system memory. Hope this helps! "
Jan 24, 2015 | Tablets & eReaders
I broght a new sdcard and my tablet is still saying insufficient space....What do i do to get some more space..
Download and install a utility app that cleans the tablet's internal storage. You can also move your music/video/pictures/audiobooks/ebooks, even some apps from the tablet's internal storage to the SD card.
Jan 18, 2015 | Tablets & eReaders
How do I store downloads to sd card
Under SETTINGS. APPLICATIONS. MOVE TO SDCARD.
Each App may also allow you to choose where it stores it's data.
Nov 05, 2014 | XO Vision Ematic eGlide 7Inch Touch Screen...
I cant download any apps says insufficient storage but have an sd card that's empty
You can try moving some of the apps to the SD card. If an app cannot be moved, you will get a warning message. Also, if you have any videos, songs or photos on the tablet move them from the internal storage to the SD card.
Sep 03, 2014 | Nextbook Tablets & eReaders
Instructions manuals
pictures should already be loaded to SD card... if not, you probably need to format SD card and then try again. I've had issues with SD cards going from laptop to Tab 3 but my pics taken with my camera always load to SD card. Now pictures I have downloaded from the internet I can open up in my Gallery, tap the picture and then hit settings and move to SD card
Dec 19, 2013 | Samsung Galaxy Tab 2
Tablets & eReaders Logo
26 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
