Mine is cast iron
SOURCE: need help to reinstall the under mower 42'' unit that out
I have that manual. If you want, give me a postal address and I'll mail you a copy. Mac
SOURCE: grease fittings
You can drive the front tires up on a set of tire ramps and grease the front and then drive the rear tires up on the ramps and grease the rear.
OR just lay on the floor and reach under using a grease gun with a flexible delivery hose.
If you do use a jack just be sure to jack on the frame of the tractor as opposed to any sheet metal.
SOURCE: what engines will fit craftsman dyt 4000 (18.5 blew w/ 290 hours)
Hi there
The only thing you have to do is have the size (diameter) and lenght (from cranckcase to end of shaft) of the shaft you have on your b&s and just go to your local Honda dealer , give them your shaft size and they should be able to give you all the options for a brand new motor . I really believe you can get a Honda 20hp model GXV620 or a 24hp model GXV670 that will replace your B & S motor .
Hope this help .
SOURCE: Instructions for fixing the choke on a Craftsman LT-1000 lawn tra
I have been hearing alot of this problem. Well it is gravity flow. I just bought a 2002 lt1000 17 hp without a carb the guy was having the same problem so he sent the carb away to get checked out and low and behold it got lost. He waited the summer to see if it would show up but it did not. He got mad and bought a new bigger one. Any ways i am waiting on a new one. Now in my reading these problems i discovered that the fuel line coming out of the tank to the carb is lower. Might be somthing to look at. JIM
