Question about Health & Beauty
Pronto m51 drive. is output shaft belt driven
  • 40 Answers
SOURCE: How do I charge My Pronto M51 motorized wheelchair?
Margie,   Yes you may charge it overnight. If you use it everyday,charge it every night. Once the charger senses 24 volts it stops sending a charge,so they cannot be overcharged.  I suggest when you go to bed put on the charger and unplug it when you get up in the morning.
Posted on Mar 29, 2009
SOURCE: pronto M51 ...the yellow light is blinks and dosen't stop
Take your drive units both out of gear and put them back in that will reset the computer and it started mine working again.
Posted on May 26, 2009
  • 175 Answers
SOURCE: won't move pronto m51
Three lights flashing on your chair indicate a left motor fault. Make sure that all of the connections inside the shroud are tight by physically testing them. If all of the connections are good, and the fuses are good, then it's time for a trip to an authorized repair facility. Here is a link to the M51 owners manual if you haven't one. Page 24 has the fault code guide.
The controller monitors all of the functions on the chair, brakes, motors, joystick, charger etc. The three flash fault indicates an "open" circuit. Open, like a switch or blown fuse is open, or a wire is cut or burned in half, or a connector is unconnected, or partially connected. The latter is what you are hoping for. Wires burned in half is the usual cause for a motor fault, and with powerchairs, is usually the result of the chair getting stuck in or against something it can't get out of and the operator over-amping the motors. Motors do, just go bad sometimes, for no reason. Very rarerly, however.
You can also check the brushes on the motor too. There's two quarter-sized black plastic screw-plugs on the ends of the motor opposite each other. Unscrew them and examine the brushes. The springy coils should be springy. Overheating can cause them to be brittle, or even burned in two. Check the lench of the brush, the dark rectangular cube at the end of the springs. It should be curved and polished at the end, and a little over a half-inch long. If it is near a 1/4 inch, it needs replaced, or if there is any evidence of overheating, replace. Good luck.
Posted on Jul 09, 2009
  • 29 Answers
SOURCE: Circuit Breaker on Pronto m51
Here's the manual. Locate battery cables follow them to the motor and Joystick. you'll see the reset button
Posted on Sep 02, 2009
SOURCE: tool; light blinks 9 times battery is charged
the batteries were dead
Posted on Sep 07, 2009
How do I troubleshoot m51 pronto scooter. When I plug it in there is no lite and of course it does not run
  1. Pronto M51 Troubleshooting‎‎1000's Solutions
  2. Troubleshooting Tips
  3. Free Diagrams
  4. Free User Guides
Service Indicator Light Diagnostics - Invacare Pronto M51 ... > ... > Pronto M51 > Maintenance manual
Invacare Pronto M51 Base Manual Online: Service Indicator Light Diagnostics. ... Invacare power wheelchair owner's operator and maintenance manual.
Dec 25, 2015 | Health & Beauty
How many batteries does a pronto electric wheelchair use
The Pronto M51 takes two batteries. It takes what is called a U1 size battery.
May 26, 2014 | Invacare Pronto M51 Power Wheelchair
Reset button on pronto m51
There is no reset button on a M51 chair. Invacare puts fuses in the battery harnesses. The manual may say there is a reset but trust me there is not.
May 20, 2014 | Invacare Pronto M51 Power Wheelchair
Pronto M51 feels forced when driving it.
The squealing noise is probably a bearing either in one of the four smaller tires called casters. The problem will not likely cause a break down right away but should be checked by someone mechanically inclined or trained in power wheelchairs. I don't know what you mean by the chair being "forced". Need more info.
May have something to do with batteries.
If the chair is driving slower and batteries are new their is a recall for that joystick from Invacare. Invacare is replacing joysticks for free.
Dec 15, 2013 | Invacare Pronto M51 Power Wheelchair
Pronto M51 Wheelchair doesn't have as much power as it used to. Batteries are good.
Have you had the batteries load tested? How do you know the batteries are good?
Apr 21, 2013 | Invacare Pronto M51 Power Wheelchair
Manual for Pronto M51 wheelchair
Hi. We can supply, but try your local Invacare dealer. If you have luck, send us an email,
May 18, 2010 | Invacare Supply Group Invacare Pronto M51...
If you chair was down for a long time before getting new batteries the tires could have developed flat spots on them. Also could have brush problems in the motors that make the motors run jerky from sitting too long.
May 02, 2010 | Invacare Supply Group Invacare Pronto M51...
Health & Beauty Logo
Top Health & Beauty Experts
Robin Hill
Robin Hill
Are you a Health and Beauty Expert? Answer questions, earn points and help others
