I put in ms card but it is not work - Computers & Internet
Graphics card for MS-7050 HP dx5150 MT
hi, it looks like that board has a PCIE slot so you can get a card that is pcie and not vga- cards are made with different connectors but they are all the same graphics chips on them
Apr 01, 2014 | Computers & Internet
How to transfer MS WORD/MS EXCEL/POWPOINT/PDF files from my computer to NOKIA N97?
they have to option to transer your ms word files to your nokia n97
1st you need a bluetoot device then coonect to your pc then if you see the blue tooth just click your item you want to send to your phone right click it then send via blue tooth then they search for devices make sure that your phone bluetoot is open 2nd you need a card reader and take it off your memory card out then put it to your computer then copy your files then go to my computer then you see your memory card then paste it there.. :)
hope it will works on you :)
Jul 18, 2011 | Nokia N97 Cell Phone
I just bought a Dell laptop, how do I download my pictures from my Sony camera? I am not a computer buff. Hope you can help me.
Hi, your sony camera should have a software bundle that came with it as well as a cable which should easlily allow you to hook up your camera and download/view/edit/store your photos on your computer, depends on the software user interface and how it looks you may find it easy but if not there is another method: your computer may have a memory card reader port, it should read SD/MMC/XD and in your case you need it to read MS or MS Pro... The MS and MS Pro are the types of memory cards used by sony, all you need to do is take the card off the camera and put it into the reader in your computer, few seconds and a pop up will come that will allow you to copy your pictures and browse/explore what is on the card... if your computer does not have the reader, pick up one at your local RadioShack, BestBuy or Walmart or any other electronics store... just be sure to pick up one compatable with your card (MS or MS pro) the reader can be put into your computer USB and will work without drivers... Should be under $10.... Best of Luck
Jan 29, 2011 | Sony Computers & Internet
How do I find out what video cards are compatible with my MSI MS-6788 motherboard?
MSI MS-6788 motherboar support Video Card interface AGP 8x. Find any video card which work on that interface!
Mar 14, 2010 | MSI 848P Neo-V (MS-6788-040) Pentium 4...
This camcorder does not record video; it won't format memory card
do you get any kind of error code?what type of memory stick are you using?how big is the ms capacity?may need to try using a diff ms or try using ms with diff devices.if diff ms works fine.may need to format ms using computer first (using card reader if available) and camcorder last.may need to reset camcorder (make sure cam is on when you press the reset button.hope this works.thanks :)
Mar 12, 2010 | Sony Handycam HDR-CX12 Flash Media...
I have a 4700 with a creative x-fi card. The
you need to either
1. uninstall the MS patches.
2. locate the patch which is causing the issue ( you can use, selective login for this)
3. or you can put latest patch from Dell/creative for the creative sound card
Sep 09, 2009 | Dell Dimension 4700 PC Desktop
I have a similar problem
Maybe the MS Stick have a corruped data :
- Try to format your MS
I have a 8GB MS i have the same probleme then you !!!
Jul 05, 2009 | SanDisk 4GB microSD High Capacity Memory...
Minolta g400 : error format on ms card !
Try this one:
Jan 17, 2009 | Konica Minolta DiMAGE G400 Digital Camera
Unable to upload pictures from memory card to computer
Most laptops that have a memory card reader will only read these types of cards, without needing an adaptor: -SD card -MMC card -Sony Memory Stick or Memory Stick Pro cards -XD cards
However, you have a MS Pro Duo card, although it fits into the card reader slot, the card is a lot thinner than what's expected, so the laptop won't be able to read it.
You need to put the Pro Duo card into the stanard size MS Pro caard adaptor. See attached image.
Hope this helps.
Jan 10, 2009 | Sony Cyber-shot DSC-W70 Digital Camera
I need to install a network card for my IBM MS-6188
have you tried with a different network card? if no try with a different card. if it does not recognise it go to control panel and to add new hardware. follow the on screen procedure and see if it will see it.
If problem still persists, try doing a clean copy of OS
Sep 29, 2008 | IBM MSI MS-6188 (49P3492) Motherboard
Computers & Internet Logo
52 people viewed this question
David Payne
David Payne
