Question about Garden
Will the engine of my my ride on lawn mower get damaged if I disconnect the battery once it's going
  • Garden Master
  • 10,073 Answers
The battery charging module may burn up since the voltage will go way high.
Posted on Apr 17, 2017
Will it damage my ride on lawn mower if I disconnect the battery once it's going
no just no accessories or charging will happen if its a simple ride on which is not like an auto where alternator --or electronics can be damaged
Apr 16, 2017 | Garden
Why isn't something engaging when accelerator pressed?
It would help to know more information about the mower in question. Walk behind push mower? walk behind self-propelled mower/ Riding lawn mower? Lawn tractor? Or goat...just The engine horse -power or cc's and make of the mower and engine. Anything happen before the problem or was it straight out of storage. Does the gas pedal feel normal? Could you be talking about the forward/ reverse pedal? These types don't engage by depressing them, they engage by releasing the pedal.
I'm going to guess you have a riding lawn mower or lawn tractor. The pedal for those types of mowers controls the transaxle ( rear wheels, transmission and differential basically). If the pedal move properly and it was working ok when it was stored, then check to see if you can push it with little effort. On most transaxles there is a disconnect rod to disengage the transaxle for towing the mower without damaging it. Pulled out for disengaged and in for engage. If that all checks out it could be very low on transmission fluid or the drive belt might be off or broken depending on which type you have. If it is low on fluid, you have a leak. Hope this helps.
Mar 11, 2016 | Garden
Solenoid clicks but starter does not kick in to start tractor
Clicking Sound While Attempting to Key Start - Riding Mower
Jul 19, 2002 - Why does the tractor make a clicking sound and not start? ... Thesolenoid connects the battery to the starter motor when the solenoid is energized. ...It can click, but not make a complete connection. ... Starting - Riding Mower · Professional Shop Manuals · Basic Troubleshooting - Lawn & Garden Tractors.
How Do I Tell If the Starter Solenoid Is Bad on My Kohler ... > Real Estate Advice > Basic Real Estate Advice
Most large Kohler engines on riding lawn mowers use an electric starting system. ... A bad solenoid can deny electricity to the starter motor and prevent engine startup. ...Lawn Mower Will Fire but Not Start · Replacing a Solenoid on a Craftsman Lawn Mower or Tractor · How Does a Starter Solenoid on a Lawn Mower Work?
My Bolens lawn tractor won't start. It just clicks when I turn ...
Dec 03, 2015 | Garden
INstalled new battery on Craftsman Riding mower. Now the motor wont start or even turn over.
You may have shorted out one of the wires going into the battery, blowing a fuse, or damaging the starter or the starter solenoid.
Mar 30, 2013 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
Engine clicks but will not start. battery is fully charged.
Check for corroded terminals between the battery and starter, including at the start switch, Disconnect the battery and follow the wires, making sure that each terminal and connector is shiny and bright, Clean terminals with a fine sandpaper or emery board. Re-connect the battery and try. Please re-post if this problem persists.
Best regards,
Jan 17, 2011 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
Have crafstman riding lawn mower: replaced battery, ignition switch, solenoid, and spark plug but it still will not crank and start up. what is the problem?
double check the ground wire going from the battery terminal to the is usually on a mount bolt at the engine...if the mount bolt is loose, it's a poor connection...
Apr 25, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
Lawn mower stays running on jumper cables but once disconnected it shuts down when choke is engaged
if it is already running and you "engage" the choke, you will flood the engine with too much gas and it will sputter and die. the only time you engage the choke is to start the engine when it is cold. if the mower dies when you remove jumper cables, and you leave the choke alone, you need to have someone look at your charging system.
Apr 08, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Husqvarna riding lawn mower will only click once but not turn over when key is turned on. Replaced battery but no help. What are some possible solutions
If you have a pair of jumper cables, connect one of the red clamps to the battery positive, then using the remaining clamp, touch the post on the starter and see if the starter turns over the engine.
Make sure the key is turned off and the transmission is in neutral.
Let me know if it turns over and we can go from there.
May 14, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Garden Logo
27 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
