Question about Garden
Will it damage my ride on lawn mower if I disconnect the battery once it's going
    Top Expert:
  • Garden Master
  • 12,744 Answers
No just no accessories or charging will happen if its a simple ride on which is not like an auto where alternator --or electronics can be damaged
Posted on Apr 16, 2017
Will the engine of my my ride on lawn mower get damaged if I disconnect the battery once it's going
The battery charging module may burn up since the voltage will go way high.
Apr 16, 2017 | Garden
Why isn't something engaging when accelerator pressed?
It would help to know more information about the mower in question. Walk behind push mower? walk behind self-propelled mower/ Riding lawn mower? Lawn tractor? Or goat...just kidding...lol. The engine horse -power or cc's and make of the mower and engine. Anything happen before the problem or was it straight out of storage. Does the gas pedal feel normal? Could you be talking about the forward/ reverse pedal? These types don't engage by depressing them, they engage by releasing the pedal.
I'm going to guess you have a riding lawn mower or lawn tractor. The pedal for those types of mowers controls the transaxle ( rear wheels, transmission and differential basically). If the pedal move properly and it was working ok when it was stored, then check to see if you can push it with little effort. On most transaxles there is a disconnect rod to disengage the transaxle for towing the mower without damaging it. Pulled out for disengaged and in for engage. If that all checks out it could be very low on transmission fluid or the drive belt might be off or broken depending on which type you have. If it is low on fluid, you have a leak. Hope this helps.
Mar 11, 2016 | Garden
I have a John deere 260 riding lawn mower and the battery doesn't charge and when I disconnect thebabattery it dies
Check the charging stator usually under the fly wheel. Check wiring first before condemning the unit.
Aug 22, 2013 | John Deere Garden
INstalled new battery on Craftsman Riding mower. Now the motor wont start or even turn over.
You may have shorted out one of the wires going into the battery, blowing a fuse, or damaging the starter or the starter solenoid.
Mar 30, 2013 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
My Craftsman 16 hp and 42 battery not charging is it normal?
get mower started and check the charging voltage at battery. it should be at least 13.5 at battery.check cables to battery and the inline charging fuse, its located somewhere in charging system.if its charging, but battery is still dead. it could be a bad battery. or alternator. . Examine the lawn mower electrical system by starting the lawn mower up, and then removing the battery. If the lawn mower turns off after the battery is disconnected, the lawn mower electrical system is the culprit.
its a good possibility that the battery is bad if it has been in use for 4-5 years.
check the fuses first. good-day !
Oct 02, 2011 | Garden
When first start my husqvarna yth 150 runs fine goes up hills plenty of power after running for while starts loosing power wont go up hills will stll move on flat surface
Hi, it sounds like the hydrostatic drive is getting too hot. Remove the battery and battery cradle and clean all grass and debris from around the hydrostatic drive and cooling fins. Also check the fan wheel on the hydro is not damaged. Regards Phil.
Apr 28, 2011 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
Blades wont engage
check the clutch if it engage then check the cable and belt to if it works make sure all the bolts are tight. usually the belts is too loose or if its a clutch drive maybe the clutch doesn't engage or worn out.
Aug 16, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Husqvarna riding lawn mower will only click once but not turn over when key is turned on. Replaced battery but no help. What are some possible solutions
If you have a pair of jumper cables, connect one of the red clamps to the battery positive, then using the remaining clamp, touch the post on the starter and see if the starter turns over the engine.
Make sure the key is turned off and the transmission is in neutral.
Let me know if it turns over and we can go from there.
Regards,
May 14, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Garden Logo
26 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
