Question about The Computers & Internet
Directory path where the photoshop 7.0 located
    Habit-Forming:
    New Friend:
  • 93 Answers
C:\Program Files\Adobe\Photoshop 7.0
I’m happy to help further over the phone at https://www.6ya.com/expert/adrienne_b03fb46fc6334991
Posted on Apr 22, 2017
Photoshop file info data cannot be read. How to fix it?
hi,
when you have your document opened, look every layer to find little yellow triangle(s), witch means that there is a problem with this(those) layer(s), it can be (more often) the text layers that have fonts that you don't have installed, or a reference file that has been moved from original path.
hope you'll solve that !
cheers
mich
May 07, 2015 | Adobe Photoshop 7.0 for PC
Sorry javac is not recognize as internal or external command , operation program or batch file-- how can i solve that?? pls help me and where can i install j2sdk_18 lezarasileger@yahoo.com--facebook...
If you are getting that error, it means that eitherJava is not installed, or is not in your path.
If Java is not installed, go to http://www.java.com to install the most recent version of the JRE.
If you're sure you have already installed Java ensure the Java executable is in your system's path. You can do this by first finding the directory it is installed in. For example, mine is installed in C:Program FilesJavajre6. The executables are located in the bin directory.
In order to set your path (Assuming Windows Vista), go to Start -> Control Panel -> System, then click on the 'Advanced System Settings' link on the left, then the 'Environment Variables' button. In the lower section (Labeled 'System Variables'), scroll through and find the item labeled 'Path' and double click it. In the field labeled 'Variable value' go to the end and add a semicolon (;), and then the path your installation of Java is located. Using the example I gave above, I would have added ;C:Program FilesJavajre6in to the end of the line.
The procedure for 64-bit Windows Vista or Windows 7 is the same, except the text you will add to the Path variable is ";C:Program Files (x86)Javajre6in". Notice there is still a semi-colon at the beginning of the line.
Once you have done this, you will need to close and reopen the command prompt if it is already open, and you should be able to run java without getting this error message.
Jun 30, 2011 | Computers & Internet
The message light on the MD110 is not working. I think I pressed something that disabled it. How to I get it back on?
detail_no-screenshot.gif Erlang R11B
Erlang is a full-featured programming language developed at the Ericsson CS Laboratory. more>> Erlang is a programming language designed at the Ericsson Computer Science Laboratory.
Open-source Erlang is being released to help encourage the spread of Erlang outside Ericsson.
Installation
When installed, the entire system, except for a small start-up script, resides in a single directory tree. The location of this directory tree can be chosen arbitrarily by the installer, and it does not need to be in the users $PATH.
The only requirements are that the file system where it is placed has enough free space, and that the users who run Erlang/OTP have read access to it. In the example below, the directory tree is assumed to be located at /usr/local/erlang, which is here called the top-level directory.
It is assumed that you have the compressed tar file, the name of which is < PREFIX >.tar.gz, where < PREFIX > is a string denoting the particular Erlang/OTP release, e.g. otp_LXA_11930_sunos5_R9B.
Wherever the string < PREFIX > is used below, it should be replaced by the actual name prefix of the compressed tar file.
The tape archive file does not have one single directory in which all other files are rooted. Therefore the tape archive file must be extracted into an empty (newly created) directory.
1. If the top-level directory does not already exist, create it:
mkdir /usr/local/erlang
2. Change the current directory to the top level directory:
cd /usr/local/erlang
3. Create the installation directory with an appropriate name. For example:
mkdir otp_r7b
4. Change to the installation directory, e.g.
cd otp_r7b
5. Assuming the compressed tar file resides in the directory ,. extract the compressed tar file into the current directory:
gunzip -c / .tar.gz | tar xfp -
6. Read the README file in the installation directory for last minute updates, before proceeding.
7. Run the Install script in the installation directory, with the absolute path of the installation directory as argument,
./Install /usr/local/erlang/otp_r7b
and supply answers to the prompts.
In most cases, there is a default answer in square brackets ([]). If the default is satisfactory, just press . In general you are only prompted for one thing:
- "Do you want to use a minimal system startup instead of the SASL startup?"
In a minimal system, only the Kernel and STDLIB applications are loaded and started. If the SASL startup is used, the SASL application is included as well. Normally, the minimal system is enough.
8. Make Erlang/OTP available for users, either by putting the path /usr/local/erlang/otp_r7b/bin in users $PATH variable, or link the executable /usr/local/erlang/otp_r7b/bin/erl accordingly, e.g.:
ln -s /usr/local/erlang/otp_r7b/bin/erl /usr/local/bin/erl
Enhancements:
- Among other things, SMP support was added.
<<less Download (10.3MB) Added: 2006-05-18 License: GPL (GNU General Public License) Price: 1259 downloads
Mar 05, 2010 | Lands Phones
Can't see KPT collection
please make sure that you have installed the plug-ins in the appropriate directory. The appropriate directory for installing plug-ins is Adobe/Photoshop CS3\Photoshop\Plug-Ins. your plug-ins must be installed in the Plug-ins Directory otherwise photoshop cs3 won't show them.
Hope helped.
Thanks
Dec 03, 2009 | Corel KPT Collection (LCKPTCENGPCMA) for...
Can't get itunes to work
The error message “The folder iTunes cannot be found or created”. It was referring to the My Music directory that is usually located in the My Documents folder on the partition containing the operating system. The iTunes software creates an iTunes folder in the My Music directory on first start and if that directory is not accessible it will throw the error message and fail to load.
Since this error is related to the My Music folder it is important to check the directory path of that folder in the Windows Registry. This is best done by using the shortcut [Windows R], typing [regedit] and hitting the [enter] key.
The fastest way of location the two locations that contain path information for the My Music folder is to use the search by pressing [F3] and entering [My Music] in the search box. A click on [Find Next] will start the search and reveal the two locations.
The test computer system did not have path information listed at all. This can be changed by double-clicking the My Music key in the Registry and changing the path to an valid path manually.
The two Registry locations that list the My Music path are the following two:
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\Shell Folders
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\User Shell Folders
Make sure both point to a valid path on the system. Once the path has been changed iTunes will create the iTunes folder in that location and start up without this error message.
Please back up your registry before doing this. messing in the registry can make your computer stop functioning.
Make sure you follow the correct registry entry.
Apr 26, 2009 | Apple iTunes
Installation path change
Change The Default Location For Installing Apps -----------------------------------------------
As the size of hard drives increase, more people are using partitions to separate and store groups of files.
XP uses the C:\Program Files directory as the default base directory into which new programs are installed. However, you can change the default installation drive and/ or directory by using a Registry hack.
Go to :-
- Start > Run
- Type “regedit” (without “” NOOBS!)
- Go to this directory… HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion
- Look for the value named ProgramFilesDir. by default,this value will be C:\Program Files. Edit the value to any valid drive or folder and XP will use that new location as the default installation directory for new programs.
Oct 19, 2008 | Computers & Internet
Mustek Be@rPaw 1200 cs scanner/Vista OP system
Very simple: download from Mustek site ONLY VPDriver.exe. Then open it and store files in a directory. Open Hardware directory on System properties, locates the unistalled item related to USB scanner, select reinstall drivers and point to the directory previous. Vista locate drivers, intall them and our scanner runs correctly with all programs (ex. OpenOffice Draw, etc).
Try it ...
Dec 31, 2007 | Mustek Be@rPaw 1200CS Flatbed Scanner
Computers & Internet Logo
129 people viewed this question
Top The Computers & Internet Experts
Perry Ralston
Level 1 Expert
ashu k...........
Level 1 Expert
ted dux
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
