Question about LG KC910 Renoir Cell Phone
The Wi-Fi on my LG Renoir does not work
The wi-fi connects okay and i enter all password etc. it's just when i go to my browser or youtube etc. it says connection failed,, how do i resolve this problem? please help
  • Anonymous Mar 27, 2014
    wi fi connection
I just switched to a different internet provider. Alexa says she is having trouble connecting. What should I do?
You probably need to connect to your new wireless router.
Open the Alexa app.
In the Alexa app, open the left navigation panel and then select Settings.
Select your device and then select Update Wi-Fi. If you're adding a new device to your account, select Set up a new device instead.
On your Echo device, press and hold the Action button for five seconds. The light ring changes to orange, and your mobile device connects to your Echo device. A list of available Wi-Fi networks appear in the app.
Note: The Alexa app may ask you to manually connect your device to your Echo device through your Wi-Fi settings.
Select your Wi-Fi network and enter the network password (if required). If you don't see your Wi-Fi network, scroll down and select Add a Network (for hidden networks) or Rescan.
Optional - Save your Wi-Fi password to Amazon: Any Wi-Fi passwords saved during setup automatically appear when you connect a new Alexa device to the same Wi-Fi network. The password is also remembered if you switch between saved Wi-Fi networks. For more information, go to Saving Your Wi-Fi Passwords to Amazon FAQs.
Optional - Connect to a public network: Enter any required information if you are connecting to a public network that requires a web browser to sign in, like a school or hotel. The information could be a pre-shared password, room number, or just a button to accept conditions for using the network. This information cannot be saved to Amazon. Contact the network owner for more information.
Select Connect. After your device connects to your Wi-Fi network, a confirmation message appears in the app.
Jan 25, 2017 | Internet Computers & Internet
My zte lever won't hook up to my home Internet.. Please help
This tutorial will explain how to get connected to Wi-Fi on your ZTE Tania Connecting your phone to a Wi-Fi network means you can access the internet, download apps and perform other tasks without incurring data charges.
This guide will show you how to get connected on the ZTE Tania.
How to connect to a Wi-Fi network
  1. From the main menu either swipe right-to-left on the touchscreen or press the right arrow button on the top right of the interface.
  2. Scroll through the menu and find the 'Settings' icon, then tap it.
  3. Press the button marked 'Wi-Fi'.
  4. Tap the Wi-Fi networking On/Off switch to turn Wi-Fi on.You'll then see a list of available wireless networks.
  5. Select the network you want to connect to.
  • If you selected an open network, your phone will automatically connect to the network. Note that some Wi-Fi networks, such as ones you might find in coffee shops, restaurants, or hotels, may require you to enter a password in your web browser before you can connect.
  • If you selected a secured network a password box will pop up. Enter the required password and then press 'Done'.
When you're connected to a wireless network, the wedge-shaped Wi-Fi connected icon appears in the status bar and shows you the signal strength - indicated by the number of bands that light up.
Unless you have wiped your phone, you won't be required to re-enter Wi-Fi details again as your handset should remember them.
How to connect to hidden networksA Wi-Fi network might be hidden, which means the network name isn't broadcasted. In this case, it won't appear in the list of available networks on the Wi-Fi Settings screen and a notification won't appear when the network is in range.
To connect to a hidden Wi-Fi network when it's in range, you'll need to enter the network name and password. Remember that the network name and password are case sensitive.
  4. Ensure that Wi-Fi is switched on.
  5. Press the 'Advanced' button.
  6. Tap the plus (+) icon.
  7. Enter the network name.
  8. Press the 'Add' button.
  9. On the 'Sign In' screen, enter the password, then tap 'Done'.
How to disconnect from a Wi-Fi network
  4. Tap the Wi-Fi Networking On/Off switch to turn Wi-Fi off and disconnect from the wireless network.
Alternatively, you can also press and hold the network name and then tap 'Delete' to disconnect.
However, bear in mind this removes the security settings if it's a secured network, meaning you'll need to enter them again next time you reconnect to that Wi-Fi network.
http://www.knowyourmobile.com/products/15952/guide-how-connect-wi-fi-zte-tania
Apr 05, 2016 | ZTE Cell Phones
How do I change the password on the kindle for the wireless network?
To add a new Wi-Fi Network:
If you don't see the network you want to connect to in the list of detected networks, you can add it by choosing "Enter other Wi-Fi network" at the bottom of the list of detected networks.
  1. Make sure you are within range of the network you want to add, and that you know the network name and password (if required).
  2. Press the Home button, then press the Menu button.
  3. Navigate to "Settings" by moving the 5-way controller down, then press the 5-way controller to select.
  4. Select "view" next to "Wi-Fi Settings" to display a list of detected Wi-Fi networks.
  5. Use the 5-way controller to navigate down to "Enter other Wi-Fi network" and press to select.
  6. Enter the name of the Wi-Fi network that you want to add.
  7. Enter the password (if required). Press the Symbol key to enter numbers or characters not present on the Kindle keyboard. You can continue to use the keyboard while the Symbol menu is displayed.
  8. Choose "submit." Kindle connects to the new Wi-Fi network.
If your Kindle fails to connect to the new Wi-Fi network, it will display an "unable to connect" message. You can try manually entering all the network information for the Wi-Fi network by choosing "set up network" when you see the "unable to connect" message. If you don't know the network information, try connecting to a different network, or contact the network's administrator.
To forget a Wi-Fi network:
You can tell Kindle to forget the Wi-Fi network you're connected to so that your Kindle doesn't connect to it automatically in the future.
  1. While connected to the network that you want to forget, press the Home button, then press the Menu button.
  2. Navigate to "Settings" by moving the 5-way controller down, then press the 5-way controller to select.
  3. Select "view" next to "Wi-Fi Settings" to display a list of detected Wi-Fi networks. You may have to wait a moment as your Kindle detects networks in range. The Wi-Fi network you are currently connected to displays the word "forget" next to it in the list of available networks.
  4. Choose "forget" to disconnect from the network.
To connect to a Wi-Fi network:
  1. Press the Home button, then press the Menu button.
  3. Select "view" next to "Wi-Fi Settings" to display a list of detected Wi-Fi networks. You may have to wait a moment as your Kindle detects networks in range. Kindle automatically scans for available Wi-Fi networks at periodic intervals. To rescan for available networks at any time, select "rescan."
  4. Select "connect" to connect to a network. If you see a lock symbol next to "connect," the network requires a password to connect.
  5. If necessary, enter the Wi-Fi network password, and choose "submit." Press the Symbol key to enter numbers or characters not present on the Kindle keyboard.
Once you are connected to a Wi-Fi network, Kindle automatically connects to it again whenever that network is in range. If more than one previously used network is in range, your Kindle automatically connects to the network that was most recently used.
Tip: Once your Kindle connects to a Wi-Fi network, that network displays "forget" next to it in the list of available networks. Selecting "forget" disconnects your Kindle from that Wi-Fi network and also prevents Kindle from automatically connecting to it in the future.
Mar 07, 2016 | Tablets & eReaders
I just bought a Lg optimus L7 l don't know how to
Turning Wi-Fi on and connecting to a
Wi-Fi network
1 Touch > Apps tab > Settings >
Wi-Fi from the WIRELESS & NETWORKS
2 Set Wi-Fi to ON to turn it on and start
scanning for available Wi-Fi networks.
Tap Wi-Fi menu again to see a list of
active and in-range Wi-Fi networks.
• Secured networks are indicated by a lock
icon.
4 Touch a network to connect to it.
• If the network is open, you are asked to
confirm that you want to connect to that
network by touching Connect.
• If the network is secured, you are
prompted to enter a password or
other credentials. (Ask your network
administrator for details)
Feb 03, 2013 | Cell Phones
What does need a data connection mean
To use Google maps or some other programs (like games), you need to be connected to a Wi-Fi network, not the cellular network. You will need to be in an area with an open wi-fi network or have a wireless router in your home. Find your password for the router's wi-fi network (it should be password-protected) and the SSID; you also need the encryption type (WAP, WEP, etc.).
Press Apps on the Home Screen. Then press Settings and then Wi-Fi. Select Scan to locate available networks. While on the Wi-Fi tab, press Add Network. Enter the SSID with the keyboard, then touch Security type to select the encryption for your router. Then enter the password and finally press Save. (Some wi-fi routers will want the MAC address before you can add a device to the network. Go to the Menu - Advanced from the Wi-fi tab to get the information.)
If the wi-fi network has been set up on the Tab, press Apps on the Home Screen. Then press Settings and look for the Wi-Fi On/Off icon. Toggle this to on. (You can also access this by touching the time on the Home Screen. Then touch Wi-fi on the Quick Settings list.)
I hope this helps.
Jan 16, 2013 | Samsung Galaxy Tab 2 7.0
My Kindle is not picking up the wi fi signal what code do I need to put into it??
Try this:
  • Press the Home button, then press the Menu button.
  • Navigate to "Settings" by moving the 5-way controller down, then press the 5-way controller to select.
  • Select "view" next to "Wi-Fi Settings" to display a list of detected Wi-Fi networks.
  • Use the 5-way controller to navigate down to "Enter other Wi-Fi network" and press to select.
  • Enter the name of the Wi-Fi network that you want to add.
  • Enter the password (if required). Press the Symbol key to enter numbers or characters not present on the Kindle keyboard. You can continue to use the keyboard while the Symbol menu is displayed.
  • Choose "submit." Kindle connects to the new Wi-Fi network.
  • If this doesn't work feel free to reply and I will try find another method. However, if it does please rate me. Thank you.
    PCHELPSTER007 from youtube
    Jul 06, 2011 | Computers & Internet
    Hoe can i connect my ipone to wiifi on my belkin router
    Wi-Fi settings determine whether iPhone uses local Wi-Fi networks to connect to the Internet.
    Turn Wi-Fi on: Choose Wi-Fi and turn Wi-Fi on.
    Join a Wi-Fi network: Choose Wi-Fi, wait a moment as iPhone detects networks in range, then select a network. If necessary, enter a password and tap Join (networks that require a password appear with a lock icon).
    Once you join a Wi-Fi network manually, iPhone automatically joins it whenever the network is in range. If more than one previously used network is in range, iPhone joins the one last used. When iPhone is joined to a Wi-Fi network, the Wi-Fi icon in the status bar at the top of the screen shows signal strength. The more bars you see, the stronger the signal. Set iPhone to ask if you want to join a new network: Choose Wi-Fi and turn "Ask to Join Networks" on or off. Join a closed Wi-Fi network: To join a Wi-Fi network that isn't shown in the list of scanned networks, choose Wi-Fi > Other, then enter the network name. If the network requires a password, tap Security, tap the type of security the network uses, and enter the password. You must already know the network name, password, and security type to connect to a closed network. Some Wi-Fi networks may require you to enter or adjust additional settings, such as a client ID or static IP address. You can type it manually by login onto the Belkin's network page using the browser and by copying the static and dynamic IP address.
    Feb 05, 2011 | Belkin (F5D7230-4) Router (587009)
    Ipod wi fi conection
    Wi-Fi Functionality
    1. Connects over the last Wi-Fi network you used that's available.
    2. If no Wi-Fi networks you've used are available, iPod touch will scan for Wi-Fi networks and show a list of Wi-Fi networks in range. Tap a network and, if necessary, enter the password to join. Networks that require a password show a lock icon (307189_1.jpg) next to them.
    3. Option to manually enter your Wi-Fi network name/SSID (if the Wi-Fi network is configured not to broadcast or be displayed to the public). If necessary, enter the password to join.
    When iPod touch is connected to a Wi-Fi network, the Wi-Fi icon (307189_2.jpg) in the status bar at the top of the screen shows connection strength. The more bars you see, the stronger the connection.
    Wi-Fi Settings
    1. Turn Wi-Fi on or off.
      Choose Settings > Wi-Fi and turn Wi-Fi on or off.
    2. Set iPod touch to ask if you want to join a new Wi-Fi network.
      When you are trying to access the Internet, by using Safari or YouTube for example, and you are not in range of a Wi-Fi network you have previously used, this option tells iPod touch to look for another network. iPod touch will display a list of all available Wi-Fi networks that you can choose from. Networks that require a password appear with a lock icon (307189_1.jpg).
      If "Ask to Join Networks" is turned off, you must manually join a network to connect to the Internet when a previously used network is unavailable.
      Choose Wi-Fi and turn "Ask to Join Networks" on or off. If you turn "Ask to Join Networks" off, you must join new networks manually.
    3. Join a Wi-Fi network manually.
      Choose Wi-Fi, wait a moment as iPod touch detects networks in range, then choose a network. If necessary, enter a password and tap Join. Networks that require a password appear with a lock icon.
    4. Make iPod touch forget a network, so that the device doesn't join it automatically. Choose Wi-Fi and tap the arrow (307189_3.jpg) next to a network you've joined before. Then tap "Forget this Network."
    5. Connect to a closed Wi-Fi network (an available Wi-Fi network that isn't shown in the list of scanned networks).
      Choose Wi-Fi, then tap Other and enter the network name. If the network requires a password, choose Security, tap the type of security the network uses, and enter the password. You must already know the network name, password, and security type to connect to a closed network. Some Wi-Fi networks may require you to enter or adjust additional settings, such as a client ID or static IP address. Ask the network administrator which settings to use.
    6. Adjust settings to connect to a Wi-Fi network
      Choose Wi-Fi, then tap the arrow (307189_3.jpg) next to a network.
    Dec 27, 2010 | Cisco Linksys Wirelessn Router Black...
    Wi-Fi service available but LG Incite can't connect to it
    A wifi connection reverting to available could mean a wrong password enter or a wrong encryption type.
    If the available wifi networks are being use as hotspot, then you probably needs to register in order to use the wifi network.
    If it's a private network, check if the network is at band 5 or 2.4. Just some tips for you to check out.
    Jun 17, 2017 | LG Incite Cell Phone
    LG Renoir wi-fi connection failure
    When i try to turn on my wifi my Lg Renoir restarts ! Any suggestions on how to solve this ?
    John
    Apr 07, 2009 | LG KC910 Renoir Cell Phone
    LG KC910 Renoir Cell Phone Logo
    284 people viewed this question
    Top LG Cell Phones Experts
    Computer Repairing
    Computer Repairing
    Are you a LG Cell Phone Expert? Answer questions, earn points and help others
