Thermostat wiring model feh015ha - Heating & Cooling
Wiring instruction for a White Rodgers 1F78 non-programable thermostat.
The White-Rogers 1F78 thermostat is a single stage 5/2 day programmable thermostat. Home Depot has the manuals for one model of this thermostat, 1F78-151, on the product page: https://www.homedepot.com/p/White-Rodgers-Single-Stage-Digital-5-2-Day-Programmable-Thermostat-1F78-151/202771121 . The wiring diagrams are in the Installation manual. The direct link to this manual is https://www.homedepot.com/catalog/pdfimages/f9/f955280d-67a2-4502-bb94-4975cd857c0b.pdf . Emerson Climate also has the wiring diagram here: http://www.emersonclimate.com/Documents/White-Rodgers/instruction_sheets/0037-6615.pdf .
If you have a different White-Rodgers 1F78 thermostat, check for the manual at Emerson Climate by starting at http://climate.emerson.com/en-us/products/thermostats/thermostat-manuals . Click on the Enter Model Number button and start typing in the model in the search box. I found a number of models with 1F78 listed. After selecting a specific model, I found a link to the installation guide on the left side of the page, below the search box. (Note: the manual link was above the Suggested Replacement header for the models that I checked.)
I hope this helps.
Dec 15, 2017 | White Rodgers Home Security
Need to know correct color wiring from goodman model gph1330h41 with heat kit to honeywell model th5220d thermostat. Thanks
here is the wiring from man. f you have trouble figuring out the programing or what terminals to use in thermostat there is an help phone number. Be shure to turn off all power to unit and thermostat, remove batteries from thermostat.
jl+ax8un4pr7j8pz3ifmkacgi5aaaaaelftksuqmcc
May 12, 2014 | Honeywell Electronic Programmable...
Dpsr483ea1ww how to replace thermostat
  • Unplug the dryer's power cord from the wall connection. You will be working around the dryer's wiring, which can be dangerous if the power is connected.
  • 2
    Remove the rear cover of the dryer. Most dryers have four screws, one at each corner. Flathead screwdrivers will work for most models, but some require Phillips-head screwdrivers.
  • 3
    Locate the thermostat. The thermostat is circular or oval with a wire connection on each side. Remove the screws keeping the wires connected to the thermostat. Set them aside--you will be reusing them to install the new thermostat.
  • 4
    Disconnect the thermostat from the wires, then unscrew the thermostat from its mounting bracket. The thermostat will easily pull away from the wires once you have removed the screws. Discard the old thermostat.
  • 5
    Install the new thermostat on the mounting bracket. Be sure to tighten the screw enough to keep it secured. Connect the wiring to the thermostat and reinstall the screws to hold the wiring in place.
Jan 13, 2012 | GE Dryers
I have a intertherm feh015ha heater , one fuse in the box is getteing hotter then the other one (60amp). what could be causing this
The wiring from the main distribution panel to the disconnect box may have a loose connection at the lugs. Fuses and breakers work by heating up when there is to much amp draw, loose connections will also cause heating of the fuses and breakers. Check the connections at the breaker panel, disconnect box with the fuses, and at the unit connections, also the terminal connections at the heater.
Nov 30, 2011 | Heating & Cooling
Not cooling
If your freezer is not cooling, i will suggest you check the defrost thermostat. To test the defrost thermostat, please follow the steps below:
  1. Locate your refrigerator's defrost thermostat. In freezer-on-top models, it may be located under the floor of the unit, or it could be found at the back of the freezer. If you have a side-by-side refrigerator, the defrost thermostat is found at the back of the freezer side. The thermostat is wired in series with the defrost heater, and when the thermostat opens, the heater shuts off. You will have to remove any objects that are in your way such as the contents of the freezer, freezer shelves, icemaker parts, and the inside rear, back, or bottom panel.
  2. The panel you need to remove may be held in place with either retainer clips or screws. Remove the screws or use a screwdriver to release the clips holding the panel in place. Some older refrigerators may require that you remove a plastic molding before you can gain access to the freezer floor. Exercise caution when removing the molding, as it does break fairly easily. You could try warming it with a warm, wet towel first.
  3. There are two wires leading from the thermostat. They are attached to terminals with slip-on connectors. Gently pull on the connectors to release the wires from the terminals. You may need to use needle nosed pliers to help you. Do not pull on the wires themselves.
  4. Proceed to remove the thermostat. It may be secured in place with a screw, clip, or clamp. The thermostat and the clamp on some models are one assembly. On other models, the thermostat clamps around the evaporator tubing. In some other cases, the thermostat is removed by squeezing in on the clip and pulling the thermostat up.
  5. Set your multitester to the R X 1 ohms setting. Place each of the multitester's leads on a thermostat wire. When your thermostat is cold, it should produce a reading of zero on your multitester. If it is warm (anywhere from forty to ninety degrees Fahrenheit), then this test should produce a reading of infinity. If the results you receive from your test differ from the ones presented here, then you will need to replace your defrost thermostat.
To replace the defrost thermostat, please follow the steps below:
  5. To install your new defrost thermostat, reverse the removal process. Reconnect the wires, replace the panel, and restore power to your refrigerator. For those models where the defrost thermostat is attached to the evaporator coil, make sure you install the new thermostat in the same location and position of the old one.
Hope this information helped. Thank you for using fixya
Jan 16, 2011 | Thetford Norcold RV Cooler/Freezer
We just installed a honeywell thermostat, our furnace is an old furnace and now it won't shut off. it is a hot air oil furnace. any suggestions
for a quick test -- remove the wires from the thermostat and see if the heater shuts off then,,, if it does shut off then the problem is the type ( model ) of the thermostat and it may not be compatible with that heater or there is something wrong with the way that the thermostat is wired. ( make sure that the thermostat is reading the correct temperature and is in fact in the off position ). also double check the wire color code at the heater and make sure that the right wires are connected proper.
what model is the thermostat ?
c...
Jan 03, 2011 | Honeywell Heating & Cooling
I have a Rheem Gas Furnace with an old analog thermostat (Wires conneected to terminals R and 4 for the thermostat). I went to install a Rheem digital and programmable thermostat and it indicated that it...
if you have 2 wire at thermostat Terminals at furnace that the thermostat wire attach to should be R & W if your new thermostat has R & W terminals is should work, an easy thing to remember is the red wire on R the white wire on W. If 4 wire at thermostat at furnace green on G, Blue on Y, red on R,and white on W same at thermostat If these do not match find a thermostat with these terminals
Dec 06, 2009 | Heating & Cooling
I want to change to a programmable thermostat my old one is 8846 and i need to have a wire diagram in order to change wire or its a lr1620 might be the model
  • Red to the thermostat RH or thermostat RC terminal with a jumper wire between thermostat RH and thermostat RC. Or Red to the thermostat R terminal which is shared with both the heating and cooling. It has an internal jumper built in to the sub-base. The red wire is the source hot wire from the transformer. All other wires, except the common wire, controls a specific relay or contactor that energizes the fan, heating, or cooling depending on the selection. The following is the common wiring colors but your system may not be common and different colors could have been used.
  • Green to the thermostat G terminal. This is the color that controls the fan or the relay that control of the blower.
  • Yellow to the thermostat Y terminal. This is for control of the air conditioning.
  • White to the thermostat W terminal. This is for control of the heating.
Here is the link you can copy and paste in your browser: They also have every other model here to:
http://highperformancehvac.com/thermostats_2.html#new_thermostat_installation
Jul 08, 2009 | Honeywell Electronic Programmable...
I have a DuoTherm BriskAIr 13.5K BTU. The Dometic thermostat also controls my HydroFlame 8531-IV furnace. This morning, the furnace would not come on. I checked the wiring and there is no voltage at the...
If you look at control box at roof unit, they usually use a separate set of wires for furnace. See what colors they are attached to at harness to thermostat. Some just follow other harness, and come out at thermostat. (bypass control box) Once you've determined which 2 they are, join them together & see if furnace starts, as it should. If it does, thermostat is faulty. If not, pull outside cover off & check voltages at furnace. I'm guessing by furnace model that your unit is approx 30 ft , but if it's a park model, you may have 24 volt system on furnace or 12 volt. Another way of confirming is to go to back of furnace where air intake grille is inside your unit, and locate 2 blue wires going to furnace & remove whatever wires are attached to them & connect them together. Furnace should start up.
Jul 08, 2009 | Dometic Rooftop RV Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
