Question about Kenmore Washing Machines
The light has gone out in my Kenmore Heavy Duty Stackable Dryer Model # 970c9486200. The machine still works and is drying the clothes the light is just out How do I fix it?
  • 291 Answers
SOURCE: kenmore heavy duty clothes dryer will not heat
You really need a volt / ohm meter to check for Continuity & Volts Its well worth the investment... $15.00 bucks give or take a few I would check to see if you have 220v to back of dryer where the cord mounts to dryer, If dryer is getting only 1 leg 110 volts instead of the 220 will it not heat. Check themostates & heater for Continuity... Most models, Now have a.. Hi-limit fuses that need to be checked for Continuity
Posted on Oct 08, 2007
  • 131 Answers
SOURCE: kenmore heavy duty dryer
You didn't mention if the motor runs or if it heats. If it does both of these, you'll need a new belt.
Posted on Mar 10, 2008
  • 1122 Answers
Posted on Feb 26, 2009
  • 3051 Answers
SOURCE: heavy duty kenmore dryer model # 76680100 not
Hello there:
please try this
Investigate these five areas if your dryer is not heating up:
Proper Voltage
If your dryer won't heat up, it's possible that it is not being supplied with the proper voltage. Here are three ways to make sure power is getting to your dryer: First, make sure your dryer is plugged in. Next, check the circuit breaker panel to make sure all the circuit breakers are in the correct positions. Finally, check to make sure no fuses in your fuse panel are blown. Any of these could explain why power is not getting to your dryer.
dryer_heating-element.jpg Heating Element
It is possible that your dryer isn't heating because its heating element is defective. Heating elements are irrepairable. If yours has ceased to function properly, you will have to replace it. Open your dryer's cabinet and locate the heating element so that you can test it.
dryer_thermal-fuse.jpg Thermal Fuse
Another possible cause for a dryer not heating up could be attributed to a faulty thermal fuse. Once a dryer's thermal fuse has blown, it is no longer of any use. If your dryer's fuse is blown, you will have to replace it. Open up your dryer's cabinet and locate its thermal fuse so that you can test it.
dryer_thermostat.jpg Thermostat
If any of your dryer's thermostats have become defective, they could be the reason that your dryer is not heating. Open up your dryer's cabinet and test each of your dryer's thermostats. If any are faulty, replace them.
dryer_timer.jpg Timer motor
A defective timer motor could also cause your dryer to not heat up. Test your dryer's timer motor. If it is no longer functioning as it should, replace either the entire motor assembly, or just its motor.
Posted on Jan 19, 2010
  • 205 Answers
SOURCE: Maytag Dependable Care Plus/Heavy Duty
HI- Usually when the clothes take a long time to dry it is an issue with the vent. Look in the back of the dryer and make sure the vent is not crushed, crimped or blocked. As well, go outside when the unit is running and feel how much air is coming out of the exit vent. It should be blowing pretty good. If not replace and clean the vent, if the vent goes through the wall and makes a bunch of turn over a long distance you will need to have a vent cleaning service out to brush and vacuum the vent. You can test this by detaching the vent where it goes into the wall and putting pantyhose over the end and see if it dries better. You could also have a thermostat issue but I look at the venting first. Hope this helps.
Posted on Sep 24, 2010
Why isn't My Kenmore Heavy Duty 70 Series Soft Heat Extra Capacity Electric Dryer drying clothes on any one cycle?
One possibility: Air flow! Make sure that the lint trap is cleaned before each cycle. You likely need to thoroughly clean out the vent piping out the back of the machine- a buildup of lint in here can also restrict airflow.
Sep 04, 2012 | Kenmore 659 Electric Dryer
I have a series 90 heavy duty electric Kenmore dryer. I think the heating element has gone out. Is this an easy fix. Dryer still works just doesnt get hot to dry clothes.
If The front panel is one assembly then the element is on the back behind the cover, if there is a small panel on the bottom ending about where the door starts the element is behind that panel on the right hand side. In either case it if fairly easy to get to. Also check the two thermostats on the heating element. Both should have continuity. If either one is open replace them both.
Jan 31, 2011 | Kenmore 62802 Electric Dryer
Kenmore Stackable washer/dryer Model #11088752793, won't heat
Either the elements have blown, or it could be a device called a thermal overload which has popped. (There may also be a loose wire which connects to the heating elements). Have your drier checked out by a good handyman or technician.
Best wishes,
Apr 18, 2010 | Kenmore 98702 Stacked Washer/Dryer
Dryer spins but does not dry clothes
It may not be your heating element. Your dryer lint vent pipe out the back of the machine or maybe out the side may be plugged. You have to pull the machine out and clear that pipe or rebuild it out to a soffit vent or static vent if it is in the attic, or out through your crawl space. This will make a huge difference. If that hot air and moisture doesn't get out of the machine it just goes back into your clothes.
Good luck!!
Mar 18, 2009 | Kenmore 83142 Electric Dryer
Kenmore heavy duty clothes dryer will not heat
Feb 25, 2009 | Kenmore Dryers
It takes a long time to dry a load of clothes
sounds as if you may have an issue with a blocked/clogged ventin, perhaps wher it leaves the home, a unit that is not able to expell the heat will tend to not dry the clothes properly, 2-3x to dry a good sign of venting issue
Jan 14, 2009 | Kenmore 98702 Stacked Washer/Dryer
I have a Frigidaire Gallery Electric Dryer Model #GLER642AS3
The identification label from a Frigidaire Gallery Commercial Heavy Duty Moisture Sensor drier has come off. I need to download operating/user manual. How can I get the serial no. or model no. The drier is 4 years old.
Dec 20, 2008 | Frigidaire GLER642A Electric Dryer
Burnt lines
Your problem is a bad rear drum seal-if these become worn, torn, or missing close can get caught torn or discolored in the space between the clothes drum and rear of the dryer. Replace the rear drum seal.
Aug 13, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore heavy duty dryer
Mar 09, 2008 | Dryers
Washing Machines Logo
Sal De
 Brian Main
Brian Main
