Question about Dishwashers
Dishwasher displays a fr r-E25 - Dishwashers
2 Suggested Answers
iam6fan
  • 1769 Answers
SOURCE: What does E25 mean on my kenmore elite dishwasher model no. 639.140031.
Indicates a drain problem. Either blocked drain somewhere or defective drain pump
Posted on Nov 14, 2017
Nov 14, 2017 | Kenmore Dishwashers
What does e25 on my dishwasher mean
The most common in my view is the impeller jamming on the pump normally something small like a piece of chipped china or bit of broken glass, this can be removed with tweezers or pin nose pliers. After removing it should rotate easily by hand... then you should replace the pump cover and the filter above it must be locked by aligning the blue arrows so that large bits of rubbish cannot get into the impeller again.
There are two types of pump covers one is held on with a screw and the other clips into place.
In a lot of people's houses they have the dishwasher plumed into a sink unit and the fittings can get clogged and also blocked with fat, some have a cross inside the spigot and this gets blocked with all kinds of stuff.
When you push the dishwasher into place the pipes can get trapped and kinked so make sure that this does not happen. Sometimes the waste pipe has kinked when it was fitted and over time the dishwasher is getting worse at emptying and this is when the E25 fault starts occurring.
The last fault is the pump has failed or it is only working intermittently. The new type of modern pump has the armature inside the pump housing and is prone to the seal failing and water can get inside and reduce the inefficiency of the pump.
Mar 21, 2017 | Dishwashers
Dishwasher error codes
For some reason I can't find my manual for my Kenmore dishwasher, but I woke up this morning to find my that it didn't drain and an E25 error code. The last rinse didn't drain.
Jan 01, 2014 | Dishwashers
E25 comes on my dishwasher
E25 means Not Draining
I suggest to clean your pump, filter, etc.
Keep us updated.
Apr 20, 2011 | Bosch Dishwashers
What is E25 on my Bosch super silence dishwasher?
I quote same wrong from other user:
Question: Model dishwasher is Bosch Exxcell SMS50E02
It stopped before the end of a cycle with the error code E:25 and the "check water" light came on
I mopped out all the residual water out of the bottom and then ran a rinse cycle, which after several trials I got to work and then it stopped at the end again with the same error code and water in the bottom as before.
Answer:
I assume by in the bottom you mean inside the dishwasher and not in the base.As long as there is no debris in the sump area and the hoses are clear it appears you have a bad drain pump.
Hope helps.
Apr 03, 2011 | Dishwashers
The control panel on my dishwasher is showing a tap and E15
Mine's a bosch, same problem but started with E25 due to broken glass in the pump impeller, after struggling to remove it and then testing, it eventually moved to E15 as rightly so, no water was entering the machine due to the E25 code. The advice above is good, but take the device out first and tip the machine. This cured my faults without the need for a service call or spare parts.
Mar 27, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Toshiba e25 Call for service
Press and hold "clear" and "8" buttons at the same time. This will dislpay an error code. What is the code?
Jul 03, 2009 | Xerox CopyCentre C118 Copier
Dishwashers Logo
27 people viewed this question
Top Dishwashers Experts
