Question about Magellan GPS
Magellan Maestro 3250 map display stuck on home position. I have performed the tiny button reset several times. Cleared all stored data. Not in Simulation mode. Installed the newest software.
I can see multiple (8 or more) satellite data. I can see the cursor move slightly as it is jumps to another satellite. The heading mode is stuck at the power on geographical location. Unit was unused for several years. I mounted it in my car and it worked perfectly for days before quitting. No actions associated with the failure of the GPS. I have tested it powered by both AC line charger, car power, and internal power. Same results from all three power sources. Could an old battery be pulling down the available voltage to the motherboard? It seems to just barely function at times. I did simulate a route and the screen map display moved as it should, so the display and its associated drivers are working correctly. Something seems to be wrong with the satellite position calculations. What SNR values from the satellites should one expect? The original battery is fully charged - all green bars. Taking the GPS to a new location and cycling the reset function will display the new location but it then remains frozen there. I don't mind changing the battery if you think it could be to culprit.
My gps is stuck
HOLD DOWN THE POWER BOTTON UNTILL IT RESETS. IT COULD TAKE TWO OR THREE MINS BEFORE IT RESETS.
Mar 30, 2014 | Magellan Maestro 3250 GPS
How do I update my Magellan 3250
You can go to Magellan's website but I can assure you there are no map updates for free.
Try resetting the unit.
Turn it on and find the tiny hole marked reset - -then push and hold a paperclip in the hole until it resets. Try this 3 times if you want to clear it out and start with the maps it came with.
Go here - the official Magellan website and read until you see the word RESET - this is for your model.
http://www.magellangps.com/support/faqdetail.asp?faqid=480&prodid=1948
Please rate me hi it makes a big difference to me - thanks
Rice
Mar 30, 2010 | Magellan Maestro 3250 GPS
Maestro 3250 Stuck on Magellan Screen at Start Up
go HERE, he/i will tell you how you can get it repaired free. this can be fixed but it requires a lot of time and patients..
i dont think there is enough space here to explain fully how to restore the gps....you cant make it any worst but why waste your time if you can get it done for free.
Aug 31, 2009 | Magellan Maestro 3250 GPS
Map is stuck on an old location and won't change to the new location on the map
take the unit outside so that it has a clear view to the open sky, turn the unit on, then push the reset onthe side(you need a paper clip) youll know its reset once you see the magellan logo screen with the black loading bar on the bottom. let in sit outside to Aguire the satellites. this may take upto 30 minutes. if that does not work, you can try the latest update. bill
Jul 14, 2009 | Magellan Maestro 3250 GPS
Switch from true view to map view on the magellan 3250?
You didn't state your model but on my Maestro 3210 and 4210 it's MENU USER OPTIONS MAP OPTIONS
Jan 12, 2009 | Magellan Maestro 3200 GPS
New maestro 3250 when turn on screen stays white
New unit , It's under warranty , contact Magellan
Jan 05, 2009 | Magellan Maestro 3250 GPS
Magellan Maestro 3250 Regions Problem My magellan maestro 3250 shows the regions,Canada,Alaska.Hawaii,and Puerto-Rico. How can I change to US?
I had the same problem, magellan would not give me a code for the map to just download but did agree to send me a new unit and then have me send back the old ubit after verifiying my receipt. did have to give them a credit card # to make sure I send back the old gps
Dec 12, 2008 | Magellan Maestro 3250 GPS
Magellan Maestro 4250
No a practical solution, but at least you will get your device repair, after being on hold for 40 minutes I spoke to a very nice rep, unfortunately evethough she didn't admit it, it seems a software problem with the new 2008/2009 map update, in other words no way to fix it, you need to send it for repair, make sure you tell them to update the device with the new 2008/2009 Maps, if not you will have the same problem later on, Good Luck
Jun 25, 2008 | Magellan Maestro 4040 GPS Receiver
Map update for the 3250
I would avoid map updates from Magellan like the plague. They have a strange way of frying the units. Unless you want to be without your GPS and fighting with Magellan for months, leave the map software the way it is.
Dec 28, 2007 | Magellan Roadmate 760 GPS Receiver
GPS Logo
54 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
