Sunvisor mirror light bulbs
What type or where to find
I put a new replacement bulb inside the the mirror.Inside the mirror it had a sticker saying Type T 25 Watt bulb. I closed it up, plugged it in and no light. This is a touch light. Could something with...
yes! it could be a broken cold weld or something of that nature, If you are not familare with electrical DO NOT fiddle with it do to the fire hazrd.
Jan 16, 2015 | Cars & Trucks
I have A 2006 Jettta 4door and my back seat lights will not turn on
I take it that the bulbs have been checked. If so the rear light cluster switches can fail. The sun visors are normaly a broken wire in the sunvisor itself. I just relace the visor.
Mar 24, 2014 | 2005 Volkswagen Jetta
1986 nova headliner
Mine came down in 1998 due to foam deterioration and spray adhesive did not help. I had an upholstery shop redo it's been great after that. As long as the cardboard in the headliner is intact, it can be re-upholstered. Shoulder belts, dome light, sunvisors, rear view mirror have to be removed to take out headliner.
Mar 07, 2012 | 1986 Chevrolet Nova
I need to change the light on my conair make up mirror and the model is BE67BR type is R18MP E67101
I found these bulbs at Interlight Light Bulb Company
Dec 16, 2010 | Conair Health & Beauty
How do you change the light bulb under the mirror on the drivers sides door?
How do you change a light bulb on the passenger side mirror of a 2006 ford expedition?
May 20, 2010 | 2003 Ford Expedition
2005 Honda Accord sunvisor buzz or rattle
has the visor got a slider for the mirror,if so, close it when not in use if not change it for a solid tinted plexiglass visor(no mirror) sorry but females will need to use central mirror for makeup..i am not a sexist by the way .........
Feb 11, 2010 | 2008 Honda Accord
Light bulb for turn signal under mirror 2006 chevy
not bulb led light part of mirror dealer, some auto stores or online parts
Jan 21, 2010 | 2006 Chevrolet Trailblazer
Blows fuse #22 when you use the sunvisor mirror.
You have probably got a dead short somewhere in the system.  Not often but on a rare occasion when a bulb blows is will cause a dead short.  Look at all the lights that are associated with that system.  Replace the bulbs that are not working or ones that are dimly glowing.  I suspect it may be in the sunvisor or trunk considering those are the two things that are causing you problems
Jun 11, 2008 | 2001 Volkswagen Cabrio
Custom Rear view mirror
Hiya...ALL factory-installed rearview mirrors are installed with different wires due to options.
About 6 different rearview mirrors are installed with those options such as On-Star, light, compass, and those features which use different wires....THIS CANNOT be modified with different rearview mirror....**for example, the Equinox owner attempt to pull out a factory-installed base rearview mirror and put in different one that has compass/temperature built into the rearview mirror**
However, the wires are located inside the front headliner which requires removing the sunvisor (and possible removal of interior plastic trim part at the left/right ends of the windshield) prior to pull the headliner down, and a small metal philips or torx screw is used to secure the rearview mirror onto the bracket glued to the windshield.
The best solution is to leave the original factory-installed rearview mirror in place.
May 16, 2008 | 2006 Chevrolet Equinox
Computers & Internet Logo
49 people viewed this question
David Payne
David Payne
