Question about Craftsman Garden
I have a craftsman mod 917.258542 When I place it in gear and release the clutch nothing happens.The drive belt is intact,and feels taut,also I can roll tractor back and forth while in gear.
    Top Expert:
  • Craftsman Master
  • 13,677 Answers
Check the rear axle release its a button or pull lever at the rear of unit by rear of seat
Posted on Apr 16, 2017
    New Friend:
    Problem Solver:
  • 9 Answers
Hi when you let your foot of the clutch the pulley may not be coming a cross if you ring me on 07849461942 i will tell you better
When I release the clutch on my 42 inch, Craftsman II, Diehard, it won't move forward or backwards
Sounds like the drive belt isit running as fast as the pulley it is either stretched or has come off not getting power to wheels.
Jul 26, 2017 | Craftsman Garden
What causes my 13.5 hp craftsman model #917270412 engine to die when i release the clutch
My question would be what caused the belt to break. Have you checked under the mower deck to make sure the blades turn freely? Could be that something is jamming them and causing the motor to die. Or even a blade that hit something hard might be bent against the top of mower deck.
May 07, 2014 | Garden
I have just fitted a new transmission belt to my westwood 1012, it will go into gear when the motor is off but when the motor is running the gears will not engage when the clutch is pressed
You've probably put the belt on incorrectly or not put the clutch wheel or spring back correctly. When you press the clutch a jockey wheel on the drive belt should release the tension, allowing the belt to slip and the gears to be engaged.
Oct 28, 2013 | Craftsman 20 Hp 42" Deck Lawn Tractor
Need a troubleshooting manual for a craftsman mod. 917.287070
Went out to cut grass and the blades will not engage and when I put it in gear it does not move. Belts are intact. I cleaned the deck of dirt and grass. Still nothing. Just replaced the cable to engage the blades last year. Cable seems to be working.
Jun 25, 2012 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
I have a craftsman riding tractor model #917.286030. It will start with no problem. When I push in the clutch and shift into gear nothing happens. It won't move. I can see the parts moving when I either...
I'm willing to help with problem. I just have may questions. You may call me and i can help figure out what the problem is. I live in California so our time zones may be different.
(831)578-4034 Thanks, Wade
Oct 12, 2017 | Craftsman Garden
Craftsman 42 in. deck lawn tractor. Will start and idle fine but when you let out on the clutch the motor bogs down and dies
few reasons will try to narrow down first start it and put in neutral and deck disengaged release clutch if bogs then fuel problem the carb may need adjustment or repair or fuel filter needs replacement----if no bog step on clutch no put in gear release clutch if bogs check drive belt -upper belt on engine pulley and check for binding an idler pulley problem -debris -or rear unit binding -needs service-drive pulley damaged-rear locked--if not bogging in gear step on clutch engage deck release clutch if bogs need to check deck -belts-pulleys -mandrels -bearings and for bent or binding blades good luck
Mar 10, 2010 | Craftsman Garden
2003 dyna wide glide, after engaging clutch, upon release nothing happens
Are you saying that with the engine running, you pull in the clutch lever, put the transmission in gear, release the clutch lever, Nothing happens?
If so, Look and see if your final drive belt is still on the bike. When the belt breaks, they just run out onto the road and you have nothing to drive the rear wheel with. It'll do it and you won't notice it except that the bike will no longer move under it's own power.
Now, if the belt is still on the bike, it could be the front final drive belt pulley has gone bad. The pulley is made of cast iron and is much softer metal than the final drive gear of the transmission. As a result, the pulley wears rather than the gear. If the gear wore, the time and cost of repair would be much greater than replacement of the pulley. The splines unside the pulley where it goes on the final drive gear may have worn and stripped out.
These are the two most likely problems. Check these out and if you don't find your problem, repost on this forum with what you have learned. Good Luck!
Jan 04, 2010 | 2003 Harley Davidson FXDWG Dyna Wide Glide
Garden Logo
44 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
