Question about Blenders
We blender dial stopped working blades do not turn how to fix only used about 15 times
Was going to crush peanuts pulse for about 2 seconds it speeded up then completely stopped did not work anymore
  • Blenders Master
  • 10,028 Answers
The speed control board is gone. Parts may be next to impossible to find. If the blender is not very expensive or out of warranty, it may be cheaper to get a new one.
Posted on Apr 17, 2017
Why are Blender blades moving very slowly?
Since it's a Kitchen Aid unit I'd examine the possibility of repair.
Mar 09, 2015 | Blenders
How can I change the blade for my 2 speed hand mixer? The model type is NC-12 if you need to know
you are using your KitchenAid blender and it stops blending, you may think there is a problem with the motor in your machine. However, a common reason for the blades not rotating in the blender is a dirty or faulty coupler. The coupler is what connects your blender dispenser to the motor, and you can easily replace the coupler at any time by only using a screwdriver.
Things You'll Need
  • Flat-blade screwdriver
    • 1 Turn the blender dispenser clockwise and lift up to remove it. Set the blender dispenser aside.
    • 2 Insert a flat-blade screwdriver between the black drive coupler and the frame of the blender on the top center portion of the blender.
    • 3 Lift the screwdriver upward, and the coupler will start to bend out of place. Slightly turn the coupler and then lift up on the screwdriver again.
    • 4 Continue to move the coupler slightly and lift the screwdriver until the coupler is completely removed.
    • 5 Insert the new coupler over the blender's motor blade and then twist the coupler counter-clockwise until it is tightly fastened.
Jun 07, 2011 | Blenders
Blender freezes with ee as an error black & decker cyclone 18 speed digital blender
Important: This blender has an intelligent system that
automatically shuts off the appliance after 2 minutes
for speeds 1 to 18 and after 20 seconds for the PULSE
and CRUSH functions. If this occurs, the LED display
shows "EE"; unplug the unit and wait 30 seconds.
Dec 26, 2009 | Black & Decker Blenders
The blades stopped turning in the middle of blending a batch of hummus Its is a Kitchen Aid blender about 10 years old
Does the motor still work if you take the pitcher off of the base? If so, the rod that's in the blade assembly is probably corroded. The blades are connected to a metal rod that passes through a brass tube through to the piece that makes contact with the motor when you put the pitcher on the base. The grease wears down eventually and if you don't pulse and run the motor for a long time at once, the heat can corrode the bar and cause the blade to stop spinning. You can either disassemble the blade unit, or buy a new blade unit online. google blender parts and you can get one for $10
Dec 22, 2009 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
The lights on my cuisinart blender come on but the motor just stopped working
Using your blade holder, turn the motor from the blade end. 1 or two turns. Tak the blade holder out, Plug in an test Sometimes the brushes in the mototor lose a good contact. SGood Luck -Ned-
Sep 19, 2009 | Cuisinart SPB-6 Smartpower 6 Speed Blender
The power switch lights up ok, then if I try to use any speed or Pulse the blender runs for approx. 2-3 seconds, then the power cuts out. How can I dismantle the unit to check the problem.
I have the same problem. 4 of the screws underneath are star-shaped and you will need the appropriate screwdriver for it. I purchased a "set" with heaps to choose from. The other 6 or so are normal. Don't forget to remove the rubber feet and get to the screws under there, too.
Hope that helps! I've had mine apart 3 times trying to fix this problem. Hint: It's probably not the power cord - I tried that already. If you figure it out, let me know, because I'd love to fix mine!
Aug 08, 2009 | Breville BBL550XL 5-Speed Blender
Connection between the motor and the blender unit (where the spinning takes place) - get extremely hot and blender does not seem to blend well. Motor works fine without the top - and the top seems to spin...
Replace the blade assembly immediately. They are available from Cuisinart's website. Sugars and other stuff can gum up the blade assembly over time, so it will periodically need to be replaced. A quick and easy way to keep the blade assembly clean and working longer is to put water and a drop of dishwashing soap in the blender after use and run the blender at low speed for 15-20 seconds - an old Osterizer trick.
Jul 15, 2009 | Cuisinart CBT-500 SmartPower Premier Work...
Breville blender bbl550 stopps after 5 seconds any setting
Mine does this as well... 5 seconds of operation and then OFF.
My guess is this is a fail safe where the blender is turning itself off to avoid overheating and what could potentially cause this overheating is the blender is struggling to turn the blades. What could cause this struggling of turning the blades I am guessing is a lack of oil in the blades rotating parts.
If you hold the circular blade part and turn it, you'll probably find that its hard to turn? Mine is... and I oiled it up a bit and found I got a bit more usage out of it... although only temporarily.
Ideally I need to pull it apart and oil it properly.
Jan 29, 2009 | Breville BBL550XL 5-Speed Blender
Hamilton Beach 52184 12 Speed Blender
keep trying it will loose unless it had worn out then you will have to replace the blade.
Apr 08, 2007 | Hamilton Beach 52184 12 Speed Blender
Blenders Logo
203 people viewed this question
Top Blenders Experts
eyecam
Are you a Blender Expert? Answer questions, earn points and help others
