Question about Tablets & eReaders
Setting up my iPad Air. Screen freezes at the password screen
A disabled ipad.
When you've forgot the lock screen password of your iPad tablet, you get 6 tries of the password entering. After that, the only way you could do is restore you iPad to Factory Settings, which would then no doubt delete your data and files on iPad. The lost data and files would not be backed up on iTunes then. In such case, the only way you could recover data and files from locked iPad is to use 3rd-party data recovery software app. Feel free to read this article to know how to recover files from your locked iPad.
Forgot iPad Screen Lock Password How to Recover Data from Locked iPad
Oct 15, 2015 | Apple iPad Tablets & eReaders
How to set up password on my new ipad mini
The following can be done on ipad with iOS 8:
1. Press the home button( the round button on the front side of your ipad), to go to the home screen.
2. Find the Settings icon ( looks like gray clockwork gears) and tap on it to launch the Settings app.
3. After settings app is started try to find on the left side of the screen Passcode ( has a red lock icon near the text) and tap on it
4. In the passcode setting screen you can choose the type of passcode with the Simple passcode setting switched on or off ( simple means a 4 digit number, not simple means any character combination
5. By taping on Turn passcode on you can enter your passcode. Be carefull not to forget your passcode, otherwise you will not be able to use your ipad later.
Dec 06, 2014 | Apple iPad (16 GB) WiFi Tablet PC
My mini ipad is disabled connect to iTune
Apple can help you to reset your login, when you enter the correct password that belongs to your Apple ID. It will be partially on the screen. If you really messed up, setting up security, and lost unlock code and your Apple ID password. Only Apple can help. For that you have to take iPhone, invoice and prove of your identity (Passport) to the Apple store and hope they will unlock your iPhone. With iOS7 Apple made a very good security system. And while setting up the iPhone and the security, you are warned several times what to do to make sure you and only you could enter the system. Whatever you is told there is no bypass for the Apple security system.Be aware if Apple does reset your iPad, all data now on the iPad will be lost.
Connecting to iTunes, only works if you had it installed on your computer and made a backup on the PC. If you know the password belonging to the Apple ID o the screen, you could try entering that.
Or perhaps you try this site?
http://www.wikihow.com/Reset-a-Forgotten-Password-for-an-iOS-Device
Jul 27, 2014 | Apple iPad 32 GB WiFi Tablet PC
I forgot my user name and password
Jul 25, 2014 | Apple iPad 32 GB WiFi Tablet PC
I can't remember my login on my iPad when I try to back it up on my HP laptop am advised to go to iCloud and turn it off. Is there anyway I could retrieve my login or else just turn off
Apple can help you to reset your login, when you enter the correct password that belongs to your Apple ID. It will be partially on the screen. If you really messed up, setting up security, and lost unlock code and your Apple ID password. Only Apple can help. For that you have to take iPad, invoice, Prove of your identity (Passport) to the Apple store and hope they will unlock your iPad. With iOS7 Apple mede a very good security system. And while setting up the iPad and the security, you are warned several times what to do t make sure you and only you could enter the system.
Be aware if Apple cols and want to reset your iPad, all data now on the iPad will be lost.
Jun 29, 2014 | Tablets & eReaders
Can't get ipad to slide open for the password
Hi Teresa,
Press and HOLD Power button then press and hold Home button without leaving power button. This will restart your iPad and hopefully this issue will be gone. If it doesnt then please let me know, I can guide you through another solution.
Good luck.,
Apr 01, 2014 | Apple iPad (16 GB) WiFi Tablet PC
Tablets & eReaders Logo
23 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
