Question about Kenmore Dishwashers
How to deal with Error E-25 on my Kenmore dishwasher?
Kid 60 s10 please give fault codes
Hi Roger, Hope this helps......CHEERS..
KENMORE DISHWASHER ERROR CODES
Kenmore Dishwasher Error Code = Start Resume light blinking slow
When the dishwasher door opens or electrical power is removed during the cycle then the dishwasher will not start again. The door is detected as being closed and the Start Resume button is being pressed
Kenmore Dishwasher Error Code = Clean light is blinking 7 times
Heater circuit fail. Control panel did not detect the water getting hot. Did not detect heating element was energized to heat the water during the wash cycle
Kenmore Dishwasher Error Code = Sanitize LED blinking at end of cycle
Control panel could not detect if sanitation has been achieved
Kenmore Dishwasher Error Code = Console light blinking rapidly
There is a stuck button on the control panel
Kenmore Dishwasher Error Code = Clean light is constantly illuminated
Dishwasher cannot start a wash cycle until it sees that the door has been opened after the previous washing cycle
Kenmore Dishwasher Error Code = Control lock LED is ON but not responding to pressing of the keys
Turned on by accident or there is a control detected key pad problem
Mar 31, 2016 | Kenmore Dishwashers
Kenmore dishwasher
It is directly related to the draining of the unit.
If all attempts to clear all debris out of the drain line and straighten out any kinks in the line still result in the error code then get a new pump installed
Apr 17, 2014 | Dishwashers
Kenmore dishwasher error e06
the error is linked to the float switch at the base of the dishwasher. Without model number and some description of the condition of the dishwasher leading to the fault code would be helpful.
in the meantime see this site and this too.
Jan 01, 2013 | Kenmore Dishwashers
Error 1 on kenwood dishwasher
Hello.
Manufactured by Whirlpool, Kenmore dishwashers have an electronic control panel that must be unlocked in order to set or make changes to your dishwashing cycle. If an error light is blinking on your dishwasher's control panel, the panel must be reset before you can gain access. Blinking lights on your dishwasher control panel may signal a mechanical problem that needs to be repaired. If the lights continue to blink after you've reset the control panel, contact Sears to service your Kenmore dishwasher or consider troubleshooting the appliance yourself.
1Press and hold the "Heated Dry" button on your Kenmore dishwasher for four seconds to unlock the dishwasher control panel.
2 Press the "Heated Dry," "Normal Wash," "Heated Dry" and "Normal Wash" buttons one after the other, in fairly quick succession.
3 Wait for the dishwasher to run a short diagnostic test.
4 Press the "Cancel/Drain" button at the end of the diagnostic test cycle. This should reset the control panel on your Kenmore dishwasher.
Thanks.
Nov 05, 2011 | Kenwood KDW243A Builtin Dishwasher
Siemens ecosense dishwasher error code 25
hello - what does error code 25 mean on the Siemens Ecosense dishwasher? Thank you
Jan 13, 2011 | Siemens Dishwashers
Disherwash is showing e4 what does it mean
The E4 error is not usually associated with newer dishwashers. Older Kenmore dishwashers with digital displays would show an E4 error when the selector switch pads/buttons were stuck. You need someone In to look at it im afraid
Sep 25, 2010 | Kenmore 15762 Dishwasher
Mineral deposits
make sure ya prime the sink before starting the dw and use less detergant
Jul 01, 2010 | Kenmore 24 in. 16309 Built-in Dishwasher
Door won't close
I have the same dishwasher and the latch has never worked. Finally after 9 months and many service trips I went back to the store and they gave me a new dishwasher. Dealing with Sears has been a nightmare.
Jan 22, 2008 | Kenmore 24 in. 17262 Built-in Dishwasher
Dishwashers Logo
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
