Question about Food Processors
One side of the release mechanism on the lid of our Cuisninart Food processor 12 DCn has come off. (Button and spring). Any tips on how to reattach it to the lid mechanism?
ukvacfan
  • 328 Answers
SOURCE: Broken food processor lid
Check EBAY UK for any older models = you might not be able to get the lid on its own - Moulinex parts are difficult to come by unless they are still being made. Failing that visit UK shops such as Cash Converters or similar - you can sometimes find these food processors there.
Posted on Jan 02, 2009
clyde2j2
  • 137 Answers
SOURCE: I need a new 6 cup holder and lid for my GE food processor.
Try these URLs
www.abtecparts.com---www.marbeck.com---www.smallappliance.com---www.nelsonappliance.com
Posted on Mar 02, 2009
SOURCE: need a replacement part for food processor
The motor is runing, but the blade is not turning.
Posted on Mar 18, 2009
co7196
  • 3433 Answers
SOURCE: need bowl and lid for 5100
Go to this site. or type magicmix in the search bar at the top of the screen, Good Luck
http://www.magimix-spares.co.uk/Parts-for-Magimix-5100-lid,-...
Posted on Oct 31, 2009
SOURCE: lid of food processor
Something I saw on Chowhound worked for me--turn the lid in the back-on direction, then twist it off!
Posted on Apr 10, 2010
My food processor is new but won't start , I have tried everything ! Could there be a safety issue that causes it not to start .
Food processors have mechanical interlocks between the bowl and the base and between the base and the top. Be completely sure everything is lined up and twist-locked into place. You may see a mechanical linkage down the side of the bowl, which should be perfectly lined up with a hole in the base and another linkage in the lid.
Mar 04, 2018 | Food Processors
Closing the lid completely the processor does not work
Take everything off and see if you can activate the motor with the safety switch. It is located at the front above the button panel normally covered by the working bowl. Mixer plugged in and turned on press that button switch in with something non metallic. If the motor goes then fault will be with the mechanisms that activate that switch in either the bowl or the lid. The lids are slightly more likely to be the problem than the bowl. Only a new part will properly solve it.
Sep 01, 2014 | KitchenAid KFP750 Food Processor
Need a product manual
Try going here:
Food Processors Product Manuals Cuisinart com
Look for a machine with the same style / bowl size as yours if your specific machine is not available. You can even download more than one to get additional recipes!
The main important thing if you have an older machine is to make sure when putting it together that the feed tube from the top aligns with the part of the bowl with the spring, so the button on the base gets depressed correctly. For some, the spring mechanism is on the front with the handle, for some it is opposite the handle.
If you put the top on backwards it won't work correctly, and you might break the catch when trying to get it apart... either on the lid, or the bowl, or both. It can be an expensive mistake.
Jan 19, 2014 | Cuisinart DLC-7SFP Pro Food Processor
How does the slide lock on the Cuisinard Custom 11 Food Process go back on?
The main important thing if you have an older style machine is to make sure when putting it together that the feed tube from the top aligns with the part of the bowl with the spring, so the button on the base gets depressed correctly. For some, the spring mechanism is on the front with the handle, for some it is opposite the handle... check the base for the tiny button to double check.
If you put the top on backwards it won't work (at least not correctly) -- but what's worse is that you are likely to break the locking mechanism when trying to get it apart... either on the lid, or the bowl, or both. It can be an expensive mistake.
Luckily, bowls and lids are available from Cuisinart... and many times the same bowl/lid was used for different machine numbers (the various models are about the base, not the bowls/lids/blades/etc.)
Dec 15, 2013 | Cuisinart DLC-8S Pro Custom Food Processor
Kitchen aide chefs chopper Model KFC3100ER2 does not always turn on when pulse button is pressed
You need to replace either the bowl or the lid. Either the lid is not pushing the bowl mechanisms far enough or there is too much lost movement in the bowl part.
Sep 14, 2013 | KitchenAid KFP715 7 Cups Food Processor
Cannot turn the lid on to kitchenaid food processor
It sounds like you need a new working bowl. It is not uncommon for that safety switch mechanism to fail inside the handle.
Jan 29, 2013 | KitchenAid KFP500 Ultra Power Food...
Just stopped working
Most often when that model processor stops working it is associated with the mechanisms in the lid and bowl that activate the safety switch that prevents you turning it on when the bowl & lid is not on correctly. The mechanisms are not repairable, the fix is to replace the bowl or the lid or both. A proper KitchenAid service agent should have both in stock, take your complete machine in so that the faulty part can be identified.
Nov 26, 2017 | KitchenAid KFPW760 12 Cups Food Processor
I have a small Cuisinart food processor and I cannot figure out how to turn it on. It has two levers low and high. I have it plugged in and the lid on? Please help. Fiona Slattery 858-752-8591
Your PowerBlend Duet™ comes with a food processor button. This button is the perfect speed for all your food processing tasks. Always use this speed when using the food processor. You may also use the Pulse button with this function for pulse-chopping.
To use your food processor, make sure that the bowl is assembled properly and the blade or slicing/shredding disc and the cover are locked into place.
When you use the control panel, the LED will light next to each button you press.
Press the On button. For continuous operation, press the Food Processor button. Motor will start if you have followed assembly instructions.
To turn motor off, press the Food Processor button again or the Off button.
For on/off operation, called pulse-chopping or pulsing, press the On button, press the Pulse button, and then press and release the
Food Processor button the desired number of times. Motor runs as long as you hold the Food Processor button down. The motor stops when you release control switch. Try it a few times.
You control the duration and frequency of pulses by the length of time you hold the Food Processor button down and the rate at which you press it. Pulses should be short bursts. Allow enough time between pulses to let food in work bowl fall to bottom.
Always use the Food Processor button for pulse/chopping. Never turn cover back and forth to start and stop processor.
You can download manual from the below link
http://www.cuisinart.com/share/pdf/manuals/bfp-10ch.pdf
ENJOY! RATE THIS SOLUTION
RNJ VINOD KUMAR
Sep 12, 2009 | Cuisinart Food Processors
No instruction manual
First, test the motor by completely removing the workbowl. There should be a dark grey or black button on the base of the processor. Using a pen (not your finger), press and hold the button while turning the machine on - if it does not spin, the motor is dead. If it does spin, then you should reattach the work bowl, slide the lid into place, and then slide the pusher sleeve into place. Slide the pusher into locked position. The link to the manual that will help you make sense of all this is here:
http://www.cuisinart.com/share/man/57_man.pdf
-Tha Mp3 Doctor
Nov 27, 2008 | Cuisinart DLC-8S Pro Custom Food Processor
Food processor
It usually goes something like this, with minor variations depending on model number:
1. Remove the work bowl completely from the base
2. Plug the food processor in and turn it on
3. Use a pen to depress the dark grey/black button on the base – if it spins, proceed
4. Put the work bowl on the base with the handle facing the front of the food processor – slide the work bowl until it locks - the white tabs show in the openings on the bottom of either side of the workbowl
5. Place the lid on the workbowl with the tab slightly left of the center of the workbowl handle – slide the lid counterclockwise until it won’t slide any more
6. Place the pusher sleeve in the feeder tube of the lid with the lock facing the front of the food processor (may vary depending on model)
7. Slide the lock to the right into the locked position
The food processor should now work
-Tha Mp3 Doctor
Apr 20, 2008 | Cuisinart DLC-10S Pro Classic Food...
Food Processors Logo
89 people viewed this question
Top Food Processors Experts
Ross Keen
Are you a Food Processor Expert? Answer questions, earn points and help others
