Question about Pool & Spa
Why doesn't tail sweep. It just drags along behind cleaner.
3 Suggested Answers
jharwell668
  • 640 Answers
SOURCE: 280 sweep hose does not sweep-drags behind unit
Make sure that the opening at the end of your pool cleaners sweep hose is not blocked by the sweep hose scrubber. If this does not work, you will need to adjust the sweep hose screw as mentioned above. The only thing that I would add about that is to make sure that you turn your booster pump off before you make adjustments. Hope this helps! I have a copy of the users manual for this model. Let me know if you need it and I can give it to you.
Posted on May 20, 2010
thepatioman
  • 52 Answers
SOURCE: My Polaris 3900 sweep hose simply drags behind the
The hose connected on the interior of the polaris could be disconnected. seperate the housing and you will see the hose. Or you need more pressure at the wall. Try closing are reducing the amount of flow to the skimmers to up the flow at the wall connection. Your back up valve should pull the polaris off the steps. Set the rotating jet propulsion on rear to 11: 00 position.
The Pool Tech
Posted on Jul 14, 2010
Tail on pool sweep is not moving
screw on bottom open up it will let water in and tail will wag
Jan 27, 2013 | Pentair White/Gray Legend Platinum...
Polaris tail not sweeping. I believe the impeller on the booster is clogged restricting water flow
If unit is operating satisfactorily otherwise, the check end of sweep tail for missing orifice tip. Without it tail won/t sweep. Also check adjusting screw. Out - more tail flow In - less.
Dec 01, 2012 | Polaris Pb4 - 60 Booster Pump
Pentair legend platinum sweep hose doesn't sweep
open up the screw on the bottom that will let water to the tail
Apr 28, 2012 | Pentair White/Gray Legend Platinum...
What would cause the 3900 to run but the tail does not move?
Make sure that the feed hose floats are properly attached and spaced. Make sure that the opening at the end of the sweep hose is not blocked. You might also need to adjust the power to the pool cleaners sweep hose. To adjust the motion, turn off the booster pump and turn the sweep jet clockwise to increase motion.
Jun 24, 2011 | Polaris 3900 Sport Pool Cleaner ()
The sweep tail doesnt sweep
Make sure the opening at the end of the sweep hose is not blocked by the sweep hose scrubber. You might also need to adjust the screw that holds the sweep hose in place. If it is too tight it will not have the slack to move. If it is too loose, it will not have enough tension to move. Try adjusting it and it should have the pool cleaners sweep hose motion.
Mar 14, 2011 | Pentair White/Gray Legend Platinum...
My Polaris 3900 sweep hose simply drags behind the vacuum. I've adjusted the sweep jet, but it doesn't appear to do anything. I'm also finding that the vacuum is gettin hung up when it gets to a the...
The Pool Tech
Jun 13, 2010 | Polaris 3900 Sport Automatic Pool Cleaner ...
280 sweep hose does not sweep-drags behind unit-unit works fine-cleans pool
Apr 27, 2010 | Polaris 280 In - Ground Pool Cleaner with...
Pool & Spa Logo
29 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
