I HAVE A PROBLEM WITH VERSANT 80 MACHINE WITH CODE OF 062-393
How to Remove front cover of Brother CS-80 sewing machine
Have you tried Alans Alterations at the MID WALES SEWING CENTRE they have a huge presence on ebay.They should be able to help you,or point you in the right direction.
Feb 27, 2014 | Brother CS-80
Krups ea 80
Good afternoon... On my krups machine and failure code appeared 8025 09. Said It was the temperature probe. I'd like to get a picture of the temperature probe and its cost. With the best regards
Joao Araujo
Feb 16, 2014 | Krups Small Appliances Espresso Machine
I'm having trouble code 80 for the machine processes the file and not print accuses engine failure''firmware''someone could help me please, I have changed the image processor board and...
hi there
Error Description: Engine Logic Board Failure, Code 80
Possible Solution:
1. Cycle power to the printer to clear the error.
2. Did this clear the error? If, yes problem resolved , if no, replace the engine control board , or,
The image processor board
eng log brd part # required, 160K85653 cost approximate $125
proc brd 650-4306-00 aproximate cost $160
hope this helps -- please send me 4 thumbs up
Jul 10, 2011 | Xerox Phaser 7750DN Laser Printer
Error code PO4-513 on rz 390. overflow problem. I've seen the drum taken apart and cleaned out. any step by step instructions?
There is a much easier way to solve this problem. get a reem of paper and put it in the machine.
next turn the power off hold down the left and right Print Position arrows and power up the machine.
when it boots it will show u a number. at this point you can let go of the arrows.
press the yellow clear button 1 time and the machine should show all zeros on the display.
enter the code 80 and press start. the machine will make a master. after that it will show you 80 again.
press the c button at the bottem of the keypad and it should show 0000 again.enter 888 and press start and set the print speed to the slowest speed possible. (if it keeps jamming try pressing stop and repeating above steps but with code 81)
this is the ink drainage mode it will keep printing until you press the stop key.when the image starts getting light press the stop key and turn the machine off and then on again. and the code should be gone!
Jun 22, 2011 | Riso RZ390 Duplicator
Code u9-80
This indicates a communication failure between the Main Control Unit and the operation control circuit board. Power the machine down and disconnect from hte power supply. Check all the connectors and wiring on the boards and also any loose wiring that may be grounding the machine. Power back up and if the fault persists a qualified copier engineer will be required.
Mar 10, 2010 | Sharp AR-M237 Copier
DCP-110c is showing machine error 46. I have followed instructions as per cene765 solution #1 withput success. I get as far as 'maintenance 80 display. Pressed 'mono start' many times but still displays...
Many thanks - I fixed the error 46 by following the helful solution provided below.
mydcp110c
Rank: Apprentice
Rating: 86%, 8 votes
Hello!
Here is the "Unable to Clean" (code 46) solution:
The machine counts all purge (cleaning) operations in order to prevent the internal ink absorber box from overflowing with purged ink. An “initial purge”, for example, advances the purge counter by 187 + 420 = 607. When the purge counter approaches 6400, an internal "Machine Error 46" is generated. Further purge operations are prohibited, and therefore the printer becomes unuseable.
When an internal Machine Error 46 is generated, the user will see an “Unable to Clean” external message and will be unable to use the printer. The “Unable to Clean” external message can relate to many different internal error codes however.
The user can establish the internal Machine Error Code as follows: pull the mains cable out of the machine (power off), hold down the Menu/Set key, re-insert the mains cable into the machine (power on). The internal Machine Error Code will be displayed.
If there is a Machine Error 46, it is necessary to dismantle the printer, replace the ink absorber box (or possibly break the ink absorber box open and clean its absorbent sponges under a tap), re-assemble the printer and reset the purge counter to zero.
Solution no. 1. (DCP-110C):
The proper reset code sequence to reset DCP printers without numeric keypad should be as follows:
1. press buttons Set, Menu, Mono Start one by one, followed by up arrow key four times.this should all be done as short a time as possible, around 3 seconds.
2. enter maintenance mode 80 by pressing the up/down arrow key and set key to select numbers 8 and 0
3. press up arrow key several times to get to the Purge item
4. enter 2, 7, 8 and 3 using arrow/set keys to reset the counter
5. press Stop/Exit key to go to root of maintenance mode
6. enter 9,9 to exit maintenance mode
Dec 11, 2009 | Brother DCP-110C All-In-One InkJet Printer
"i have a uniden 6 0 dect2080 3 answering machine how to check the messages from a different phone"
The default security code is "80". If you have not reset that code, you will use 80.
This is all from the manual:
1) Call your telephone number and wait for the system to answer. If the answering system is off, it will answer after about ten rings and sounds a series of beeps.
2) During the greeting or the beeps (if answering system is off), press 0 (zero) and enter your security code within 2 seconds.
3) The answering system announces the current time and the number of messages stored in memory. You hear "To play incoming messages, press zero-two. For help, press one-zero" followed by a beep.
Then the manual lists all the remote commands. If you need those, you can go to uniden.com and download a manual.
Apr 13, 2009 | Uniden DECT 6.0 Cordless Phone ID
KONICA MINOLTA BIZHUB C350 WITH ERROR CODE C0960
Check your bypass tray, the tray is on the right side of the machine, the tray flips out for legal and 11x17 paper sizes. Check that there is nothing jamed inside, code says that the tray can't lift. so check for anything jamed inside down there. As to reset the code open then close the front door where you put the toner. Turning the machine on and off will not reset the code. but open and closing the front door will clear about 80% of the service codes.
Apr 02, 2009 | Konica Minolta Office Equipment & Supplies
k24674
