Question about LG Heating & Cooling
LG package unit working but after 15 minutes show error ch16 Please guide me Thanks
2 Suggested Answers
SOURCE: LG single type package air
ac blow air running but compressor not on what is prblom pleas solution
Posted on Jul 22, 2012
Sir, LG package unit , error code CH21 its was start but after 5 minutes turn of its self,??kindly help me,?
Sorry but must replace the pcboard of outdoor unit and maybe the compressor too. It isn’t worth to fix it.
Nov 09, 2017 | LG Heating & Cooling
Why showing always error 7 in lg package unit
You have to try resetting the system. First turn the breaker off for the condenser and wait about 20 seconds. After you turn it back on the system should reset. With out that information i cant help you with your ac repair problem. If you need more information on Air Conditioning Repair please check us out.
Jun 01, 2014 | LG Heating & Cooling
I have a ductless window LG airconditioner that keeps show P2; I have lost the owners manual so I can't remember what this means.
P2 indicates a circuit protection shut down. Turn the Unit Off & Unplug it for 15 minutes. Then plug the unit back in, and turn it ON. During that time out, the electronics should have reset and the unit will go back to your original settings. If this continues to happen contact LG Customer Support 1 (800) 243-0000.
Hope this helps you and thanks for choosing FixYa.
Jul 29, 2011 | Heating & Cooling
I recently purchased lg dehumidifier. it worked for a while then stopped working it displays the following ch24
For whatever reason, LOG does not list any information on Error Codes. To find out what CH24 indicates, contact LG's Support Representative at (800) 243-0000.
In the meantime, turn the unit OFF & unplug it for 15 minutes. Then plug it back in and turn it ON. During that 15 minute timeout, the electronics may have reset themselves and reverted back to the original factory settings. From there, you can set them as you like.
Jul 27, 2011 | LG LHD65EBL Dehumidifier
I have washer machine wm2277hw LG., Tromm., this machine have flash light "" LE"" Error, what is the problem?
Hello & Welcome to FixYa
LE error in your LG front load washer is displayed when either the motor is not working or the control board thinks that the motor is locked up. A Hall effect sensor is used in these washer which monitors the speed and direction of the motor and then forwards this information to the control board. Hope you understand by now that this LE error is displayed when their is an issue with the motor or when the hall effect sensor sends wrong signal to the control. Conclusion is you'll have to check both motor and hall sesor and replace the part# that is bad, usually I have seen the sensor going bad. Please get back to me if you have any other questions.
May 22, 2011 | LG WM-2277HW Front Load Washer
My LG washer is displaying the te error code and it keeps shutting down. What do i do?
'te' for an LG normally means 'heating error' (Temperature).
(It might be worthwhile trying this but sorry, no promises 1)
This could be that the element is coated in calcium. I suggest you run the contents of a couple of sachets of proprietary limescale removing powder/fluid through it. The most efficient way is to put the contents in an empty washer and pour a kettle or two of boiling water into the drum then leave overnight. In the morning run just a spin; the water mix will then go through the drain filter and drain motor impeller blades, doing absolutely NO harm whatsoever, in fact some good!
You could also consider repeating the action ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
May 11, 2011 | LG WM2688H Front Load Washer
The washer shows a UE error during the final spin. It does not reach the fast spin speeds, but shows the error after 5 minutes.
hello ue is an unbalanced error one of the first things you can do according to lg is click this link to try to aleviate the issue also check with a level that your unit is leveled if it is not then you would get this error code as well if you have any further questions message me back and please remember to rank how this opinion has helped it allows me to help others in similar situations in the future Thanks Rick
Apr 21, 2011 | LG WM-2277HW Front Load Washer
Unit stops rinning after 15 minutes ande a sign appears in the window saying c6. turn off unit at main switch and wait for 15 minutes and unit starts adain for a further 10 to 15 minutes and cuts off...
Compressor run current high. Check condenser coil dust blocked. Clean it. Check fan motor- if less rpm, replace capacitor.
Best solution:Do water Service and then check. If still amps gradually increase, replace capacitor.
Thanks and hope helpful.
Jan 28, 2011 | LG Heating & Cooling
My LG Single Package Unit appears CH16 in the thermostat. What must be the Problem? Why?
I know this is little bit late but my information might benefit another person who has the same fault (CH16). In my case, compressor is working but no air blowing. CH16 indicates A/B Cycle low pressure error in LG. According to the maintenance technician analysis and findings, it was the fan belt. They replace and the air start blowing again.
Jan 23, 2011 | LG Heating & Cooling
Heating & Cooling Logo
21 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
