My sky scan mod.31420E .battery spring just feel out is any warranty or replacement?
How to reset time on SioScan travel alarm clock model 31420E
Google (SioScan)(31420E)(manual) without parens to get instructions.
Nov 06, 2016 | Home
How can I be sure if my PCM is bad???
I would try disconnecting battery again. Disconnect both cables and touch them together for a few seconds. This will reset all modules. Wierd that you had so many codes after just disconnecting battery. Sometimes very hard to tell if ecm is bad.
Dec 01, 2014 | 2006 Pontiac Torrent
How to change timeon Sky scan atomic clock mod 31269
Check this link for more details. Pull up older posts there. To type in all details here by this window is very difficult.
Mar 18, 2013 | Televison & Video
My sky remote control does not work with a secondhand skyplus box. what is wrong
see the diagram attached:
1) retight the spring contacts batteries with pliers for good contact
2) clean the contacts batteries with contact cleaner
3) resolder the wires contact batterires
4) open the r.control for clean the contacts for dirty, corrrosion, oxide, test with continuity, remember they send infrared signal to the microcontroller receiver.
5) if you can do it, go to the repair shop TV for fix it.
God bless you
Jul 16, 2012 | Televison & Video
Latch opener spring broken wont open door
You can buy a new door spring through KitchenAid by calling For more information on warranty replacement, please call 800-541-6390
that should solve the issue if not feel free to contact me.
Jan 29, 2011 | KitchenAid KCMS145J Microwave Oven
Need a manual for a Bushnell 565 mod. 78-5656 Where can I get one/
All of Bushnell manuals are on this web site, Look down the web page for your telescope:
The manual will NOT help you find objects in the sky. It only helps with assembly of the telescope.
Jul 31, 2010 | Bushnell Optics
My SIO/SCAN 31420E did not reset for daylight savings time and I can't find the instructions to reset
how do I change my atomic clock to eastern time zone. Or when I set my time does it automatically set to the correct time zone.
Nov 02, 2009 | SkyScan 86709 Atomic Wall Clock
Xbox 360... HELP
Send the unit back to Microsoft for warranty repair.
Call 1-800- 4MY XBOX to set it up.
Make sure you remove mod before sending in as to not void warranty.
Hope this helps!
Mar 11, 2008 | Microsoft Xbox 360 Console
Lens came off-where do springs go?
There are a bunch of Sky Tour telescopes ---
which model you actually have??
I am assuming you have what is called a Dobsonian mounted reflector like this one:
Is that correct?
Dec 02, 2007 | Bushnell Sky Tour Telescope
Televison & Video Logo
Top Televison & Video Experts
