Question about Midea Freezers
The light in my midea upright freezer doesn't work and the door open ding is also not working
  • 1779 Answers
SOURCE: door gasket for Kenmore upright freezer model 2539239712
Go to sears parts direct website. It's part #3206261 and is in stock, $93.07. Good Luck! countrycurt0
Posted on Aug 08, 2008
tech master
  • 120 Answers
SOURCE: frezzer not running, light still on
well if the frezzer needs a new compressor is still under the manufactures warranty for five years you can have it check out it might just be a timer or overload , thermostat if you are not handy with tools just call a tech to give a diagnosis
Posted on Nov 03, 2008
Bat1956
  • 585 Answers
SOURCE: won't freeze after door was left open
Having the door open has introduced an excess of humidity and therefore condensate/ice into the freezer coils. The coils are therefore iced over. You have choices depending upon your skill level. You might: allow the unit to sit unplugged with the door open until the excess ice thaws out and wets the floor underneath, which may take from 6 to 24 hours. You might: do this, adding some heat source in the freezer to accelerate the process. You might: locate the defrot timer, advancing the timer until a click is heard indicating the unit is in defrost, and repeat after about 15 minutes to defrost the unit with it's own heater. You might: let it recover just as it is but it will take a couple of days to clear itself.
Posted on May 19, 2009
garing
  • 998 Answers
SOURCE: Green indicator light not working on Beko freezer
should pry out
thumbs up
Posted on Aug 17, 2009
iwillfixforu
  • 619 Answers
SOURCE: door will no vacuum seal closed
Are you sure compressor is running? If it is make sure the evap fan is running. You should be able to hear the fan when you open the door. If ypou do not hear a fan running then fan has gone bad. 4390914 and approx cost is rediculous in my mind but it is approx. 150.00 to 160.00 . Crazy for a fan motor.
Posted on Jan 29, 2010
Light flickers when door is opened
it has connection problems when you open the door of freezer connecting wire turn gradually and one time comes up light normally,you repair connecting wire of lights.
Mar 23, 2013 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Inside light bulb quit working the bulb is good but doesn't turn on when door opens
Hello Rick Cieri - From what you have described it seems like the unit could possibly be experiencing a wiring failure or communication problem coming from the main control board. Connect with a certified technician to accurately pinpoint any potentially more serious issues.
Jan 19, 2013 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
The door open light is on and the fridge is not getting cold
You have broken door seals and need a replacement soon. Opened door while your freezer running is WASTE the energy and bucks.
Regards, Jay
Oct 25, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
My kenmore frostless 16 upright freezer alarms
kenmore elite, alarm kept going on and b flashed on and off. I finaly figured out on bottom of freezer there is a battery door open it and change 9v. thats it,
Jun 05, 2010 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Left my upright freezer open a crack and now the
With the door left open moisture would get into the unit behind the walls and into the duct work. The only way to fix this right is to unload it and let it unthaw for a day or so open. Once it is all defrosted and restarted it should be fine again.
May 09, 2010 | AEG 10.35 cu. ft. / 293 liter Upright...
Re: danby upright freezer 20.1 cubic ft., model #
The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it’s wore out and doesn’t work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
Leave the door shut and let the magnetic gasket hold the door in place. Put something between the bottom of the door and the floor to hold it in case it slips.
Remove the bracket holding the pin and hinge assembly taking note of order of removal of parts. Slide new cams on. You probably need two.
Oct 13, 2009 | Freezers
I have 15 year old Kenmore upright freezer -- NOT frost-free model. Recently have found ice buildup at top of freezer ---which returned within days of defrosting. Will replacing gasket solve this ? ?
depends on what condition it is in in most cases yes as long as the doors and body are in good shape meaning doors not loose and hanging or holes or dings in the body to allow air and moisture to get in
Jul 20, 2009 | Freezers
Kenmore freezer upright frost build up on door
first just take it out and clean that one carefully .And then set correctly and observe it,s working condition.then also it's not working means show it to ur near by worker those who repairs it
Jun 20, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Freezer not working
I have a Kenmore Freezer model # 253.9251310 serial # s510347256
10\95 Makes all kinds of noises and now is defrosting. Sounds like fan is working but no noises besides fan. any ideas
Dec 12, 2008 | Frigidaire 14.1 cu. ft. Upright Freezer...
Freezers Logo
87 people viewed this question
Top Midea Freezers Experts
mike cooper
Andrew Taylor
Andrew Taylor
Al
Al
Are you a Midea Freezer Expert? Answer questions, earn points and help others
