Question about Briggs Garden
What should the compression be on a 6hp briggs and Stratton engine mdl 12H182
  • Briggs Master
  • 3,498 Answers
I have seen engines run with <90psi.. to run well you need about 120psi..
Posted on Jul 08, 2017
  • 84 Answers
SOURCE: will not start, briggs & stratton 3.75
put a small amount of gas in carb from top and try it. if still not starting make shure choke is in closed position . check the safty switch handle . you do have spark/ and gas
Posted on Oct 19, 2008
  • 15 Answers
SOURCE: cant get a spark on my briggs and stratton 4hp engine, trying to
gap from coil to flywheel is .010. if you've replaced coil, points and condenser with no spark i would try replacing the coil and points with an magnetron kit or a coil that allows for the elimination of points.
Posted on Apr 23, 2009
  • 389 Answers
SOURCE: timing for briggs and stratton 15.5 engine
There are no timing marks, timing is correct when the flywheel key is in place, the flywheel is properly torqued and the air gap for the magneto is properly set
Posted on Sep 29, 2009
  • 1033 Answers
SOURCE: Briggs & Stratton 6hp yard machine with 21inch
The fuel bowl needs to be removed and a new float and needle needs to be installed. The float "floats" in the gas bowl raising the needle, letting fuel into the carb. The repair kit cost about $5 and easily replaced. The float is attached with a pin and the needle fits on the float.
Posted on May 13, 2010
SOURCE: I have a 18 hp briggs and stratton engine that will not start
18 HP Briggs; runs great but oil is leaking on chassis near exhaust
Posted on May 05, 2011
Briggs and stratton 6 hp engine
You can go to the B&S website and download a manual for your particular engine. You will need the model number of the engine. Not all B&S 6HP engines are alike.
Here is a link to the B&S manual page.
Jul 30, 2014 | Garden
What is the magneto gap for a 6HP Briggs & Stratton 12H802 series engine?
Briggs lists it as .006 - .010 on this 6 HP L-head engine. The .010 width can easily be attained by using a standard sized business card as a feeler gauge (and it doesn't stick to the magnets in the flywheel). I double up the card, loosen the coil and let the magnets in the flywheel draw the pickup legs in until they press on the card, tighten up the retaining screws (threadlocker is optional) and your air gap is set.
Jun 10, 2011 | Briggs & Stratton Briggs Stratton...
18 hp vanguard 165lbs and 180 lbs compression have to hand turn engine past compression or starter wont turn engine over
if its hard to get the engine to turn past the compression release then pull your valve coversand try setting your valve lash
.006 on intake
.008 on exhaust
Oct 25, 2010 | Briggs & Stratton Briggs Stratton Vanguard...
Engine wont start
go to youtube and type in valve adjustment on briggs,very simple procedure to do.
Apr 23, 2010 | Briggs & Stratton 66set Panzer Tractor...
Simplicity Sno Away Snow Thrower Briggs 6hp engine No Spark
Check engine oil.
Remove wire from low oil sensor and the start.
Replace low oil sensor.
Hope this tip help solve your problem.
Dec 28, 2009 | Briggs & Stratton Ignition Kit 2-8 HP...
How do i set the timing on a 6hp briggs and stratton pressure washer? mODEL g23
The only timing is the flywheel key and the air gap on the ignition coil. Air gap should be 0.010-0.012"
Nov 22, 2009 | Briggs & Stratton Garden
Need small engine manuals for briggs & stratton & honda
You can go to , input your model and type number and get illustrated parts lists but as the other gentleman said if you want a Service Handbook youj are going to have to pay for that
Apr 03, 2009 | Briggs & Stratton 66set Panzer Tractor...
Garden Logo
59 people viewed this question
Top Briggs Garden Experts
Renee Knafel-Bullock
Are you a Briggs Garden Expert? Answer questions, earn points and help others
