Question about Coffee Makers & Espresso Machines
Blinking water light - Coffee Makers & Espresso Machines
Why does the power light keep blinking
The blinking light is wrongfully indicating that there is not enough water in the tank. The sensor is a small magnet that is floating in a compartment at the bottom of the water tank. (The black square in the corner) You shold be able to see it. Check if it is stuck at the bottom and if it is floating in its chamber. If that is OK, the sensor inside the coffee maker that is reading the magnet might either have come faulty or dispaced (due to a shock?). That would need a disasembly of the coffee maker.
Villi
Jul 05, 2014 | Philips Senseo HD7820 Espresso Machine
Intermittent water flow and blinking lights
the water filter should be changed at least every 6 mos. when the filter is dirty it will not allow the water to flow at full force because it is restricted. change the filter and I think that will be the answer.
Apr 16, 2014 | Amana Refrigerators
No heat from heater
Copy following link to help identify water heater.
http://waterheatertimer.org/How-to-fix-water-heater.html
Add a comment and describe water heater in detail. Attach video with clear description.
If unit has blinking lights, then check product manual for error codes from blinking lights.
If unit is delivering no hot water, check for cross connections
http://waterheatertimer.org/Crossover.html
Call service technician and catch up on routine maintenance, such as cleaning water filter, etc
Jun 10, 2013 | American Heat ADK-2 - Electric 8.2KW...
Blinking blue light on water reservoir won't stop blinking
Needle port is plugged. Clean with paperclip end and run it up 1/4 into the tank to clear the debris.
Apr 10, 2013 | Keurig B60 Coffee Maker
Starbucks sirena lights won't turn on
Just had this happen. Finally I let water run through the steam wand (thought it had to heat up first). Water ran through (until blue light stopped blinking) and now the other lights are blinking...we will see if it works now.
Sep 05, 2009 | Saeco Starbucks Sirena Espresso Machine
Water light keeps blinking and won't brew coffee?
it sounds like either the pump is giving out or the flowmeter.
since it is releasing water from teh steam valve, i'd aim more for the flowmeter giving out.
Not sure if saeco sells them to the public. Usually gets sent out for repair. Repair will run ya 100-150 usually.
May 23, 2008 | Saeco Magic De Luxe Espresso Machine
Blinking small red light.
I had that problem, it is the filetr reminder. I used Reverse Osmosis water so I dont use a =fileter, but the machine doesn't know that. If I recall the manual was wrong on which button to push an hold. I dont remember which was was right (could be the steam button). but one of them does make the light go out in about 5-10 sec.
Feb 20, 2008 | Saeco Easy Espresso Machine
Coffee Makers & Espresso Machines Logo
Top Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
