How do I return a DVD? - Televison & Video
I am returning DVD without the sleeve.
You are very naughty. If you don't find the sleeve we charge you for the full replacement cost of the DVD. For all we know you might have copied it and put it in the original sleeve and sold it. This is mentioned in our agreement. All DVDs must be returned in the condition as supplied to you.
Jan 12, 2016 | Televison & Video
Code or other problem fixes fix.
One fix to return DVD player to origional setings, is to go in to the menu and find the factory reset option the will return the setings back to fresh from the factory.
Regards Tech Guy
on Mar 24, 2008 | Panasonic DMRES30V DVD Recorder/VCR Combo
I need an address for the return of my Netflix DVD. Lost the return envelope. Traverse City MI is the destination.
The addresses vary by where you live they go to the closest place. You can just put two DVDs in one return envelope if you only have one DVD at a time log into your Netflix acct and tell them the problem. They either sent your next DVD or another envelop.
Oct 04, 2014 | Netflix
Is there a code for multi regions for sony hcd s300
Put your player into „Standby“ Mode and enter one of the following commands if necessary:
Remote control command Function
[0] [RETURN] Default Default region code on the player
[1] [RETURN] Region 1
[2] [RETURN] Region 2
[3] [RETURN] Region 3
[4] [RETURN] Region 4
[5] [RETURN] Region 5
[6] [RETURN] Region 6
[P. MODE] [RETURN] Only play DVDs with the selected region; auto switching OFF
[AUDIO] [RETURN] Default Auto switching ON
[ANGLE] [RETURN] Enable video interference impulses (Macrovision ON)
[SUBTITLE] [RETURN] Default Disable video interference impulses (Macrovision OFF)
[PREV] [RETURN] Enable user operation prohibitions* and access restrictions
[NEXT] [RETURN] Default Disable user operation prohibitions* and access restrictions
* The DVD can no longer prohibit you from using the fast-forward, chapter change or Audio-/Subtitle-/Angle switch. You can no longer be forced to watch intros. Just press [TITLE] or [DVD MENU] and select PLAY.
Jan 12, 2010 | Sony DAV-S300 System
How to unlocked DVD in order to play
Try these Two Methods.
  • Turn On the unit with the remote controller
  • Wait until "no disc" appears in the unit's display
  • Press Pause, 3, 1, 4, 1, 5, 9
  • The word "CODE" should appear in the display
  • Within five seconds, press the key that corresponds to the zone you want i.e. 0 for region free, 1 for region 1, 2 for region 2 and so on
  • Again, within 5 seconds, press Pause and Power
If the above fails to work then you may wish to try the following:
  • Put the player into Standby mode
  • Press 1 and Return on remote for region 1, 2 and Return for region 2, and so on. Use 0 and Return to return player to default region settings
  • Press P-Mode and Return to play DVD's with the selected region, auto-switching is Off
  • Press Audio and Return for auto-switching On
  • Press Angle and Return for MacroVision On
  • Press Subtitle and Return for MacroVision Off
Hope this Helps you out if it does then please leave a thumbs up
Little Dish Fitter
Oct 03, 2009 | Sony DVP-NS355 DVD Player
Have a coby dvd r-1200 ,go to systems apply
Im assuming you want to unlock you DVD player so thats its region free??
Try this:
Coby DVD-R1200
  1. The disc tray has to be empty
  2. Press RETURN
  3. Press INFO
  4. Enter 8, 8, 8, X (X is the region code, 0 = multi-region)
  5. Press ENTER (or RETURN)
Jun 10, 2009 | Coby DVD-R1200 DVD Recorder
Unlocking dvd region code
We returned it to the shop, spoke to the manager,and complaained about inaccurate information given to us by disinterested shop assistant and bought a different DVD player that WAS unlocked. Took DVD from different region to check before we bought it.
Jenny Broady
May 04, 2009 | Televison & Video
Returned it to store,got adifferent brand name
Aug 19, 2008 | Philips Magnavox DVD/VCR Dual Player
Hey Carolmb,
Most products that are carried by your local Best Buy™ store are subject to a 30-day return and exchange period, including DVD players. Once you are beyond this point however, we unfortunately cannot take the product back.
If you'd like more information about our return/exchange policy, you may wish to check out the return policy FAQ located on
Hope this helps you out.
Go Ahead. Use Us.
Jun 19, 2008 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
