Question about Samsung Dryers
Samsung Front Loader dryer bought in December 2016, Roller bearings squelling and sounds like they are seezing up
  • 188 Answers
SOURCE: the dryer gets hot but takes five hours to dry one load
Check the exhaust vent, make sure it's not kinked or squished behind the machine and that the outside vent is not clogged with lint. You should feel air blowing freely to the outside.
Also make sure the exhaust vent is not over the recommended length (refer to the manual).
Let me know if you still need help.
Posted on Apr 01, 2009
ginko
  • 19396 Answers
SOURCE: Maytag gas Dryer is Noisy
If the noise is like a shaking of rattling , like coins being shaked , then it is an object trapped inside the drum.
If instead the noise is a loud grinding , that may get louder on high speed, then it is usually a bad drum bearing.
If dryer is not cooling, check that the noise is not coming from the ventilation fan.
Rollers and belt tensioner can also make noise.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Posted on May 06, 2009
  • 56 Answers
SOURCE: 2005 Nisan Akltima Motor has a ticking sound.
Many times your rack in pinion may be the cause, not usually ever a ball joint although if there is an grease fitting grease it with a grease gun with all purpose grease.check also the power steeering fliuid level.
If your motor is ticking check the oil and make sure it is on the full line. Low octane fuel on some cars may cause dieseling although most new computer systems are designed to compesate for lower octane fuels. you also may have a major vacumm leak in your emission control causing the car to idle to low causing noise. If you cannot visually see a problem or have a trained ear to know what the problem may be seek a mechanic or severe engine damage may result.
Posted on Feb 10, 2010
  • 86 Answers
SOURCE: Its seems like the motor valves are making
The steering joints seize and steering wheel will not return to center as a result. Your oil quality may be poor causing the ticking noise.
SOURCE: dryer noise sounds like bearing out or a roller is
my dryer makes a funny noise about 10 to 15 min. into cycle. then shuts off. if you try to restart will not restart unless you hold start button down. once you let go will stop. wait about an hour and dryer will run for another 10- 15 min and start process over again.
Posted on Feb 23, 2010
Samsung front loader washing machine making noise
IF IT IS VERY LOUD SOUNDS LIKE IT NEEDS BEARINGS REPLACED
Jun 17, 2012 | Samsung Washing Machines
Dryer starts then makes aweful noise then stops timer keeps ticking then when you try to start it again it doesnt do anything
If it is a grinding noise then it is probably a bad bearing. If it is more a squell it could be the belt slipping in addition to a bad bearing. If it is a banging sound it could be the belt.
Jun 19, 2011 | Dryers
Rattling and very loud
Rattling and very loud sounds like a very worn roller on the belt tensioner inside the dryer. The top and front panels must be removed to replace these items. Remove the top first to inspect. Usually the inner bearing on the roller locks up making the roller to receive a flat spot on it which causes the belt to jump upon hitting the flat spot on the roller. That is the sound of the dryers drum you hear
Apr 17, 2010 | Dryers
Makes a squeaking sound
had this once upon a time turned out to be bearing swelling as the cycle went on and generated a binding on it so thus came the squealing
Jan 28, 2010 | Bosch Nexxt WTMC3321US Electric Dryer
Dryer starts squelling and cuts off after a few seconds. checked the belt and it seems fine
the squelling you are hearing are the bearings on the motor. The only way to fix the problem is to replace the motor. The part number on the motor is 279827 and price is around $105
Oct 04, 2009 | Whirlpool LER7646E Dryer
The dryer gets hot but takes five hours to dry one load
Apr 01, 2009 | Frigidaire Dryers
Dryers Logo
42 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
