Question about Karcher Garden
Where can you buy a new Karcher motor for a WV60 - 3.6V 12W window vacuum? Alternatively, who makes a suitable little motor and fan assembly?
    Top Expert:
  • Karcher Master
  • 48,384 Answers
Try the karcher manufacturer service agent spares or the manufacturer spares
Posted on Dec 19, 2017
3 Suggested Answers
  • 614 Answers
SOURCE: Replacement fan motor needed
Google ac repalcement parts or we have a replacement parts site Just schroll down at our web site and you will see replacement parts. Russ
Posted on Jul 22, 2009
  • 694 Answers
SOURCE: I have an Electrolux Epci 3500 Sr upright vacuum
The switch is replaceable, so you don't need to replace the complete handle assembly. I've got a 3500 that I replaced the switch on and it works great now. You can get a new switch at the local Aerus Electrolux store. To find the nearest store, just follow the directions on the below site.
I do recommend letting the service tech do the replacement.
Posted on Nov 26, 2010
It keeps dying even after being charged.
You need a new battery. I could describe how to rebuild the old one if you are so inclined to do that type of thing. It would save you some money over buying a new one. It looks like it is a specialized piece of cleaning equipment and buying a replacement battery would be fairly expensive.
Apr 04, 2015 | Karcher WV50 Window Vacuum
Why is my karcher wv50 blowing out water through its air vents
Have you over filled it and tipped the karcher to one side that sometimes makes warter blow out the vents give it a good shake on its side then try again.
Jul 31, 2014 | Karcher WV50 Window Vacuum
Why wont my karcher window vac switch on even after a full charge any ideas ?
Take it apart and see what is stopping it (the motor) from turning .
Jun 23, 2014 | Karcher WV50 Window Vacuum
Cant charge it the red light blinks fast when i push power button
I had the same problem but discovered on opening up the unit that the motor was a bit stiff to turn. I therefore prised off the fan and removed the waterproof shroud only to discover some corrosion on the front bearing. A drop of WD40 did the job and now its working again good as new.
Apr 24, 2014 | Karcher WV50 Window Vacuum
Karcher will not turn on
Check to be sure that the GFI on the plug is not tripped. If that is ok, try turning the motor a little - use a screwdriver, stick it through the fan housing and move the fan 90 degrees. Then try turning it on. If it starts, the problem is with the motor starting to go bad.
Feb 18, 2014 | Karcher Garden
My little green machine won't dispurse the water. what could be wrong?
You can disassemble the unit and check to see if the pump motor has seized.
the motor has a black, red and green wire attached, is encased in a plastic housing, and is right next to the vacuum assembly. Don't cut the line attached to the plastic housing, you don't need to and it can be a pain to reattach later. just slide the whole white housing up towards the black vacuum assembly, and undo the wire leads attached to the motor, they just pull off (make sure it's not plugged in) making sure to note which wire attaches to which lead... i marked each lead with a colored marker to be sure.
Use a pair of pliers to turn the drive shaft if it has seized, and be sure not to lose the small rubber o-ring that sits around the shaft. Lubricate at the base where the drive shaft meets the motor with just a drop of 3-in-1 electric motor oil and then reassemble the housing, attach the leads, seat the motor back into the seating (make sure the bottom nozzle goes into the green water feed coupler!) and reassemble the case.
worked well for me, if it still doesn't work you could buy a new pump and install it. they go for around $10 on ebay and
Jun 24, 2010 | Bissell 1400 Little Green Pro Canister...
I installed a Nutone Bathroom Exaust fan/Light combo #8663RP at my home several years ago. It has worked fine until last week, when it started making a funny noise. I took out the motor/fan assembly and it...
Hello georod01,
Pretty simple problem and you have a few options.. first off.. If you take the fan/motor assembly out of the housing ( meaning : unplug the motor ... power off of course... and remove the sheetmetal screws that secure the mount that holds the fan/motor to the housing.....) You may have already done this... On some models, there is a set screw that secures the fan to the motor shaft.. you may be able to snug that up to stop the wobble... If the motor is OK and the fan is spinning but making contact with the housing.. It may not be centered in the housing so you may be able to better orient it..
If that fails to solve your problem, you can get a fan/motor assembly at home depot and either transfer it from the new bracket to the original ( if they are different).. or transfer just the fan blade onto the old motor... I think it costs about $8 - $12 for that and they are not usually easy to find but they do sell them...try the plumbing section...
As for suitability in an insulated area.. you should have no problems unless you put the wrong bulb size in the holder.. most of them have an over-temp cutoff sensor built in.. The fan motor is not much of a heat source... Hope that helps...
Jan 30, 2010 | Broan-NuTone N-8663RP Combination Light...
Oreck xl 9100 how to replace the fan
I just replaced the fan (plastic) on an XL9100. I assume you got the bottom plate off (5 screws).
Undo the single screw holding the suction housing in place.
Remove the two screws holding the motor in place and gently lift the assemble up, being careful not to stress the wires. The motor and fan assembly should now be exposed. If the nut holdling fan in place is removed, the whole fan should slide right off. If it does not, try a little WD-40 on the shaft and wiggle and move from side to side. (I slipped a small drill bit between the motor fan (motor cooling fan) to prevent the shaft from turning when you remove the nut.) Be sure you turn the nut counter-clockwise to remove it.
You should now have the fan off. Reverse the procedure to place the new fan - following the directions carefully as some assemblies need a washer and "feathered" washer on the top.
Assuming everything went well, it should work.
My 9100 sucked a magnetic bearing and trashed the metal fan to where suction was weak. The new fan works great.
Mar 26, 2009 | Oreck XL Ultra Bagged Upright Vacuum
Garden Logo
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
