Question about Celestion Audio Players & Recorders
Hi guys im looking for replacement drivers or the part number for my celestion A2 loudspeaker. My tweeters both are ok, can someone help me. Thanks
4 Suggested Answers
THENTHEREWER
  • 131 Answers
SOURCE: I need to buy a replacement woofer and tweeter
http://www.usspeaker.com/homepage.htm
http://www.speakerdoctor.com/diaphragms.html
both these companys deal with celestion speakers,for replacments go to usspeaker,to have the originals repaired go the speaker doctor.both have 800 #'s.now which to do is a matter of money.also make sure you don't have a blown crossover(its rare for the high & low freq drivers to go at once)this is usualy crossover related.happy hunting.hope this helps.thanx for using fix-ya!!! p.s.(please tell me you did'nt try best buy:) :) :) HAPPY HOLIDAYS!!!!!!!!
Posted on Nov 30, 2008
SOURCE: hi i have a driver
Motor/unidad de compresion 65watios 1" 103dB 8 Ohms. 500Hz-8000Hz CELESTION DCR-100
Post from EBay.....
Posted on Mar 26, 2011
  • 5 Answers
SOURCE: I had a party last
If you have little kids the center of a tweeter is the perfect place to poke, And wow it dents just like that. Hears a tip. Get some black electrical tape and cut a piece just big enough to fit on the dent, leave a tail piece to hold on to, Then with a quick yank pull the tape directly toward you. this in most cases will pull the dent out clean. There are some cases where leaving the dent may cause distortion in the first harmonic however this is very small so the dent though ugly , presents no problem. THE GREAT OZ.
Posted on Aug 16, 2011
Replacement tweeters
TIP
Why not go for replacement diaphragms for the ones you have ?
Its not realy difficult to do it yourself
celestion a2 tweeter blown or not
http://reconingspeakers.com/product-category/diaphragms/celestion-diaphragms
Jul 26, 2013 | Celestion A2 Speaker
I had a party last weekend, and someone put their finger into the tweeter for my celestion a2.it is dented but still works. are there any shops that do spare tweeters for those speakers? i really hope...
Aug 16, 2011 | Celestion A2 Speaker
No sound from Celestion F20 subwoofer. Tweeter is OK, and so is the other speaker in the pair. Wiring OK as switched speakers around to test.
Since these can be bi-amped or bi-wired (and you don't indicate if that is the case) you need to make sure the jumpers are secure (see the last picture http://archiwumallegro.pl/celestion_f20-1062028198.html) or (if the jumpers are removed) that you have viable amplifier signals coming to each speaker within the cabinet.
May 30, 2011 | Celestion F20 Main / Stereo Speaker
Musical fidelity amp x-a2, one channel intermittent crackling / fading out, any ideas?! Tried swapping source and speakers... Many thanks -chris
hi,
This problem will occur when any one of the driver transistor is become faulty. You have to replace all the driver transistor of the same channel which make cracking sound . It is very difficult to tell which one is faulty. Because if you check the transistors with multimeter it will be ok. Replace all the driver transistor in that channel with same part number marked on it. The driver transistors will look like this,
ajin_g_6.jpg ok
May 20, 2011 | Car Audio & Video
Tweeter not working
Check the continuity of the removed tweeter with a VOM meter (I use an original Heatkit MM-1 available on eBay for $20) and do the 1.5 volt battery click & scratch test mentioned above.
Celestion A3 tweeters (also used in the A1 and A2 speakers) or the replacement diaphragms are no longer available from Celestion. A1 speakers show up regularly on the United Kingdom eBay website for $300 or less and are small enough to economically ship to the USA. You would also end up with a midrange spare speaker (assuming it is the same as in the A3 cabinets)
The part number for the A series 3 bar tweeter is T4969/P. The 3 bars refers to the 3 bars in the casting to protect the dome. I got this number from the box of my spare tweeter I have the earlier 1 bar castings in my A3's.
Go to www.ersatzteil-versand.at do an "artikelsuche" (article search) for the number T4969/P and something extremeley similar shows up except that they list the manufacturer as Onkyo. The part number and description are so similar to what is printed on my spare tweeter box it would be worth 81 euros to see what shows up.
I have designed an adapter plate for either a Scan-Speak Revelator Tweeter D2904/710002 4 ohm, 1" soft dome, 70 mm diameter magnet, $220 or a Vifa D27TG35-06 6 ohms, 72 mm diameter magnet, 91 db, $37.50..Both are available from:
http://www.speakercity.com/ in Burbank, CA
I only modeled the front flange of the tweeter to save time. I have not built any of these yet but the price would probably be $400 for a pair of adapter plates and speaker flange modifications. But when you are done you would have replaceable tweeter for a long time to come. The 2 protective bars are drawer handles available for $3 each.
Other possibilities are:
http://www.audioloudspeakers.co.uk/boultons.shtml voice coil rewinding in the uk
http://www.speaker-repairs.com.au/coils.htm voice coil rewinding in australia
http://www.speakerex.com/diaphragms_new.html in Florida can rebuild the woofer and replace the midrange but no longer have the 4 ohm diaphragm for the tweeter.
If you want the drawings (and 3D geometry file necessary for the machinist to make the curved edges) for the adapter plate and tweeter flange modification contact me at mercedes280se-4@yahoo.com
Feb 11, 2010 | Celestion A3 Speaker
Clestion S10 Sub not working
Instead of connecting it to the sub output, try it on the L or R output of your amp.
This will eliminate the Denon.
If this fails, you need to test the loudspeaker driver unit whilst disconnected from the sub amp. Use a 1.5v cell (AA or bigger) connect using croc leads to the speaker's terminals. If the speaker is OK, you should hear a click. If you hear nothing, the speaker unit is faulty.
Jan 25, 2009 | Celestion S10 Subwoofer
Nov 29, 2008 | Celestion A1 Main / Stereo Speaker
Tweeters poked to death
I know this sounds silly, but I had the same problem. Your speakers have a little plastic bulb that has been pushed in, right?
If so, simply put your mouth up to the tweeter, seal with your lips and **** gently (seriously). The tweeter dome should pop back out and in to shape.
It worked for me.
Good luck.
Aug 03, 2008 | Celestion AVF302 Main / Stereo Speaker
Kenwood LPS 5000D
Hi cw10k
Thats odd. The only passive radiators I have seen over the years have been the same size as the bass driver. They need to be this way to provide the correct tracking of the bass driver. Your speakers sound more like a a 3 way system that may have been modded. Unfortunately they pre-date the internet by the looks of it :) I cant find any info for them, and from my recollection. Kenwood never made anything notable in loudspeakers. I suggest checking the crossover of the speakers to see if they look original, or if indeed they are 3 ways. If there is only a capacitor to the tweeter, then they were never meant to be performance loudspeakers,and probably came with a system of sorts. Keeping in mind the cost of replacement drivers to do upgrades to this sort of gear, may make them uneconomic to repair or upgrade. In Australia(they do deliver world wide) you can get passive radiators from Speaker Bits
Got any thoughts on that. :)
regards
robotek
Jul 17, 2008 | Audio Players & Recorders
26 people viewed this question
Top Celestion Audio Players & Recorders Experts
Josh Whitehead
Josh Whitehead
 Grubhead
Grubhead
Robert Rankin
Are you a Celestion Audio Player and Recorder Expert? Answer questions, earn points and help others
