Question about Lands Phones
Can I make a 3 way conference call with Tracfone?
International Conference Calls: What are the best in terms of quality and most cost effective international conference call services?
Keeping up to the competitive trend the world is dealing with; the conference calling sector too is undergoing the same. Here are some of the best international conference call service providers both in terms of cost plans and service quality:
>Vast conference- It offers operator assistance upon conference calls for some additional but affordable charges.
>Infinite conferencing- You enjoy the privilege of sharing the call recordings upon private and public social media sites at the time of using infinite conferencing.
>RingCentral- It offers numerous interactive features such as easily accessible document sharing feature.
However, in terms of best in quality and cost effective international conference call, Reliance Mind Bridge is a reputed company to deal with. Its MindBridge Freedom service is a reservationless conference service to conduct easy conference anytime, anywhere.
May 16, 2017 | Lands Phones
I need a card for conference calls. where can i get one and for how much.
Conference calls can be made for free.
To set up a conference call:
  1. Dial 305 848 8888
  2. Select "Set up a Conference Call" and follow the prompts.
You will create a password and will be given a 10 digit code.
Distribute the code, time of call, and dial in number (305 848 8888) to all conference call attendees. You may use the access code for any future conference calls as well.
To join a conference call:
  1. Dial 305-848-8888
  2. Select "Join a Conference Call"
  3. Enter the pin
Nov 14, 2013 | magicjack.com
Panasonic kx t7436 how many conference will do conference
you can do as many conferences as you have phones, but one phone can have one conference at a time with 3 total parties(depending on your phone system) in the conference (so yourself and 2 other people, inside or outside of the office)
if you have a TDA/TDE/NCP phone system (blue box on the wall or in a computer rack) you can have 5 people in a single conference...
if you have a TD phone system (white box on the wall) you are limited to a 3 party conference
Jan 06, 2011 | Panasonic KX-T7436 Phone (KXT7436000000)
How do we arrange a conference call?
While on a call, press conference or transfer button(will put first call on temporary hold). Make call to next party, talk to party, press conference button to join all callers. Same procedure to add more parties up to 8 total.
Also, if you use transfer button to start conference call you can use transfer button to join all parties.
If you use conference button to start conference call use conference button to join all parties.
Dec 15, 2010 | Panasonic KX-T7130 Corded Phone
MITEL 5303 Conference Phone question: during connection of a few numbers and 1 number is busy - how do you drop that call without dropping all parties connected?
I believe that if you reach a busy signal, you can hang up. The conference should ring you back and the rest of the conference will be there.
Here's what the documentation shows from within the help of a 3300 ICP/MCD...
a 5303 is to be treated just like a 2500 series set...
2500, 5302 IP Phone, SUPERSET 401, SUPERSET 401+, and SUPERSET 4001 telephones:
To form a Conference when a two-party call is already in place, or to add another party to an existing Conference:
  1. Press Flash or flash the switchhook.
  2. Dial the number of the next party.
  3. Wait for an answer.
  4. Press Flash or Flash the switchhook.
  5. Dial the Conference Call Feature Access Code.
To Leave a Conference:
  • Hang up.
2500 telephone:
To split a Conference and speak privately with the original party:
  1. Flash the switchhook.
  2. Dial the Conference Call Split Feature Access code.
Sep 30, 2010 | Mitel 5303 Conference (50001905)
How do I start a conference call on a Mitel 5303 Conference Phone? It states it only hosts up to 8-10 people.
I'm assuming you are using this on a 3300 ICP. In that case, the phone system is only able to do 8 party conference calls without an external Conference server.
You can dial the first number, press the flash button, dial the next number, dial the feature code (get from your vendor), repeat until you have all parties as part of the call.
The 5310 IP conference unit works much easier than this phone. A conference bridge such as Audio Web Conference with the appropriate licensing will allow for extended conference calls... it will also allow you to record the call for later "off-air" participation.
Sep 23, 2010 | Mitel 5303 Conference (50001905)
Three party conference call
Once you receive your first call Press conference button. your first call will automaticaly be on hold. Press a line button to dial second number. Once call is connected Press conference button and you will have 3 way conference.
To add more PeoPle into conference Press conference button again and select a new line. Dial the number and Press conference button to connect everyone to that conference.
HoPe this helPs
Jul 17, 2009 | AT&T Lucent MLS-12D Phone
HOW TO DO A CONFERENCE CALL
Here are the instructions for making a conference call on a Norstar system.
Conference [Feature] [3]
  • Establish a conference call between yourself and two other parties.
1. Make or answer the first call.
2. Put the first call on hold.
3. Make or answer the second call.
4. After the second call is connected, press [Feature] [3].
5. Press the line or intercom button of the first held call.
6. Press [Rls] to end the conference call
  • To remove yourself from a conference permanently (unsupervised conference):
    • Press [Feature] [7] [0]. The other two callers remain connected. (Some external lines may not support this feature.)
  • To put a conference on hold:
    • Press [Hold]. The other two callers can still talk to each other.
  • To split a conference:
    • Press the line or intercom button of one caller to consult privately while the other caller is on hold. To re-establish the conference, press [Feature] [3].
  • To disconnect one party:
    • Press the line or intercom button of the caller you want to disconnect, then press [Rls].
    • Press the line or intercom button of the remaining caller to resume your conversation.
  • To independently hold two calls:
    • Press the line or intercom button of the first caller, then press [Hold]. The second caller is automatically put on hold. To re-establish the conference, retrieve one call from hold, press [Feature] [3], then retrieve the second call from hold.
May 14, 2009 | NorStar M7324 Telephone
Unable to use conference button
Mar 11, 2009 | Nortel Meridian M7208 Corded Phone
Dropped Conferences
You need to upgrade the code on your system. This happened to me and upgrading the code fixed it. Good luck!
Oct 24, 2007 | Polycom VSX 7000 Video Conference
Lands Phones Logo
59 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
