Question about John Deere Garden
John deere D140 is hunting. Cleaned carb. Still hunting. 60 hr on machine. Now wont start without spraying quick start. Is there a fuel mixture screw on this machine? Only 3 yrs old.
  • John Deere Master
  • 7,515 Answers
Here's the link and I'm sure you will get the solution of your problem.
Posted on Apr 18, 2017
  • Dee gee
    Dee gee Jun 03, 2017
    Horrible answer to a valid question.
John deere d140 ont move
there is a small handle on the back of most riders allowing you to free wheel the machine. If you can push your machine freely now then push the handle in and it should drive
Aug 04, 2014 | John Deere Riding Lawn Mower. D140 48 in....
Why wont my john deere d140 move when I engage the double foot pedal
check and see how much fluid in trans mission and change hydrostatic transmission filter
Aug 03, 2014 | John Deere Riding Lawn Mower. D140 48 in....
I have a John Deer riding lawn mower SX95 with a fb460v kawasaki engine that only starts with fuel dropped into carburetor I have a good spark , I had changed the oil and filter , I also took the carb...
in the carb did any of the screws have any micro bored holes for gas to go through like in many small engine iv found . clogged with goop. does it have a gas bowl an a screw on bottom take it out if does an look it over close.
Jul 25, 2014 | John Deere Garden
John Deere D140 Engine will not turn over.
Important details
Does it turn over/crank well?
Did you check to ensure you have fuel and that it's getting to the carb? (you can simply pull the hose off the carb, and crank the engine holding a little glass under the hose to see if gas pumps out)
Did you check the fuel is not rotten (it should be clear and smell like gas at the gas pump, if it is orange or has a bad smell it needs to be replaced)
Did you check the spark?
Did you check for water in the tank? This looks like little bubbles floating on the bottom of the tank because the water and gas don't mix and the water sinks. Any water at all will contaminate the fuel. You will have to drain the float bowl, the fuel lines, and the tank, dry them and put in fresh fuel.
Did you clean the carb float bowl? If the fuel you by has ANY ethanol content and the tractor sits more than a few weeks without running it is very common to get gunk build up in the carb that will block the jets and keep it from running. carefully cleaning it can fix this.
Tip, do not let carb cleaner get on any rubber seals as they will swell and not fit properly anymore. (or just by new seals)
Check these and repost findings if it doesn't solve your problems, good luck!
Apr 24, 2013 | Garden
Fuel problem with John Deere 23hp engine
time to pull the hose off the fuel pump coming from the tank and drain the tank and check flow of gas coming from tank hose, and possibly inline fuel filter is plugged or there is junk in your tank/line from tank not letting enough fuel to run to pump so pump can pump it to carb !
May 15, 2012 | Briggs & Stratton Briggs Stratton...
My john deere L130 riding lawn tractor has spark and gas going to the carb but wont start. it has new spark plug and fuel filter When starting fluid is sprayed into carb it runs till its burnt up and...
I had a JD 111 rider that may have had the same problem. Turned out to be the fuel line had a weak area and would **** together and not allow the fuel through. It's a cheep place to start.
Good luck!!
Jul 11, 2011 | John Deere Garden
I have a John Deere 420 garden tractor it wont shift from high to low range, also the throttle ramps high to low it sounds like the thing is gonna blow up,I have cleaned the carb what's next?
Check just above the idle fuel mixture screw on the front side of carb and see if the 1/4 inch welch plug blew out of carb.You should see a hole if its blown out of housing,if still there you would barely make out its location,these blow out for 2 reasons,using compressed air to clean carb and a back fire through maniforld.If still have problem I would suspect a split intake manifold near where it goes into block causing an air leak.Both of these are common problems.
May 01, 2010 | John Deere 420,1020,2010,2020,2510,2520...
I am have the same problem
carby jet may be blocked!
or the air fuel mixture needs adjusting
Cheers Rob
Jun 26, 2009 | Peg Perego John Deere Gator HPX
Garden Logo
78 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
