Laptop locked on utility screen from toddler pushing buttons
How long should this process take? My laptop has been doing this for hours!
my computer did this after my toddler grandson pushed the power button on and off again repeatedly, just hold the power button down and force it off, and restart it again, this should work
Oct 24, 2012 | Computers & Internet
What's your prothe laptop didn't even boot up, the fans were whirring but not the BIOS screen came up. The CAPS lock button is blinking in intervals of two, the wireless button is orange and t
With out the mode number can't really help. Remove battery and plug in AC Charger. Push and hold Power on button for 30secs. Then try powering up again.
If unit still fails most likely to be a System/Motherboard fault. If under warranty contact HP.
Aug 31, 2012 | HP Computers & Internet
Zzy6913@yahoo.com i havwe a new compaq presario laptop 1800 model number a18xl390 and its locked up !!!! how do you unlock this model of laptop ?? can a nyone help thanks the wiz
Locked up screen?? Shut down with button, pull the battery. After five or ten minutes reinstall the battery, Push start button. Screen will say window shut down unexpectedly and ask for start command. Start in safe mode and prompts should come up about your problem and ask you to send a report to microsoft. Do that and follow the prompts. I hope that helps.
Jul 14, 2011 | Computers & Internet
Whe i make power button on, he press f1 to BIOS setup utility and press f12 for temporary boot device. when i hit f1 or f12 after some minit, he display just like lock icon on screen and some times says...
Check the laptop is booting by connecting it to an external monitor and see if the lock appears there you may need to press Fn and F7 keys to switch display
If it does not, then try pressing Fn and scroll lock
Jan 10, 2011 | Computers & Internet
Stanley 10-788 how to change blade
Push the top metal button all the way foward as if pushing the blade out to it's (farthest) 3rd setting. Then push foward and down one more time which locks the mechanism down. Push and hold the yellow side button as you insert the blade. When the blade locks in all you have to do is release the yellow button and return the top slide to it is fully retracted home. The blade is loaded
Jan 14, 2010 | Hand Tools
Touch screen and push buttons are not responseive.
Make sure the switch on the side that locks the buttons is not switched on. To be safe, switch it on (so that the red shows) then off.
Oct 11, 2009 | Dell Axim X51v Pocket PC
I turn on my mac and only this small folder icon appears in the middle of the screen
The face is probably frowning.  The computer cannot find the operating system.  Use a utility disk to boot up the computer and then use First Aid or Disk Utility to check the disk.  You may have to re-install the operating system.  This can be done without losing your files if done correctly.  Seek help from an Apple repair facility if you are in doubt about how to do it.
May 20, 2009 | Apple iBook G4 (Z0AZW13397068) PC Notebook
Ps button
Back up your system using the backup utility ( ONLY if you have saved games, pics, video, etc. that you wanna keep)
Go to SETTINGS, SYSTEM SETTINGS, RESTORE PS3
That's the first thing you should try.
Let me know what happens.
Mar 02, 2009 | Sony Playstation 3 (PS3) Console
Enabling wireless connection on Presario R3000
Windows XP
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&dlc=en&cc=us&lang=en&product=442914
Networking Drivers And Utilities Can Be Found Under "Network-Driver"
Go to device manager (Right click my computer , properties , hardware , device manager) and check for any devices listed with a yellow ! next to them
Download and install the wireless driver or alternatively right click the device with the yellow ! and click update driver. The wizard then guides you through the steps of searching for and installing the correct wireless Lan driver.
When finished , check to see if the connection has appeared , either at the bottom near the clock or in the network connections area (access from control panel)
If yes - Problem Solved!
If no - Download the Correct wireless lan utility from the link above that corresponds with the driver you downloaded.
install the utility and load it to see if it detects any wireless points
Dec 10, 2008 | Compaq Presario R3000 Notebook
Resolution problems following a power lock.
Turn on the on screen menu by pushing the number (1) button. Go down the menu to the memory recall function and Push the number (2) button to reset all the controls to factory settings. This should return you monitor to it normal function. If this does not solve your problem, you can call Envision customer support at this telephone number. 1-888-838-6388. They should be able to help you solve the problem. I hope this information helps you with your problem.
Jul 14, 2008 | Envision 19" Widescreen Flat Panel TFT LCD...
Open Questions:
We provide best team support to all Toshiba users active for 24*7 hrs. Call us +1888784-9316 With 24x7 major subsidiaries and affiliates worldwide, Toshiba Corporation is known as a world class innovator and global high technology product leader worldwide. Toshibha launched laptop computers from its kitty way back in 1985 and by Financial Year 2010 they have managed cumulative shipment of more than 100 million Laptops. Toshiba has been known to set benchmarks when it comes to quality and features that results in exceptionally high performance. In spite of the exceptional features you may experience issues related to data recovery, backup and security and may be deprived of any support by the Toshiba Support. In the event of an OS Crash there is always a chance that you may Toshiba Support your critical data. Virus attack or accidental data deletion are also some of the other reasons that could cause mess. An updated backup will warrant that you do not lose your critical data forever. DataAlign comes to you rescue in these situations. DataAlign offers comprehensive technical assistance for your computer's data backup, recovery and security. DataAlign lets you schedule backups to execute daily, weekly or monthly. Our award winning cloud backup Toshiba Customer Service lets you schedule your backups continuously throughout the day. Data Align gives you affordable services that saves you both time and money and that lets you take control of other important things in life like growing your business or spending time with near ones. TOSHIBA is known for its diversified product range and services worldwide. Still, there are several issues that a TOSHIBA user can face on the TOSHIBA computer. Problems faced by TOSHIBA customers BIOS update Toshiba Backup Slow Performance Windows 10 upgrade Data Backup and Transfer Office and outlook setup Wifi and Internet Issues Audio & Video Issues Startup and Boot problems Windows updates Computer Tune-up Issues Virus Removal Issues Our highly talented and expert IT Team can help you fix most of the issues that you face with Toshiba Virus . And the best thing is that we can help you get your data backed up on our secure cloud storage. Why Our Toshiba Help Desk Number Technical Support Team Are Best? With several years of experience in our kitty working with a wide variety of customer group, we have gained an edge when it comes to providing technical support for TOSHIBA Computers. To add to it, our expert technicians trained specifically on TOSHIBA computers are always ready to help you best possible solution for any issue that you may face with your TOSHIBA product. 24X7 availability and assistance for your TOSHIBA computer. We have a dedicated & experienced support team to handle issues for your TOSHIBA computer We ensure little to no downtime with maximum uptime and highest productivity for your TOSHIBA Computer. We ensure Data backup and retrieval assistance We ensure end to end ownership & solution for issues you face with your TOSHIBA computer. Quick and efficient support over the remote. You can sit back & relax while one of our techs fix the issue for you. All these issues and many more, concerning Toshiba users are directly and efficiently resolved by our technically knowledgeable team who can be Reached 24/7 on our Toshiba Contact +1 888 784-9316.
Apr 27, 2018 | Toshiba Computers & Internet
Computers & Internet Logo
55 people viewed this question
David Payne
David Payne
