Question about Vacuums
Cannot find a reason for the pipes clogging dirt not goinginto dirt container
2 Suggested Answers
SOURCE: bissell cleanview bagless - dirt doesn't end up in container
i have a bissell power brush shampoo cleaner, it will not release the soap. what is the problem
Posted on Feb 21, 2009
I have bought a cordless slimvac It was great for a couple of weeks but for some reason the dirt is not going into the dirt container it is just clogging up the pipes can you help.
Most have simple paper filters that block up fairly quickly.it should all come apart for cleaning without needing screwdrivers etc
Apr 16, 2017 | Vacuums
My dirt devil vigor cyclonic pet has no clogs I can find,belt is like new,still won't suction, all filters are clean.
Look for a clog of pet debris right at the intake to the container. It may not be visible unless the container is removed.
Sep 11, 2016 | Dirt Devil Vacuums
Vacuumed dirt does not enter container. Dirt spews out when turned off.
Vincent,
More than likely you have a clog some where so that it does not pull the dirt all the way to the hopper. I would check hoses and filters and any tubing from the floor attachment all the way to the dirt container. Hope this helps!
Apr 21, 2015 | Dirt Devil M085807HD Bagless Upright...
The vacuum cleaner will not **** up any dirt
Hi have you tried cleaning out all of the pipes and brushes on the vacuum? it could be something as simple as clogged up pipes
hope this helps
Mar 03, 2011 | Dirt Devil Reaction Twin Cyclone Upright...
Vacuum not picking up. It is throwing dirt out the back.
it sounds like is clogged or the bag/dirt container is full
Feb 02, 2010 | Dirt Devil Vision Turbo W/Bonus Upright...
Dirt does not collect in container....collects in filter area
Small Filter at bottom of cannister may be clogged. Not letting enough suction draw dirt down.
Dec 22, 2009 | Eureka 5856BVZ Boss Bagless Upright...
Dirt gets caught up in filter instead of in removable container
That is the problem with the bagless cleaners. The dirt goes through the cup, directly to the filter. There is nothing to keep them seperate. You can try putting a single layer of paper towel against the filter. It will provide a breathable barrier for the dirt but, it will clog too.
Aug 24, 2009 | Bissell 3576 CleanView II Bagless Upright...
Clogged hose...
Hi!
Low suction, poor pickup, or no suction may be due to a clog in the vacuum cleaner. If you notice a change in the sound of the motor or a reduction in the spinning action in the Dirt Container, check for clogs. Unplug cleaner from electrical outlet. Empty Dirt Container. Check Upper Tank and Louvers for build up or clogs. Check to make sure Louvers are installed correctly. To unlock the Louvers, grasp the rim and turn toward the left. Pull straight down to remove. If the Louvers are missing or not locked into place, check and clear the tube in the center of the Dirt Container. Remove the Twist ‘n Snap Hose from the vacuum by turning to the left. Check the Suction Inlet, Hose and Hose Wand for clogs. Remove any clogs from the hose using a long, narrow object. Check the Foot Hose for clogs. If needed, remove the screw attaching the Hose Wand Base to the vacuum. Straighten the Foot Hose and unclog with a long, narrow object. If the clog persists, then check the Rotating Floor Brush the Air Passageway for obstructions.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 10, 2009 | Bissell 6594 PowerForce Bagless Upright...
Bissell cleanview bagless - dirt doesn't end up in container
Feb 20, 2009 | Bissell Cleanview Powertrak 35933 Bagless...
My Bissell upright won't **** up dirt
the first thing i would have you do is take apart the unit and check the hoses and the elbows for clogs. any area where there is a angle where the dirt would pass through. if it is not picking up dirt usually there is a clog somewhere in the hose or where the hose meets the vacum bag container.
Nov 29, 2008 | Bissell Vacuums
Vacuums Logo
26 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
