Question about LG Lotus Cell Phone
Lg won't recieve calls and vm is delayed 2 hours
My lotus is less than a month old and many times incoming calls are not recieved and either the vm is delayed (longest so far has been 2hrs!!) or I never recive it. I have attempted turning the phone off and back on and this seems to work for a bit, but I have no clue that people are calling.
I am not seeing the name of the person that is calling me
try saving the contact to your phone instead of the SIM. This may solve your problem,
Mar 26, 2010 | LG KP500 Cookie black on T-Mobile U-Fix...
My LG Shine phone (less than a month old) started overheating in my bag and it smelled like something was burning in the phone. I pulled the battery out, let it cool down, and put it back in. The phone...
you must call att and let them know the problem with the phone because they have been recieving lots of these phones back i send mine back for the same reason
Oct 29, 2009 | LG Shine CU720 Cellular Phone
Cannot Recieve message from Ukraine
your msg settings number may need to be re-entered again, seeing that you are a AT&T customer call the Helpdesk for further support on this issue...
Aug 10, 2009 | Nokia 7373 Cellular Phone
My texts not being recieved when i send them
dear it happens some time because of n/w problem ,if it is happening many times then contact to ur service provider
Aug 07, 2009 | LG Lotus Cell Phone
I can not send txt from my Motorola W375 i can recieve txt make calls recieve calls but can not send txt i was told 2 change the message centre no. how can i do this?
Somce cell phone carriers can block outgoing texts, separately from incoming texts.. You might want to check with your cell company and see if they accidentally blocked your incoming.
Mar 25, 2009 | Motorola Cell Phones
Haunted Phone!
well i can say I have had this issue before myself alot of the time it was due to interferance, lots of metal and steel in the way I had calls come in VM 4 days later make sure your always close to a window if there is lots of metal or tin around.
other then that I would contact your local dealer and tell them of the issue and see if there is something that can be fixed on the unit or if it is just a flaw of the phone itself and if possible upgrade or downgrade of the phone to one that will work correctly in your enviroment.
Nov 30, 2008 | LG CHOCOLATE VX8500 Cellular Phone
Unable to make and recieve calls
I flashed and flexed the set but to no avail, tried a software update but no update was available from motorola. I then went to the Security settings of the set and restricted all outgoing calls and restricted all incoming calls except the phonebook entries. Then I dialed my mobile using a landline which was on my phonebook and my phone started recieving the calls, then after that I allowed all incoming and outgoing calls. This solved the problem. I believe it is sheer luck because I tried that step earlier on the same day but it gave no result.
Jul 21, 2008 | Motorola Mobility L6 Cellular Phone
Katana- Submerged in water for less than 2 minutes
Dang, that is not good the keypad is waterdamaged for good. Take it into a store and have them run a diagnostic on the phone itself. As far as the incoming calls you should still be able to receive those... that is weird actually I would call in for that. Hope that helps :)
Aug 28, 2007 | Sanyo Katana SCP-6600 Cellular Phone
LG Lotus  Cell Phone Logo
109 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
