Question about Cub Cadet Garden
Cub cadet rh65 tiller start problems. Will not start and only fires when spray starting fluid in carb and just stops. Changed filter and gas and still wont start.
  • 10865 Answers
SOURCE: cub cadet 7254 with a 25 hp kawasaki running rough when hot
your carb needs to be either rebuilt or replaced. it is crudded up with lacquer.
Posted on May 10, 2009
  • 25 Answers
SOURCE: 2160 cub cadet that wont start.hot spark to the plugs
You've solved for some of the equation. Spark. Fuel. Air.....all in the proper sequence. Now, what condition are the plugs ? I'd change them out if they have any wetness to them. Check your fuses as well. Another thing is the 'safety switches' - located in seat, on parking brake, etc. One of these could have come undone or gone bad/loose wire. I'm thinking the latter....
Posted on Jun 22, 2009
lemmingleejn
  • 173 Answers
SOURCE: international cub cadet 1250 series wont start
This is definitely a timing problem.
Simply, it is either, too far advanced, or too far retarded.
The first thing I would check, would be the plug.
Clean it up if it's in need, and just check the gap.
If it's too tight, or too far open, that could explain it.
Otherwise, it will be the spacing on the magneto. Either open the gap, or close the it.
I hope that's cleared it up for you,
Good luck with that.
Posted on Jul 26, 2009
buffalonyman
  • 1865 Answers
SOURCE: cub cadet wont start. changed plug, fuel filter,
A safety switch may be preventing startup. Jumper out safety switches and see if it starts.
Posted on Jul 30, 2009
wireguy212
  • 1627 Answers
SOURCE: i have a cub cadet 1500 series and it wont start i
Check and see if it has an anti-backfire solenoid in the front of the carb.If it does and the solenoid has power then you need to replace it.
Posted on Nov 18, 2009
My rtz 50 will not start I have changed the fuel pump and filter it seems to not be pumping aany fuel. I have checked the fuel lines and can suck gas from the carburetor side of the pump thru.
Take a spray bottle and spray some fuel into the carb and see if it starts if so you have a fuel problem. If not you may not be getting fire to the plug. Check the plug and be sure it is gapped correctly and be sure you are getting fire through the plug wire.
Sep 20, 2015 | Cub Cadet RZT L50 50" 23HP Zero Turn Mower...
Won't start without starting fluid
You might want to try using a carburetor cleaner additive, or a spray cleaner to clean the carb internally. Make sure your air filter is clean. You may also want to make sure fuel lines are not restricted.
Sep 07, 2015 | Cub Cadet Riding Lawn Garden Zero Turn...
LT 1550 stopped running and now turns over but wont start
You need to determine what caused it to stop. Is it fuel, carburetor problem or spark, coil problem, or compression, valve or piston problem.
Start by removing the plug, touch the metal on the side by the plug hole, keep fingers clear, turn motor over and look for a blue spark, if good, set plug aside and put your finger over the hole, turn engine ove and it should easily push your finger off by compression. If all, of these are good, you may have gunk in the carb, float stuck or other carb problem. You can also try starting fluid. spray a some at the intake of the carb, you might have to remove the air cleaner, try starting, if it then pops or fires, then it looks like a carb problem, starving gas.
Jul 14, 2015 | Cub Cadet Garden
Kohler engine command pro 27 hp not start cub cadet m60 tank
spray some starting fluid in carb if starts ether bad feul filter or fuel pump or need to rebuild carb
Jul 23, 2014 | Cub Cadet Garden
Will the valves on a kohler engine being out of adjustment keep it from starting
it will but try spraying starting fluid in it to see if it starts if it does replace fuel filter and rebuild carb
Jul 08, 2014 | Cub Cadet Street Sign- tractor lawn riding...
My cub cadet LT1045 46 inch cut model number 13ax11ch712 will not start its getting spark, fuel I was mowing and turned it off when I tried to restart it, it run rough then died now it will not start I...
Have you tried putting a little gas down into the carburetors throat ? If it starts then you'll know you're dealing with a fuel delivery problem. You claimed you have spark so I'm assuming that it's a good blue color, I think if it was me I would be pulling my flywheel off and checking to make sure it hasn't sheared or moved. If you were able to rule out the fuel delivery issue.
Oct 10, 2013 | Cub Cadet Garden
Cub Cadet has gas, has spark, has air -still won't start/run
Are you pulling the plug to check for wetness after cranking it a few times, WITHOUT using the starting fluid? Also, I would recommend using carb cleaner in place of the starting fluid. Starting fluid runs the engine VERY hot for a brief time and can possibly damage rings, valves, and aluminum parts.
Jun 09, 2013 | Garden
I don't think my tiller is getting any juice to the sparkplug. I changed the sparkplug and air filter, checked the oil and gas, but it still won't start.
disconnect the kill wire on the motor and then see if you get spark. If so its your switch, if not it either points or electronic coil or regular coil or condenser problem did you gap the pints correctly and was there a problem b4 you changed the points.
May 03, 2011 | Troy-Bilt Pony Garden Tiller
I have a cub cadet 1500 series and it wont start i changed the fuel lines feul filter spark plug i can pour gas in the carb and it will fire but there is gas getting to the carb it just wont start
Nov 15, 2009 | Garden
Garden Logo
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
