Question about NordicTrack Exercise & Fitness
I have a running machine Nordictrack T7.0. It was running fine But now When I press go it runs fine for 10- 20 seconds and stops. Can I please ask your advice on this? Thanks
  • Deepak Apr 16, 2017
    I have just noticed the motor itself stops after few seconds and also a red light on the mother bord turns off too.
    Novelist:
  • 145 Answers
Hi There, Speed sensor too far from front roller or defective? Lower control board not reaching target "set-speed" when compared to roller feedback may be a failing lower control board. Good Luck
Posted on Apr 18, 2017
#1 Taper
  • 1041 Answers
SOURCE: CS30 Ryobi trimmer dies when I press throttle!
Yes. You just need to do a simple carburetor cleaning. Disassemble the carb. and spray with carb. cleaner. Make sure the small screen is in carb. is free of debris. Use a Den Tek Brush,(http://www.dentek.com/shop.php?target=products&product_id=7), to clean the small portals in the carb.
If you need further assistance, just let me know.
Jim
Posted on Jun 08, 2009
  • 103 Answers
SOURCE: Nordictrack EXP1000i stopped in the middle of program
Your drive motor is over heating. Usually caused by friction from the walk belt. The belt needs to be lubricated. (silicone only) Loosen the adjusting screws on the rear of the macine ten revolutions lift up the belt and using a spray silicone lubricant (from any big retailer) spray a light film on the deck (walk board). Retighten the adjusting bolts ten revolutions. If this does not help I would suggest replacing the walk belt. Good Luck, Tim
Posted on Nov 13, 2009
SOURCE: when starting to sew, cotton
it is possible that the needle & thread are not compatable
here's how to check
Cut 6-8 inch piece of thread of the spool you are going to use for your project
Take the needle you are going to use for the project
& insert the thread thru the eye of the needle
& lift one end of the thread to a 45 degree angle
& if the needle is the right size for the thread it will slide down the thread
But if the needle hangs on the thread you need one size larger needle for the thread
Posted on Oct 07, 2010
Testimonial: "many thanks for your advice, most appreciated and especially so quickly. Will follow advice and check, thanks again"
2manyhobbies
  • 129 Answers
SOURCE: I have a NordicTrack c2200. I find that the tread
There are a couple possibilities.
Remove the motor cover and run the machine.
Check the tension of the motor belt. It may need to be tightened. 2manyhobbies.jpg
Check that the pulley has not broken free from the front roller by stopping the walking belt when the machine is running. If the belt stops, but the motor and pulley keep turning, the pulley has broken free from the front roller.
If this is the case, with a drill and small drill bit, drill a hole through the pulley and roller on the inside edge of the pulley, between the ribs (not where the motor belt travels) and put a screw through the plastic into the metal roller.
Otherwise, change the roller.
Good Luck.
Posted on Dec 30, 2010
AJIN G
  • 6694 Answers
SOURCE: when I turn on my
hi,
There are two possibilities for this problem
1. Check the speed sensor on near the motor pulley. Remove the sensor and clean it and re-fix it. then make a try. if problem remains then
2. The motor speed controller is faulty. There is an IGBT for controlling the motor speed. If it get shorted the motor will run it its high speed.
Be sure before opening the treadmill remove the power.
ok
Posted on Mar 22, 2011
I have a problem. Every time I try to run my treadmill the motor runs for roughly 2 seconds and then turns off. The power is still on, however, but the treadmill only runs in short bursts. How can I f
If it stops but you can still hear the motor running then I would check the belt tension. The force of you running could be causing the belt to stop but no the drive.
Dec 24, 2014 | Nordic Track Nordictrack C2100 Treadmill...
Treadmill belt stops abruptly
This happen because the lack of LUBE in the machine according with the instruction maintenance.
Please see the video and proceed according , LUBE the rollers bearing too.
God bless you
Jan 07, 2013 | Nordic Track Nordictrack A2350 Treadmill...
My Nordictrack X9i treadmill console says it is operating at speed, however the track is not moving. Occasionally the belt will move for just a moment then it stops.
do you hear the motor running but the belt is not? if it is the belt need tightened or the drive belt may have broken. remove the motor hood to inspect
Aug 23, 2012 | NordicTrack Exercise & Fitness
When I turn on my nordictrack e4400 it runs for 1 second and then stops
hi,
ok
Mar 22, 2011 | NordicTrack E4000 Treadmill
I have a NordicTrack c2200. I find that the tread belt is not running smoothly while running on it. As I run, the belt temporarily stops during each running step, causing me to trip up. I tried to lube,...
Good Luck.
Dec 30, 2010 | Nordic Track Exercise & Fitness
Exercise & Fitness Logo
Top NordicTrack Exercise & Fitness Experts
Craig Butler
Craig Butler
Howard
Howard
Ross Metcalfe
Ross Metcalfe
Are you a NordicTrack Exercise and Fitnes Expert? Answer questions, earn points and help others
