Question about Crock Pots & Slow Cookers
How to set nu wave to cook 2.64 hours - Crock Pots & Slow Cookers
Della 12 Quart 1600-Watt Electric Pressure Cooker Multi-Functional Timer Slow Cook XL Part number: 048-GM-48261 Unable to get this cooker to slow cook.
it is possible that you have misunderstood the instructions
for a slow cooker you have low medium and high
press slow cook and on low and in 8 hours the food is cooked
I see from your statements that you expect the cooker to be set on slow cook but cook at a high temperature fast
if it says slow cook --9 hours and the temp is 125 degrees , have you waited 9 hours to see if it is cooked as the slow cooking process is by the gradual build up of heat in the container that is not expelled by radiation to the air
in a pressure cooker , that build up of heat also builds up pressure and so it cooks better
other solution--- if it is not right return it for a warranty refund or if out of warranty , junk it and get a different make
Mar 25, 2017 | Crock Pots & Slow Cookers
I pushed the cook time button but it still says zero what do I do
Hit the on/off button, so that the cooker looks like it is off, then hit the cook time button up the the number of hours you need to cook. This slow cooker has three settings: LOW, HIGH and WARM..... When your corningware slow cooker is initially plugged into a wall outlet, the display will show "0". This display indicates the programmed number of hours for which ameal will cook. The slow cooker can be programed in one hour increments from 1 to 10 on your digital display. The number of hours may be selected by pushing the COOK TIME button until the desired cooking time appears. If 1,2,3,4,5, or 6 hours are selected, then the slow cooker will operate on the high setting. If 7,8,9, or 10 hours are selected then the slow cooker will operate on the low setting. To start the cooking cycle press the ON/OFF button. To interrupt the cooking cycle at anytime, press the ON/OFF button. If the ON/OFF button is pressed when the digital display shows "0", then the slow cooker will automatically start on the warm setting.
May 11, 2010
Nov 19, 2012 | CorningWare SC60 Slow Cooker
I have inherited a west bend slow cooker model 84624 and dont have a manuel for it. I am concerned with the 300 watt is this normal? Or is that very low? I dont know how long to cook in this or amounts...
  • 1 Use setting 1 (warm #1) only to warm rolls and muffins. At 140 degrees Fahrenheit, this setting should not be used for cooking.
  • 2 Use setting 2 (warm #2) to keep cooked foods warm until they're ready to be served.
  • 3 Use settings 3, 4 and 5 (low, medium high) for cooking. The setting you choose determines the length of time the food will cook. A typical meal with meat and vegetables needs 7 to 10 hours to cook at the low or #3 setting, 4 to 6 hours at the medium or #4 setting, and 2 to 3 hours at the high or #5 setting.
  • All West Bend slow cooker models eventually simmer at the boiling point, or 212 degrees. The setting simply determines how quickly the cooker will reach that temperature.
    300 watt is not a huge consumption of electricity, depending of course on, how often, how long and how high temperature.
    Regards
    Sep 28, 2011 | West Bend 84624
    Just been given crock pot with 3 settings can you explain them no manual came with pot
    It sure would help us to help you if you could get the model number off of the bottom of the unit. I can probably locate a user's manual with that information. Try this site to locate the manual: (my best guess without a model number)
    http://safemanuals.com/314159.php?k=84c8d7db0922eceeab89e8e236b92e45&ID=2854106&q=CROCK%20POT%20SMART%20POT
    (209k)
    Find the little blue print that says enter security code and then you can dounload the manual.
    The settings should be OFF High 4 High 6, Low 8 Low 10 and warm.
    1. Place food in stoneware according to recipe.
    2. Plug in Smart-Pot™ slow cooker. The Power light will begin to flash
    indicating that the unit is plugged in, but not turned on.
    HOW TO PROGRAM YOUR SMART-POT™ (CONT.)
    3. Push the Cook Time button to scroll through the timed cooking
    options. Push once and the 4 hour light will illuminate, twice and the
    6 hour light will come on, etc. Select the time based on the length of
    time indicated in the recipe. Two time options are usually given. The 4
    and 6 hour settings are the HIGH temperature setting and may be
    used when you want your food done quicker. The 8 and 10 hour
    settings correspond to the LOW temperature setting and is used for all
    day cooking. In addition your Smart-Pot™ can be set to the Warm
    Setting by scrolling through the timed cooking options until the warm
    light illuminates.
    NOTE: The Warm setting is for keeping already hot food warm. Do not use
    the warm setting to cook or reheat food.
    4. When the cooking time is completed, the Smart-Pot™ slow cooker will
    automatically shift to the Warm setting and the Warm light will come
    on. NOTE: We do not recommend using the Warm setting for more
    than 4 hours.
    5. To turn the Smart-Pot™ off push the OFF button. Unplug unit from the
    wall outlet.
    6. For other recipes that give a range of times, select the time closest
    to the setting on your Smart-Pot™. For instance a recipe calling for
    cooking time of 7 to 9 hours on LOW, set your Smart-Pot™ to 8 hours.
    NOTE: If power goes off then power light will blink and settings must be
    reset. If cook time is changed before the cycle is complete the time will
    reset to the new setting.
    Thanks for choosing FixYa,
    Kelly
    Mar 04, 2011 | Rival 38601 Smart Pot 6-Quart
    I need the user instructions for use
    Hi and welcome to FixYa, I am Kelly
    I see I am nearly a month late in replying to your post. I just answered another post and when I finished I saw your question.
    This is driectly from the user's manual that you can find here with some difficulty:
    (Avoid answering questions by looking for the blue text that says "security code" and clicking that) Then enter the 4 digit code to download the manual that is 209k)
    2. Plug in Smart-Pot slow cooker. The Power light will begin to flash indicating that the unit is plugged in, but not turned on.
    3. Push the Cook Time button to scroll through the timed cooking options. Push once and the 4 hour light will illuminate, twice and the 6 hour light will come on, etc. Select the time based on the length of time indicated in the recipe. Two time options are usually given. The 4 and 6 hour settings are the HIGH temperature setting and may be used when you want your food done quicker. The 8 and 10 hour settings correspond to the LOW temperature setting and is used for all day cooking. In addition your Smart-Pot can be set to the Warm Setting by scrolling through the timed cooking options until the warm
    light illuminates.
    NOTE: The Warm setting is for keeping already hot food warm. Do not use the warm setting to cook or reheat food.
    4. When the cooking time is completed, the Smart-Pot slow cooker will automatically shift to the Warm setting and the Warm light will come on. NOTE: We do not recommend using the Warm setting for more than 4 hours.
    5. To turn the Smart-Pot off push the OFF button. Unplug unit from the wall outlet.
    6. For other recipes that give a range of times, select the time closest to the setting on your Smart-Pot. For instance a recipe calling for cooking time of 7 to 9 hours on LOW, set your Smart-Pot to 8 hours.
    NOTE: If power goes off then power light will blink and settings must be reset. If cook time is changed before the cycle is complete the time will reset to the new setting.
    That is pretty much the entire user instructions. Everything else is warnings, cautions, and oh yes; don't submerge it in water yadda yadda....
    Kelly
    Feb 05, 2011 | Rival 38601 Smart Pot 6-Quart
    Hi i have a hamilton beach crock pot that only has low, med, and high to cook with. i cannot find my book that has the times or what to put the crock pot on for port tenderlon and how many hours to cook...
    Most recipes will have different times to cook meat, I would make good use of www.google.com and look at recipes and suggestions there. Generally speaking I would say you're going to cook that on low for about 4 hours, but it really does depend on the amount of meat you're cooking and your personal preference.
    Dec 08, 2010 | Hamilton Beach Crock Pots & Slow Cookers
    Whats the differences with the low high and auto settings on a slow cooker which setting is considered best for cooking stews
    The difference is the time and how warm it cooks. Low cooks a slow, lower heat - cooks 6-8 hours. And High is a faster cook at 4-6 hours. I tend to use low for stews and chilis.
    Feb 11, 2010 | Crock Pots & Slow Cookers
    How do I start the cooker on low?
    The manual says "When your corningware slow cooker is initially plugged into a wall outlet, the display will show"0". This display indicates the programmed number of hours for which a meal will cook.
    The slow cooker can be programmed in one hour increments from 1 to 10 on your digital display. The number of hours may be selected by pushing the COOK TIME button until the desired cooking time appears.
    If 1,2,3,4,5 or 6 hours are selected, then the slow cooker will operate on HIGH setting. If 7,8,9 or 10 hours are selected, then the slow cooker will operate on the low setting.
    To start the cooking cycle press the ON/OFF button. To interrupt the cooking cycle at anytime, press the ON/OFF button. If the ON/OFF button is pressed when the digital display shows "0", then the slow cooker will automatically start on the WARM setting.
    When the full cooking cycle is complete, your corningware slow cooker will automatically switch to the warm setting, to keep food at a warm serving temperature."
    If, after you plug the slow cooker into the outlet, the COOK TIME button does not work, unplug the cooker, hold both ON/OFF and COOK TIME buttons down, plug into wall socket and wait till the display flashes. Release both buttons and the slow cooker buttons should both work.
    Dec 18, 2009 | CorningWare SC60 Slow Cooker
    I'm cooking a 7 pound beef rump roast. It has been recommended that I cook it for 7 hours on medium. I only have a high and low setting. How long should I cook it on either or both settings.
    if it is recommended that you cook for 7 hours on medium I would think the you would cook it on high for 3-1/2 hours, and or low for 14 hours but check it with a meat thermometer every hour
    Aug 01, 2009 | Crock Pots & Slow Cookers
    Need directions for presidents choice slow cooker
    Heat intensity is warm, 1, 2, 3 (highest)
    How to operate: Plug in. Set timer to amount of hours to cook. Press the SELECT button to scroll thru 4 settings - "warm", "1" (Low), "2" (Medium)", "3" (High). Once the desired cooking temp selected, press the "round circle" power button to begin cooking. The time display will now start to count down to "0:00" When the cooking time has been reached, the slow cooker will automatically go into "warm" mode for a maximum of 6 hours, then automatically turn off. NOTE: Not recommended using the WARM setting for more than 4 hours at a time. NOTE2: To stop the cooking process at any time, press the "round circle" power button. The unit will default to "0:00" time but the indicator light in the "3" high position will remain on.
    Apr 11, 2009 | Crock Pots & Slow Cookers
    Crock Pots & Slow Cookers Logo
    Top Crock Pots & Slow Cookers Experts
    tsalagi152
    charles
    Irene Tulloch
    Are you a Crock Pot and Slow Cooker Expert? Answer questions, earn points and help others
