I have a blue diamond television what is the code for it
What is the code for a blue diamond television?
Thanks for your post.
After checking our database for remote codes we don't have a code available for your particular make of TV, Blue Diamond.
I will be sending your make of TV to the relevant team to update our remote code database. Remember to check for an update using the link below.
Further information on programming Sky remote controls to control televisions can be found here.
Any further queries don't hesitate to contact us here on Boards or even speak with our support staff on 0818 719 819.
Apr 16, 2017 | Televison & Video
Have solid red light at the 7 o'clock and blinking red light at 11 o'clock
[PDF]Download XD1080 User Guide - Replay XD
Note: The red LED on the rear will blink when the memory card is not inserted .... The Start REC button should always point up or at the 12 o'clock position for a ...
LG TV Blinking - YouTube
? 0:43
Nov 5, 2015 - Uploaded by Gillet Gaming
My TV suddenly started blinking when I turned it on at 12o'clock. ... I was going to use it when a few ...Missing: p
Diamond - ndxLocOut
11/7/15 18:05, San Diego, CA, Diamond, 5 minutes, Orange Diamond like .... 8/23/15 21:08, Wildwood Crest, NJ, Diamond, 2 minutes, Hovering red light, ... Diamond shaped brilliant white light with red light in eastern sky at 12 o'clock ..... flashing blue yellow the red at times staying solid red or blue seems to get bigger. 2/27/ ...Missing: p
[PDF]Air-Pak 75i SCBA - User Manual - Scott Safety
Dec 21, 2015 | Televison & Video
I need a code for a blue diamond tv model number BD40DL fev10
Remote Code for Blue Diamond TV - > Talk to... > Sky Ireland
Aug 7, 2015 - After checking our database for remote codes we don't have a codeavailable for your particular make of TV, Blue Diamond. I will be sending ...
Horizon UPC Blue Diamond LED Remote Control - > ... > Cable & Digital TV > Cable & MMDS & IPTV
Dec 11, 2013 - I have bought a BLue Diamond TV and upgraded to UPC Horizon HD. ... the code for Mitsubishi who from what I can see make Blue Diamond Sky Remote COde
May 29, 2015
Anyone code for programming sky remote bluediamond tv?
Dec 10, 2012
More results from
Dec 10, 2015 | Televison & Video
Brand code for Blue diamond
I had to get a Rev 10 version of the Sky remote as those codes did not work and I entered in the CORRECT Blue diamond code which is 2586. this worked perfectly for me. other codes for blue diamond are: 2134, 2454, 3493, or 3500.
Sep 25, 2014 | Televison & Video
What are the Standard diameter for Razor Wire?
· 0.450m Welded Razor Diamond Mesh 6m
· 1.200m Welded Razor Diamond Mesh 6m
· 1.800m Welded Razor Diamond Mesh 6m
· 2.100m Welded Razor Diamond Mesh 6m
· 2.400m Welded Razor Diamond Mesh 6m
Jun 22, 2011 | Razor MX350 DIRT ROCKET - BLUE
Blue screen on my tv
sounds like the tuner may be out on it if all u get is a blue screen
Jan 11, 2009 | Televison & Video
Blue Ghosting Help Needed
Good Day, jhazelwd;
From what you say it sounds like the Convergence IC's have failed. Part number 267P150010, STK392-570, replace both IC's. They are on the middle board secured to a large heat sink.
Good Luck, big IRISH.
Aug 24, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Tv code
The brand of the remote please.
May 08, 2008 | Televison & Video
Televison & Video Logo
42 people viewed this question
Top Televison & Video Experts
