Question about Canon GL2 Mini DV Digital Camcorder
I cannot access the menu on my camera Canon GL2. Also the manual/auto Focus, nor the Digital Effects buttons work either. I took the memory battery out and then put it back in and all I could do was set the time and date. It hasn't been dropped or damaged in any way that I know of or see.
  • 35 Answers
SOURCE: camcorder won't focus
I hope I can offer a simple solution. If it doesn't work, then I'll I have to ask a few more questions. I know the GL has many buttons and settings and it can be confusing to keep an eye on all of them. Perhaps the camera was changed accidentally to manual focus? Can you check to see it is set to auto focus. If that isn't the case. When you say you can't focus, do you mean when you try to manually focus it, nothing happens?
Posted on Jun 30, 2007
SOURCE: Canon GL2 shuts down automatically while in record mode
Turn off the power saver mode. I did it and it works!
Posted on Sep 07, 2007
SOURCE: Color registration on Canon GL2: purple recorded as blue
I have the same problem on my Canon XH-A1 and sony TRV33. I wonder if this problem applies to all camcorders?
Posted on Mar 07, 2008
SOURCE: Canon XH-A1 Menu Button...
Just b f it....
Posted on Aug 19, 2008
SOURCE: canon gl2 camcorder, how do i download my film to vista
I'm having the same problem. I don't have the disks with the camcorder and Vista is not recognizing nor seeing the camcorder. I'm going to try to download Zoombrowser and see if that makes it work.
Posted on Dec 22, 2009
My canon rebel XSi will not auto focus
Actually what I found to solve the problem was to first set the lens in "MF" and practice taking a picture manually to see if that would work. When I did this, I discovered that the fine tuning portion of the lens was somehow stuck mechanically. I heard a loud click as I turned it. That was all it took to fix the focusing mechanism on the lens. Then I set to "AF" and Voila, the camera worked just fine.
Apr 04, 2010 | Canon EOS Rebel XSi Digital Camera
Tip
Canon GL2 Manual Download
Download Canon GL2 Camcorder Manual
Have you misplaced your Canon GL2 Camcorder Manual?
Would you like a digital, searchable, pdf version of the Canon GL2 Camcorder Guide?
Follow this link (& click FREE) to download a pdf version of the Canon GL2 Camcorder documentation.
I hope that helps.
__________________________________
on May 08, 2010 | Canon GL2 Mini DV Digital Camcorder
Camera stopped taking pictures
Same thing happened to me a while ago. I was in a panic. I turned it on and off several times...no change. Finally, I turned the camera to the off position, took the battery out of the camera for about 30 seconds and put it back in again and it worked fine. No problem since.
Jul 27, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Canon gl2 camcorder, how do i download my film to vista
Apr 07, 2008 | Canon GL2 Mini DV Digital Camcorder
No menu
What do you mean you lost the menu? Can you not see it? Push the button that says EV display.
Feb 25, 2008 | Canon GL2 Mini DV Digital Camcorder
Absolutely screwed up, recently purchased camera
try to shoot without a card. or better use a known good card. [:0)
Jan 10, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Gl2 " overlap" flashing in viewfinder
The flashing overlap on your screen is telling you that you have a digital fader effect (D.EFFECTS) selected. To remove the effect, simply press the D.EFFECTS/BARS SELECT BUTTON and select D.EFFECTS [OFF].
For further information, check the manual under Using Digital Effects.
Dec 04, 2007 | Canon GL2 Mini DV Digital Camcorder
CAMERA WILL NOT TURN ON
I had exactly the same problem I seem to have solved it by holding down the shutter button and then pressing the on/off button. It powered up and the lens stayed out. It was not auto focusing, so I placed it into manual focus and ran it back and forth in manual focus mode. (The circular button on the back adjusts manual focus by pressing it to the right or left) I suspect it's part of the start up self test that checks to see if the auto focus system is working, if it fails it shuts off. I think I stumbled onto a override of sorts by the button combination. Running the manual focus seemed to help. I do have a small black area in the upper right of the screen that gets no light - a dark spot. I store the camera in my pocket, I wonder if some pocket fuzz got into the camera somehow...
Oct 24, 2007 | Casio EXILIM EX-Z1000 Digital Camera
Powers Up but won't take picture
Is this an interchangable lens model? If so remove the lens and reseat it.
Sep 04, 2007 | Canon Digital Rebel / EOS-300D Digital...
Camcorder won't focus
Jul 31, 2006 | Canon GL2 Mini DV Digital Camcorder
Canon GL2 Mini DV Digital Camcorder Logo
51 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
